> foobar2000 Development Forum Rules
This forum is for developer discussions only. If you have a problem / bug report / idea / feature request that isn't related to foobar2000 SDK, post it in an appropiate forum instead - tech support questions go to support forum, everything else goes to general forum.
All non-developer posts on this forum will be removed. Continued abuse of this forum will result in admin actions (warnings, account suspension).
How to force the calling order ?
lowzoom
post Nov 2 2011, 10:59
I have a function:
void func(){
    // initialization ignored ...
    static_api_ptr_t<play_control>()->start(play_control::track_command_next);
    static_api_ptr_t<playlist_manager> ()->playlist_remove_items(list_idx, bit_array_one(item_idx));
When the function is called, foobar2k always removes the song before playing the next one.
This would lead to the "wrong" next song to be played.
I also tried a callback on starting, which, however, makes foobar2k crash...
// in a class named RemoveCallBack:
void on_playback_starting(play_control::t_track_command p_command,bool p_paused) {
    static_api_ptr_t<playlist_manager> list;
    list->playlist_remove_items(list_idx, bit_array_one(item_idx));
    static_api_ptr_t<play_callback_manager>()->unregister_callback(this);
// the previous func
void func(){
    static_api_ptr_t<play_callback_manager>()->register_callback(
        new service_impl_t<RemoveCallBack>,
        play_callback::flag_on_playback_starting,
        false
How can I force foobar2k to play the next song before removing a specific song from the playlist?
This post has been edited by db1989: Nov 4 2011, 18:28
Reason for edit: Please use the standard font size for normal text, not an enlarged one.
Zao
post Nov 2 2011, 12:25
Group: Members (Donating)
Verify in the SDK comments whether it's legal to modify the playlist while in a play callback.
If it's forbidden, which it probably is, you can register a main_thread_callback from there, and do your operation inside of that.
In particular, it may be illegal to unregister a callback from inside itself. Yet another case where a main_thread_callback helps.
This post has been edited by Zao: Nov 2 2011, 12:25
lowzoom
post Nov 2 2011, 13:44
QUOTE (Zao @ Nov 2 2011, 12:25) *
Yes, you're right. It's the unregister-self behavior that crashes foobar2k.
I've followed your advice and unregistered the callback successfully.
But... foobar2k still removes the song before starting to play the next one,
which is opposite to my expectation and causes the "wrong" next song to play.
That really confuses me.
Is there any other way to get the thing done:
Start playing the next song in the current playing order first, and then remove the previous one from the playlist ?
Thank you.
foosion
post Nov 2 2011, 14:12
Group: FB2K Moderator (Donating)
Playlist modifications happen synchronously, whereas the playback start request is processed asynchronously. One way to achieve the desired result might be to use the playback queue. You could add the track to the queue using its playlist position, start playback and remove the song from the playlist. Of course you would also have to worry about the state of the playback queue, i.e. whether it is empty. I think that is how I handled it in foo_utils.
lowzoom
post Nov 2 2011, 16:34
QUOTE (foosion @ Nov 2 2011, 14:12) *
Very impressive... You know really a lot! Are you the author of foobar2k?
Your method works very good, however, except one thing:
It seems that I have to decide the next song myself.
Any way to know which song is the next to play in the current playing order (without actually playing it) ?
Thank you.
This post has been edited by lowzoom: Nov 2 2011, 16:45
mudlord
post Nov 4 2011, 09:39
Group: Developer (Donating)
QUOTE (lowzoom @ Nov 2 2011, 09:34) *
No, foosion worked on some portions of the player. Another person did the rest, etc...
lowzoom
post Nov 4 2011, 16:03
QUOTE (mudlord @ Nov 4 2011, 09:39) *
So maybe I should call him one of the authors ?
db1989
post Nov 4 2011, 18:26
foosion contributed to foobar2000 itself between 2005 and 2006, but has been more active in creating various components for it and maintaining the tutorials for others interested in doing so; hence, no doubt, his knowledge of its inner workings.
foosion
post Nov 4 2011, 19:07
Yeah, what the others said. I have been around since about 2002 as a foobar2000 user, plugin author, forum moderator and alpha tester. I have contributed some parts to foobar2000 and the SDK, and was sometimes mistaken for being its author. ;-) My most active time was until 2006/2007. Since then life, work and other interests have taken their toll on the time I spend on foobar2000 and my knowledge of the SDK is getting hazy. I still try to help new developers to get started with the SDK which has become significantly more complex in the past nine years.
Hm, I think I should put this text on my profile page here on the forum. :-)
RSS Lo-Fi Version Time is now: 3rd September 2015 - 11:58
