iTunes Plus AAC encoding flawy, High and Best settings cause corrupt audio
Danny_DJ
post Sep 7 2011, 16:28
by chance i discovered audio glitches in AAC encoding. I used 256 CBR Stereo AAC w/ XLD 20110821 on Mac OS 10.6.8 with high or best mode, but it gave me a eventually "scratchy sound". I contacted the developer of XLD, "tmkk". He cross-checked it w/ iTunes Plus internal encoding and confirmed this bug and suggested me to contact this forum since here are some of the iTunes' AAC encoder's developers. So could anyone please have a look into this?
The affected source file can be found here:
http://soundcloud.com/dannywho/amelie-went...eview-1/s-FrDeC
Already at the intro there is an alteration of the sound recognizable. There it sounds quite musical (it seens a little bit like conga drums on top of the bassdrum) but since I composed it on my own I know which sounds I've put in and which not.
And then very noticably from 2:35 through the end, five times very significantly.
Try to convert it on your own.
Regards,
Danny
This post has been edited by db1989: Sep 7 2011, 18:23
Reason for edit: restoring link; self-composed so not a TOS #9 violation
My Music: www.soundcloud.com/dannywho
db1989
post Sep 7 2011, 18:07
QUOTE (Danny_DJ @ Sep 7 2011, 16:28) *
Are there? I know some people who work on Neros AAC codec are members here, but Ive never heard of there being anyone from Apple (or whoever provides their encoder). I could well be wrong, but Id be interested in confirmation either way.
mixminus1
post Sep 7 2011, 18:37
Confirmed under Windows XP via qaac and qtaacenc with foobar2000, QT 7.7.0.
Weird "ghost notes" at the beginning, and very distinct distortion on the bass notes after the 2:35 mark.
I didn't try qaac's "quality" switch, as I don't know what its 0-2 range maps to, but trying the various quality settings in qtaacenc, the artifacts were consistent with --best, --higher, and --high (the default), but disappeared with --normal.
This was true at CBR 256 and 192, as well as --tvbr 90.
Good find!
Danny_DJ
post Sep 7 2011, 18:49
@db1989: don't remove this entry, it is required for other users to be able to make comparisons and confirmations on their own.
The unflawed original AIFF source can be found here:
http://soundcloud.com/dannywho/amelie-went...preview/s-Sdqx4
b66pak
post Sep 7 2011, 19:14
QUOTE (mixminus1 @ Sep 7 2011, 20:37) *
I didn't try qaac's "quality" switch, as I don't know what its 0-2 range maps to...
tested for "--tvbr 127" and compared the output aac lenght:
qaac quality 0 = qtaacenc fastest
qaac quality 1 = qtaacenc normal
qaac quality 2 = qtaacenc high
qaac quality 2 = qtaacenc highest
_
/mnt
post Sep 7 2011, 19:46
Sounds like it's a problem with the pre-echo handling on QT. This problem is much worse on certain Kraftwerk tracks (Die Roboter / The Robots and Spacelab), even at tvbr 127.
This post has been edited by /mnt: Sep 7 2011, 19:47
"I never thought I'd see this much candy in one mission!"
Danny_DJ
post Sep 9 2011, 09:10
I got informed that the reason for that problem has been found and the fix should come in a future release, but w/o any mention about when exactly.
kawaiigardiner
post Sep 30 2011, 04:48
I know I am a little late to the conversation but has the original poster tried the exact same audio file with Mac OS X Lion? I've encoded around 1/2 dozen different files so far and haven't come across it so I wonder whether it is a 'Snow Leopard only bug'.
mixminus1
post Sep 30 2011, 05:17
Is the version of QuickTime included with Lion newer than 7.7.0? It's definitely not exclusive to Snow Leopard as I was able to reproduce it under Windows with the same version of QuickTime.
Note that this particular artifact is very program-dependent, and since it affects all AAC encoding methods of QuickTime from the default quality setting on up, it theoretically could show up on tracks currently on the iTunes Music Store.
However, of the several dozen I've downloaded over the past couple years, I've never heard anything like it, nor anything else I could positively identify as an encoding artifact.
kaoruAngel
post Oct 18 2011, 22:26
SoundCloud reports that it "can't find that page!" for both links posted [ http://soundcloud.com/dannywho/amelie-went...eview-1/s-FrDeC and http://soundcloud.com/dannywho/amelie-went...preview/s-Sdqx4 ]. Where can I find this source track to test with?
I made the decision this past week to switch to QT's AAC encoder after reading IgorC's latest AAC listening test in which Nero performed poorly, but now your report concerns me! Am I wrong to use QT?
Danny_DJ
post Oct 18 2011, 22:32
I took these files offline since "skuo" as part of the Apple AAC dev team reported that he found the reason for that issue and that a solution will be implemented in furter QT engine updates.
I add that this issue was the only one I ever encountered w/ AAC. I am buying a lot of iTunes music which is encoded the same way and never had any sound issues.
matt the cat
post Jan 23 2012, 18:10
To be honest, I dont really trust Apple, it would be useful to be able to test this with the newer versions.
HTS
post Jan 29 2012, 04:02
QUOTE (mixminus1 @ Sep 7 2011, 12:37) *
Good find!
Qaac's site says:
Since 1.00, qaac directly uses CoreAudioToolbox.dll. Therefore, QuickTime installation is no more required. However, Apple Application Support is required.
Does this make a difference?
Danny_DJ
post Feb 16 2012, 18:26
Hey guys,
DeaDruiD PM'd me and told me the following:
The glitches were easily hearable when encoding using qaac+CoreAudioToolbox.dll 7.9.7.3 (included in QuickTime 7.7.0 for Windows) and disappeared completely when using CoreAudioToolbox.dll 7.9.7.9 (included in Safari 5.1.4 for Windows). The newest version does not include any changes to the AAC encoder, so it is safe to assume that version 7.9.7.8 (included in QuickTime 7.7.1, iTunes 10.5.3 and Safari 5.1.2) is glitch-free as well. Using newest version of QuickTime/iTunes for Mac should work as well.
But now comes my problem: I am on Snow Leopard 10.6.8, my System Profiler tells me that my QT framework is on 7.6.6.
There seems to be no way to seperately get any higher version for SL. Or am I wrong?
My System Updater gives me no QT option and the Apple download section tells me that QT is always up to date w/ my system updater.
Are QT updates discontinued w/ the introduction of Lion?
Regards,
Danny
Danny_DJ
post Feb 16 2012, 18:56
Post #15
Update:
I just went for the latest security update which was available and that now fixed the glitches, although my system profiler still tells me that I am on 7.6.6.
Thanks for the developers around that they investigated in that issue, found the error and finally have implemented the solution with the latest update smile.gif
RSS Lo-Fi Version Time is now: 26th January 2015 - 02:25
