7 Pages V  « < 2 3 4 5 6 > »
lossyWAV 1.3.0 Delphi to C++ Translation Thread, Added noise linear PCM bitdepth reduction method.
Nick.C
post Dec 16 2012, 23:11
Post #76
lossyWAV Developer
Got sidetracked again - I'm going to add an option to convert any valid input audio (9-bit to 32-bit signed integer) to Float16, with or without adaptive / fixed noise-shaping. This will require the same messing about with the WAV handling code that I had to do for TransPCM. ETA is sometime early in the new year.
lossyWAV -q X -a 4 --feedback 4| FLAC -8 ~= 320kbps
Atak_Snajpera
post Jan 3 2013, 16:44
Post #77
any progress on lossywav?
Nick.C
post Jan 3 2013, 23:28
Post #78
lossyWAV Developer
Still working on it, still distracted by the Elite: Dangerous KickStarter....
FreaqyFrequency
post Jan 7 2013, 18:17
Post #79
I've been experimenting with various compression levels in FLAC and -q X, and I've found that for certain tracks, -0 compresses much more efficiently than higher levels, and is practically equivalent with at least one of the tracks I tested at -8. Extraportable combined with -0 might very well make for the most overall efficient decode combination ever. Exciting stuff.
FLAC -2 w/ lossyWAV 1.3.0i -q X -i
Nick.C
post Jan 18 2013, 21:26
Post #80
lossyWAV Developer
lossyWAV beta 1.3.0g attached to post #1 in this thread.
FreaqyFrequency
post Jan 20 2013, 08:25
Post #81
QUOTE (Nick.C @ Jan 18 2013, 15:26) *
Neat! I'm getting an average of 2 to 3 kbps reduction at level 0 compression for the material I've tested so far. It also seems to average faster processing than 1.3.0a, which is what I was using previously.
Nick.C
post Jan 20 2013, 18:00
Post #82
lossyWAV Developer
QUOTE (FreaqyFrequency @ Jan 20 2013, 07:25) *
I've carried out a FLAC settings comparison test (based on my 55 problem sample test set) and will post the results this evening.
Nick.C
post Jan 20 2013, 22:44
Post #83
lossyWAV Developer
I did a bit of testing with my 55 problem sample set (12:43.933 of audio) processed using "-q X" and got the following results:
| FLAC | Relative |
| Encoder +----------+----------+
| Setting | Size | Time |
| -8 -m -r 8 -p | 97.66% | 2187% |
| -8 -r 8 -p | 97.66% | 2089% |
| -8 -e -r 8 -p | 97.66% | 2094% |
| -8 -e -m -r 8 -p | 97.66% | 2105% |
| -8 -e -p | 97.66% | 1599% |
| -8 -p | 97.66% | 1615% |
| -8 -m -p | 97.66% | 1616% |
| -8 -e -m -p | 97.66% | 1634% |
| -6 -e -m -r 8 -p | 98.06% | 1689% |
| -7 -e -r 8 -p | 98.06% | 1694% |
| -6 -e -r 8 -p | 98.06% | 1695% |
| -7 -e -m -r 8 -p | 98.06% | 1697% |
| -4 -e -m -r 8 -p | 98.06% | 1701% |
| -7 -r 8 -p | 98.06% | 1705% |
| -7 -m -r 8 -p | 98.06% | 1710% |
| -5 -e -m -r 8 -p | 98.06% | 1723% |
| -5 -e -r 8 -p | 98.06% | 1799% |
| -7 -e -p | 98.06% | 1215% |
| -6 -e -p | 98.06% | 1220% |
| -6 -e -m -p | 98.06% | 1222% |
| -7 -m -p | 98.06% | 1222% |
| -7 -e -m -p | 98.06% | 1224% |
| -7 -p | 98.06% | 1225% |
| -5 -e -p | 98.10% | 983% |
| -5 -e -m -p | 98.10% | 1020% |
| -4 -e -m -p | 98.18% | 825% |
| -8 -r 8 | 98.36% | 368% |
| -8 -m -r 8 | 98.36% | 370% |
| -8 -e -m -r 8 | 98.36% | 374% |
| -8 -e -r 8 | 98.36% | 379% |
| -8 -e -m | 98.36% | 249% |
| -8 -m | 98.36% | 249% |
| -8 | 98.36% | 250% |
| -8 -e | 98.36% | 250% |
| -3 -e -m -r 8 -p | 98.69% | 1449% |
| -6 -e -m -r 8 | 98.80% | 294% |
| -7 -e -r 8 | 98.80% | 295% |
| -7 -r 8 | 98.80% | 295% |
| -5 -e -r 8 | 98.80% | 296% |
| -7 -e -m -r 8 | 98.80% | 296% |
| -6 -e -r 8 | 98.80% | 296% |
| -4 -e -m -r 8 | 98.80% | 298% |
| -7 -m -r 8 | 98.80% | 298% |
| -5 -e -m -r 8 | 98.80% | 318% |
| -6 -e -m | 98.81% | 174% |
| -7 -e -m | 98.81% | 175% |
| -6 -e | 98.81% | 176% |
| -7 -m | 98.81% | 177% |
| -7 -e | 98.81% | 183% |
| -7 | 98.81% | 189% |
| -3 -e -m -p | 98.82% | 605% |
| -5 -e | 98.86% | 127% |
| -5 -e -m | 98.86% | 138% |
| -4 -e -m | 98.95% | 105% |
| -3 -e -m -r 8 | 99.40% | 261% |
| -6 -m -r 8 -p | 99.42% | 201% |
| -6 -r 8 -p | 99.42% | 205% |
| -5 -r 8 -p | 99.42% | 206% |
| -5 -m -r 8 -p | 99.42% | 209% |
| -4 -m -r 8 -p | 99.42% | 215% |
| -6 -m -p | 99.42% | 137% |
| -6 -p | 99.42% | 138% |
| -5 -m -p | 99.45% | 106% |
| -5 -p | 99.45% | 108% |
| -4 -m -p | 99.51% | 87% |
| -3 -e -m | 99.55% | 71% |
| -3 -m -r 8 -p | 99.86% | 209% |
| -3 -m -p | 99.95% | 88% |
| -6 -m -r 8 | 99.97% | 28% |
| -6 -r 8 | 99.97% | 31% |
| -5 -m -r 8 | 99.97% | 32% |
| -4 -m -r 8 | 99.97% | 33% |
| -5 -r 8 | 99.97% | 33% |
| -6 -m | 99.97% | 6% |
| -6 | 99.97% | 7% |
| -5 -m | 100.00% | -1% |
| -5 | 100.00% | 0% |
| -4 -m | 100.06% | -5% |
| -3 -m -r 8 | 100.44% | 27% |
| -3 -m | 100.52% | -9% |
| -3 -e -r 8 -p | 100.54% | 678% |
| -3 -e -p | 100.69% | 279% |
| -3 -e -r 8 | 101.28% | 102% |
| -3 -e | 101.45% | 9% |
| -3 -r 8 -p | 101.76% | 78% |
| -3 -p | 101.87% | 20% |
| -3 -r 8 | 102.37% | -15% |
| -3 | 102.48% | -30% |
| -4 -e -r 8 -p | 102.59% | 846% |
| -4 -e -p | 102.74% | 403% |
| -4 -e -r 8 | 103.33% | 130% |
| -4 -e | 103.50% | 28% |
| -4 -r 8 -p | 104.08% | 85% |
| -4 -p | 104.19% | 22% |
| -4 -r 8 | 104.64% | -8% |
| -4 | 104.76% | -28% |
| -2 -e -m -r 8 -p | 108.34% | 113% |
| 0 -e -m -r 8 -p | 108.34% | 114% |
| 0 -e -m -r 8 | 108.34% | 114% |
| -2 -e -m -r 8 | 108.34% | 115% |
| -1 -e -m -r 8 | 108.34% | 115% |
| -1 -e -m -r 8 -p | 108.34% | 117% |
| -2 -e -r 8 -p | 108.34% | 118% |
| -2 -e -r 8 | 108.34% | 119% |
| -2 -r 8 | 108.50% | -4% |
| 0 -m -r 8 -p | 108.50% | -3% |
| 0 -m -r 8 | 108.50% | -3% |
| -1 -m -r 8 -p | 108.50% | -2% |
| -2 -r 8 -p | 108.50% | -1% |
| -2 -m -r 8 | 108.50% | -1% |
| -1 -m -r 8 | 108.50% | 0% |
| -2 -m -r 8 -p | 108.50% | 5% |
| -2 -e -m -p | 108.65% | -2% |
| -2 -e -m | 108.65% | -1% |
| -1 -e -m -p | 108.65% | -1% |
| 0 -e -m -p | 108.65% | -1% |
| 0 -e -m | 108.65% | -1% |
| -1 -e -m | 108.65% | 2% |
| -2 -e -p | 108.65% | 5% |
| -2 -e | 108.65% | 7% |
| 0 -m | 108.71% | -28% |
| 0 -m -p | 108.71% | -28% |
| -1 -m | 108.71% | -27% |
| -2 -m -p | 108.71% | -27% |
| -2 | 108.71% | -27% |
| -2 -m | 108.71% | -25% |
| -2 -p | 108.71% | -23% |
| -1 -m -p | 108.71% | -21% |
| 0 -e -r 8 -p | 110.94% | 30% |
| 0 -e -r 8 | 110.94% | 35% |
| 0 -r 8 -p | 111.12% | -31% |
| 0 -r 8 | 111.12% | -28% |
| 0 -e | 111.29% | -29% |
| 0 -e -p | 111.29% | -25% |
| 0 -p | 111.37% | -41% |
| 0 | 111.37% | -34% |
| -1 -e -r 8 -p | 113.83% | 34% |
| -1 -e -r 8 | 113.83% | 44% |
| -1 -r 8 -p | 114.06% | -27% |
| -1 -r 8 | 114.06% | -24% |
| -1 -e -p | 114.18% | -20% |
| -1 -e | 114.18% | -19% |
| -1 -p | 114.31% | -39% |
| -1 | 114.31% | -38% |
This post has been edited by Nick.C: Jan 23 2013, 22:20
Nick.C
post Jan 23 2013, 22:19
Post #84
lossyWAV Developer
lossyWAV beta 1.3.0h attached to post #1 in this thread.
Nick.C
post Jan 30 2013, 23:20
Post #85
lossyWAV Developer
lossyWAV beta 1.3.0i attached to post #1 in this thread.
Nick.C
post Feb 8 2013, 22:31
Post #86
lossyWAV Developer
lossyWAV beta 1.3.0j attached to post #1 in this thread.
Cynic
post Feb 19 2013, 23:31
Post #87
What is the penalty (if any) for using the -i switch? Slower encoding, higher risk of artifacts, or both? For someone not that concerned with filsesize, is the new noise shaping routine preferable to the default?
Nick.C
post Feb 20 2013, 22:03
Post #88
lossyWAV Developer
Hi Cynic,
The penalty is simply that the noise shaping is a bit more aggressive in trying to conform to the lossless audio spectrum. This saves about 1% of the resultant lossyFLAC size when compressed at --extraportable, less at higher quality levels.
I am currently working on a (very) simplistic psymodel based on masking using the Bark scale. This may be a wrong turn, but it is an option for both the classic method and the --interp-curve method of determining the basis shape of the noise spectrum.
Nick.
Banned
post Mar 2 2013, 21:20
Post #89
Out of curiousity, why does the distribution include a "gpl.txt" file? I thought it is for open source software.
Nick.C
post Mar 3 2013, 17:33
Post #90
lossyWAV Developer
When v1.40 is released, the source will be as well in a similar manner to the previous versions.
Nick.C
post Mar 8 2013, 21:27
Post #91
lossyWAV Developer
lossyWAV beta 1.3.0k attached to post #1 in this thread.
[edit] updated to beta 1.3.0k2 [/edit]
[edit2] updated to beta 1.3.0k3 [/edit2]
This post has been edited by Nick.C: Mar 8 2013, 22:26
Nick.C
post Mar 25 2013, 23:04
Post #92
lossyWAV Developer
lossyWAV beta 1.3.0m attached to post #1 in this thread.
Nick.C
post Mar 30 2013, 15:14
Post #93
lossyWAV Developer
lossyWAV beta 1.3.0n attached to post #1 in this thread.
skamp
post Mar 30 2013, 15:31
Post #94
Thanks for your work. I'm looking forward to 1.3.0 final.
doccolinni
post May 26 2013, 03:04
Post #95
I may be late for the party, but regarding the internal FFT routines...
You might consider using FFTW's genfft to generate efficient FFT routine source code. genfft is a set of routines written in OCaml which generate C code for efficient FFT routines. For example, this is a C code for 128-sample MDCT generated with genfft. These were used to generate FFTW's FFT routines, and you can use it to generate the code for lossyWAV's internal FFT routines. You can download it from here. Contact fftw@fftw.org and I'm sure they'll gladly assist you with using it to generate code for lossyWAV.
This post has been edited by doccolinni: May 26 2013, 03:11
doccolinni
post May 26 2013, 05:43
Post #96
By the way, you can read more about genfft and why FFTW is fast here.
The best solution, however, is to not have a specified internal FFT routine, because ultimately its performance will be hardware-specific (better/worse on some hardware). You are better off completely relying on FFTW since it adapts itself to whatever hardware it's used on.
This post has been edited by doccolinni: May 26 2013, 05:47
Nick.C
post Jun 11 2013, 19:34
Post #97
lossyWAV Developer
lossyWAV beta 1.3.0o attached to post #1 in this thread.
Hi doccolinni,
The internal FFT / IFFT routines are only used if the appropriate FFTW 32-bit DLL is not available to lossyWAV.
Nick.
Atak_Snajpera
post Jun 12 2013, 23:13
Post #98
does pipeing work with wave64 format? for example latest flac 1.3 -> lossywav -> latest flac 1.3
This post has been edited by Atak_Snajpera: Jun 12 2013, 23:16
Nick.C
post Jun 13 2013, 07:16
Post #99
lossyWAV Developer
FLAC 1.3.0 > lossyWAV 1.3.0o > FLAC 1.3.0 works with --force-wave64-format in the first FLAC command.
Atak_Snajpera
post Jun 13 2013, 12:33
Post #100
I've encoded using pipes (FLAC -> lossywav -> FLAC) 2h:41m 6 channels avatar soundtrack without any problems.
Lossywav now really needs multithreading optimalization. Using internal algo it took 40 minutes to complete task on my Q6600@3Ghz. With proper multithreading this could be reduced to 12-14 minutes.
Btw What exactly .dll does lossywav need to use FFTW? libfftw3-3.dll , libfftw3f-3.dll or libfftw3l-3.dll ?
One more thing. You forgot to include pthreadGC2.dll in package.
RSS Lo-Fi Version Time is now: 24th July 2014 - 01:51
