IPB
> foobar2000 Tech Support Forum Rules
Please read foobar2000 Tech Support Forum Rules before posting and comply with all the points.
Failure to provide all the information pointed out in the above document in your post is considered wasting other people's time and in extreme cases will lead to your topic getting locked without a reply.
See also: Hydrogenaudio Terms of Service.
FooBar doesn't read song ratings from their ID3v2 tags, Fixing this will get me to dump WMP
shademe
post Apr 1 2010, 01:18
Post #1
Group: Members
I primarily use Windows Media Player 12 for my music requirements, and have set it to save star ratings as globals in the file itself (through its ID3 tag). Unfortunately, Foobar2000 1.0.1 doesn't seem to read ratings from song tags ( as far as I can tell, at least ). Would someone please help me fix this issue if it's possible to ? I'd appreciate it a lot. Thank you for your time.
This post has been edited by shademe: Apr 1 2010, 01:19
Go to the top of the page
+Quote Post
shakey_snake
post Apr 1 2010, 01:31
Post #2
Group: FB2K Moderator
1) Open WMP.
2) Sort your library by rating
3) select all items with a rating of X
4) drag and drop them onto a fb2k playlist.
5) with all dropped items selected, press Alt+Enter, opening fb2k's properties dialog
6) Ctrl+N to Add a new field called RATING
7) Click the Single Value Tab enter the X rating, press OK and OK again.
8) Repeat steps 3-7 for each rating.
This post has been edited by shakey_snake: Apr 1 2010, 01:37
Reason for edit: Now with more detail
elevatorladylevitateme
+Quote Post
shademe
post Apr 1 2010, 01:33
Post #3
Group: Members
QUOTE (shakey_snake @ Apr 1 2010, 06:01) *
You can drag and drop files from WMP to fb2k, selecting all files with each rating and tag them with fb2k's property dialog. just add a RATING field or whatever you want.
I can drag-drop files from WMP ?! Nice. I'll try it out. Thanks again!
+Quote Post
shademe
post Apr 1 2010, 01:52
Post #4
Group: Members
Strange - I'm having trouble performing the drop. The cursor changes to the Not Available icon on entering fb2k's playlist area. I'm not even using any custom skins.
+Quote Post
tpijag
post Apr 1 2010, 02:44
Post #5
Group: Members
A possible explanation is that you may be dragging to a autoplaylist.
terry
+Quote Post
shakey_snake
post Apr 1 2010, 03:09
Post #6
Eh. It doesn't seem WMP supports drag-and-drop.
I doesn't even seem like you can export playlists.
Gosh, I'm sorry shademe.
I had not idea that piece of crap was locked down so hard. I know this method has worked with iTunes for people before.
+Quote Post
shademe
post Apr 1 2010, 03:15
Post #7
Group: Members
QUOTE (shakey_snake @ Apr 1 2010, 07:39) *
Hardly an issue in any case - I'll just sort my W7 Library by rating and move it through explorer.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 22nd September 2014 - 17:27
