IPB
2 Pages V   1 2 >
my EAC currently rips very fast
Bobjua
post Aug 9 2005, 18:30
Post #1
Group: Members
my eac rips whole 50 minute albums in 2 minutes. I know its not supposed to be that fast, and the last rip i did had lots of clicking. it could be the drive im using.
im going to try my other drive, but in case i cant figure it out, can anyone help me with configuring EAC to suit my computer.
Go to the top of the page
+Quote Post
Cartoon
post Aug 9 2005, 18:53
Post #2
Group: Members
Check that you're not ripping in burst mode, EAC->Drive Options->Extraction Options
+Quote Post
Bobjua
post Aug 9 2005, 21:00
Post #3
Group: Members
no im in secure mode. is there a fast way to show everything about my computer. and then someone can help me to set EAC up to run as good as it can.
+Quote Post
teleguise
post Aug 9 2005, 22:54
Post #4
Group: Members
Here is the EAC & LAME quickstart quide.. http://users.pandora.be/satcp/cd2mp3-en.htm
There is lots of information on EAC setup.. Search the forums if need more
'Typically' the following will be checked..
Secure Mode, Drive has Accurate Stream feature, Drive Caches Audio Data
Under Gap Detection Tab
'Typically' you will have 'Detection Method A' and 'Secure Mode' set...
NOTE: These are GENERAL guidelines for many drives...
Your drive may differ but this should set you in the right direction, the guide explains
how to set EAC up for your individual drive.
+Quote Post
Bobjua
post Aug 9 2005, 23:56
Post #5
Group: Members
Okay thanks. I'll check it out.
i just want to clarify one thing. i have 2 drives but only one audio cable. does the cable matter at all?
+Quote Post
mp3chan
post Aug 10 2005, 00:00
Post #6
Group: Members (Donating)
QUOTE (Bobjua @ Aug 9 2005, 10:56 PM)
Then you can only use one of them to play CD-Audio or is there any soundcard with 2 CD inputs? Anyway you can always play CD audio with DAE mode so that u won't need to worry about the cable.
And audio cable doesn't affect audio extraction at all.
This post has been edited by mp3chan: Aug 10 2005, 00:02
+Quote Post
Bobjua
post Aug 10 2005, 01:29
Post #7
Group: Members
Well if it has nothing to do with extraction then i dont care about it. I dont listen to cds with my computer.
UPDATE !!
okay i followed that guide. and it still goes really fast. im listening to what i extracted and there is a lot of clicks... sooo.... here is the logfile.
QUOTE
EAC extraction logfile from 10. August 2005, 0:10 for CD
Sanctuary / Magna Canta
Used drive  : HL-DT-STDVDRAM GSA-4163B  Adapter: 1  ID: 1
Read mode  : Secure with NO C2, accurate stream, NO disable cache
Combined read/write offset correction : 0
Overread into Lead-In and Lead-Out : No
Used output format : Internal WAV Routines
                    44.100 Hz; 16 Bit; Stereo
Other options      :
    Delete leading and trailing silent blocks : No
    Native Win32 interface for Win NT & 2000
Track  1
    Filename D:\Magna Canta\Sanctuary - Magna Canta - 01 - Russia.wav
    Peak level 96.3 %
    Track quality 100.0 %
    Copy CRC F4487DF9
    Copy OK
Track  2
    Filename D:\Magna Canta\Sanctuary - Magna Canta - 02 - Kyrie.wav
    Peak level 97.9 %
    Track quality 99.9 %
    Copy CRC A51F6441
    Copy OK
Track  3
    Filename D:\Magna Canta\Sanctuary - Magna Canta - 03 - Pater Noster.wav
    Missing samples
    Peak level 0.0 %
    Copy finished
Track  4
    Copy aborted
Track  5
    Copy aborted
Track  6
    Copy aborted
Track  7
    Copy aborted
Track  8
    Copy aborted
Track  9
    Copy aborted
Track 10
    Copy aborted
Track 11
    Copy aborted
There were errors
End of status report
i just cancelled it on the 3rd track.
This post has been edited by Bobjua: Aug 10 2005, 05:14
+Quote Post
teleguise
post Aug 10 2005, 09:26
Post #8
Group: Members
Well I'm guessing your problem is that you have 'NO' disable cache..
Most likely your drive did not report correctly to EAC. I would recommend setting
(checking) the "Drive Caches Audio Data Box" so that the log reads :
Read mode : Secure with NO C2, accurate stream, disable cache
(assuming of course I hope your drive DOES accurate stream)
It appears your drive -DOES- cache audio data and when EAC tries to re-read the data
to detect any discrepancies it is pulling the drives cached data which of course is going
to be identical. Therefore EAC cannot detect any errors and thinks the stream was
good (duplicate reads) and continues on quickly giving you the end result of
(Lots of clicks and pops)
I'm guessing track 2 was 99.9% and not a 100% (in this case) because of a Gap re-read.
This post has been edited by teleguise: Aug 10 2005, 09:35
+Quote Post
Bobjua
post Aug 10 2005, 21:16
Post #9
Group: Members
Very fast again EDIT: and very clicky still. im going to try my other drive.
QUOTE
EAC extraction logfile from 10. August 2005, 16:14 for CD
Magna Canta / Sanctuary
Read mode   : Secure with C2, accurate stream, disable cache
Other options      :
Track  1
     Filename D:\Magna Canta\Magna Canta - Sanctuary - 01 - Russia.wav
     Peak level 96.3 %
     Copy CRC F4487DF9
     Copy OK
No errors occured
This post has been edited by Bobjua: Aug 10 2005, 21:17
+Quote Post
teleguise
post Aug 10 2005, 21:31
Post #10
Group: Members
QUOTE (Bobjua @ Aug 10 2005, 12:16 PM)
You did -NOT- set your settings like I suggested...
NO C2 (Uncheck) drive is capable of retreiving C2 error information
"Read mode : Secure with NO C2, accurate stream, disable cache"
Again of course all this depends on the condition of the disc as well and the
possibility of copy protection. Trying another drive and disc will determine if
its hardware or your software (your disc).
This post has been edited by teleguise: Aug 10 2005, 21:34
+Quote Post
rohangc
post Aug 10 2005, 22:37
Post #11
Group: Members
QUOTE (teleguise @ Aug 10 2005, 02:26 AM)
This is the same thing as the HA.org wiki. Please configure your drive according to the KnowledgeBase and then let us know if it solved your problem.
+Quote Post
Bobjua
post Aug 13 2005, 18:54
Post #12
Group: Members
i give up
+Quote Post
heavymetalwiseon...
post Aug 13 2005, 19:02
Post #13
Group: Members
I would recommend sth else. Try to rip cds using another prog such as CDex. If the extracture is still very fast (but uncheck on the fly), then it must be your drive. If not, I don't know stick with CDex.
Heavy Metal Is the Law!!!
---Let 'Em Eat Metal---
+Quote Post
teleguise
post Aug 13 2005, 20:12
Post #14
Group: Members
QUOTE
  i give up
Well you never did say if you configured it like rohangc & myself told you to follow.
It's literally impossible for it to go that fast with those settings and every post showed one of your settings -WRONG- .
+Quote Post
Bobjua
post Aug 14 2005, 03:00
Post #15
Group: Members
fine ill show you with the settings the way you said.
edit: ps, i never said how fast it goes. it rips at about 4-6x, which is fast for EAC isnt it?
here is the options you suggested.
QUOTE
EAC extraction logfile from 13. August 2005, 22:03 for CD
Other options      :
    Installed external ASPI interface
Track  1
    Filename C:\Documents and Settings\Shane\My Documents\Magna Canta - Sanctuary - 01 - Russia.wav
    Peak level 96.3 %
    Copy CRC AA134C13
    Copy OK
No errors occured
still has a lot of clicking. and i know its not the cd, because i keep ripping the same track and the clicks are always at different points.
This post has been edited by Bobjua: Aug 14 2005, 03:07
+Quote Post
A_Man_Eating_Duc...
post Aug 14 2005, 03:29
Post #16
Group: Members
Have you ripped the same song twice and compare them to see if there is any differences?
What are you using to play the ripped file?
What soundcard are you using?
Are you using the latest drivers for your board and soundcard?
Have you checked that DMA is enabled?
Whats the specs of your system ?
Is your soundcard sharing an IRQ with anything ?
This post has been edited by A_Man_Eating_Duck: Aug 14 2005, 03:31
+Quote Post
Bobjua
post Aug 14 2005, 05:13
Post #17
Group: Members
Yes, i just said that didnt i?
foobar
i dont know
i dont know
i dont know
all of them?
i dont know
PS. im listening to some scene releases and they have clicking sometimes too. damn its annoying. i never really cared that much, but now i notice it so easily.
edit: so what im saying is maybe i should be happy enough with the quality im getting.
This post has been edited by Bobjua: Aug 14 2005, 05:16
+Quote Post
A_Man_Eating_Duc...
post Aug 14 2005, 05:26
Post #18
Group: Members
QUOTE (Bobjua @ Aug 14 2005, 04:13 AM)
foobar
i dont know
i dont know
i dont know
all of them?
i dont know
by comparing the files i mean use the EAC compare wav's function in the tools menu
maybe it's a good time to turn your machine off and poke you head inside it and find out what you have.
Or
download SANDRA and use that
This post has been edited by A_Man_Eating_Duck: Aug 14 2005, 05:31
+Quote Post
teleguise
post Aug 14 2005, 06:26
Post #19
Group: Members
QUOTE
Track  1
    Peak level 96.3 %
    Copy CRC AA134C13
    Copy OK
Will that track if extracted again report the identical results? If so though then it
sounds definitely like a sound/mboard issue. If not clicks could appear in different
places if it were an issue with your drive/cd.
I gather you don't have the convenience of another computer handy, do you?
I don't recall you ever saying if when playing back the cd in foobar or EAC does it
click?
QUOTE
No... cause then you wouldn't be here wink.gif .. It's seems like its leaning towards a sound
card/board issue.
You could check for conflicts & specs with "msinfo32" however Sisoft Sandra, Aida32
report more -detailed- specs of your system.
QUOTE
And no that's average.... 10x is about the upper end with those settings.
This post has been edited by teleguise: Aug 14 2005, 06:30
+Quote Post
landy
post Aug 14 2005, 09:48
Post #20
Group: Members
for a properly set up lg drive i would say 10x speed atleast should be expected in secure mode i often get closer to 15x sometimes with my 4120b, test and copy is even faster (the few times i have used it) but as everything is done twice the end result is rips take just as long.
+Quote Post
dreamliner77
post Aug 14 2005, 10:04
Post #21
Group: Members
I think it's either
1) Poor cd mastering
or
2) Soundcard settings.
What are your volume sliders at? (wave and master)
"You can fight without ever winning, but never win without a fight." Neil Peart 'Resist'
+Quote Post
user
post Aug 14 2005, 13:51
Post #22
Group: Members
EAC could do the testing for him.
Please rip again some tracks, but now in EACs secure no c2, disable cashe, TEST & Copy mode.
Then u will see, if u get 2 times the same waves by extraction.
Maybe follow this guide High Quality Audio EAC Tutorial
www.High-Quality.ch.vu -- High Quality Audio Archiving Tutorials
+Quote Post
Bobjua
post Aug 15 2005, 17:21
Post #23
Group: Members
okay i got that Aida32 program. what exactly am i looking for on it?
i wouldnt be surprised if all this has something to do with my soundcard, because i dont remember ever updating its drivers haha.
+Quote Post
heavymetalwiseon...
post Aug 15 2005, 22:18
Post #24
Group: Members
What about my recommendation? I don't think you got sth to lose.
Besides, you will see whether your drive is the matter or not.
+Quote Post
Bobjua
post Aug 16 2005, 04:56
Post #25
Group: Members
okay heavymetalwiseone, i did what you said too. i ripped the same track with CDex and it clicks still.
PS. im going to try to find out how to update my audio drivers now.
+Quote Post
2 Pages V   1 2 >
0 Members:
RSS Lo-Fi Version Time is now: 26th January 2015 - 04:49
