6 Pages V   1 2 3 > »
Open Source Fraunhofer AAC Encoder (fdk-aac)
D404
post Jul 11 2012, 17:02
Android 4.1 has included an AAC encoding library by Fraunhofer, and Libav/FFmpeg support for this library is in the works (that is, in a day or two, it will be official.)
From the release announcement:
As part of the Android Jelly Bean source code released recently, a new AAC
library was released as well, developed by Fraunhofer:
https://android.googlesource.com/platform/external/aac
To ease using this library on platforms other than Android, I have added
an autotools based build system and done a minor portability fix, and
released this code as fdk-aac 0.1.0 today.
This project is hosted at sourceforge, under the opencore-amr project,
acting as an umbrella project for these codecs that are repackaged from
Android as standalone libraries, just as opencore-amr, vo-amrwbenc and
vo-aacenc before this one.
The release file is available at
http://sourceforge.net/projects/opencore-amr/files/fdk-aac/
and the code is available in git at
git://opencore-amr.git.sourceforge.net/gitroot/opencore-amr/fdk-aac.
This library is licensed under a custom copyleft style license:
http://opencore-amr.git.sourceforge.net/gi...a=blob;f=NOTICE
I in general intend to limit this project to minor tweaks and portability
fixes - for anything larger than that, I'd prefer if it first is
contributed upstream, to keep the difference between the upstream code and
this library as small as possible.
Edit: Obvious patent violation removed.
It can be used as such:
Bitrate Mode
avconv -i <input> -c:a libfdk_aac -b:a <bitrate> -afterburner 1 <output>
VBR Mode
aconv -i <input> -c:a libfdk_aac -flags +qscale -global_quality [1-5] -afterburner 1 <output>
VBR modes 1-5 correspond to roughly:
  1. about 32 kbps/channel
  2. about 40 kbps/channel
  3. about 48-56 kbps/channel
  4. about 64 kbps/channel
  5. about 80-96 kbps/channel
-afterburner 1 enabkes "improved quality" mode.
Cheers.
Edit: This should be moved to the Tech forum.
This post has been edited by Garf: Jul 11 2012, 19:30
Garf
post Jul 11 2012, 19:02
Server Admin
Group: Admin
Heh, interesting. It was pointed out that the previous encoder they had had very questionable licensing because it appeared to be 3GPP code with the copyright notice of another firm slapped on it: http://www.hydrogenaudio.org/forums/index....showtopic=88183
I guess Google "fixed" that.
IgorC
post Jul 11 2012, 19:14
I wonder if it's the same or similar encoder as Winamp FhG AAC. It has the same number of VBR modes (the last version of past year). If it's the case then it will be a first high quality open source AAC encoder. w00t.gif
This post has been edited by IgorC: Jul 11 2012, 19:16
LithosZA
post Jul 11 2012, 19:21
I wonder if it's the same or similar encoder as Winamp FhG AAC. It has the same number of VBR modes. If it's the case then it will be a first high quality open source AAC encoder. w00t.gif
I hope this is true
Garf
post Jul 11 2012, 19:23
Server Admin
Group: Admin
QUOTE (LithosZA @ Jul 11 2012, 20:21) *
I hope this is true
It certainly looks like the real thing to me... (I don't know if this is Winamps encoder, but it's certainly a full-featured encoder not based on any code I've seen, with full psymodel, smart bitallocation etc)
IgorC
Can anyone run this encoder in high quality mode (-afterburner 1) with VBR let's say at 96 kbps compare it to Winamp FhG encoder VBR 3 in wave editor?
Brand
post Jul 11 2012, 20:31
QUOTE (IgorC @ Jul 11 2012, 20:14) *
But the bitrates are much lower than those from Winamp's FhG AAC. (Mode 4 in Winamp's encoder is ~130kbps, for example.)
Or maybe those are not the same kind of VBR modes?
IgorC
post Jul 11 2012, 20:37
Winamp FhG encoder: VBR 4 130 kbps stereo.
This new encoder: VBR 4 64 kbps/channel, 130 kbps stereo.
This post has been edited by IgorC: Jul 11 2012, 20:39
punkrockdude
post Jul 11 2012, 20:49
Interesting! I look forward to try it.
Brand
post Jul 11 2012, 20:52
QUOTE (IgorC @ Jul 11 2012, 21:37) *
Oh, I see.
It would be nice if it's the same encoder then. To me it sounded like the best AAC encoder when I was testing them (only tested with one sample, tho..).
This post has been edited by Brand: Jul 11 2012, 20:53
06_taro
post Jul 11 2012, 22:33
libfdk-aac also has an aac decoder, which can decode AAC-LD/AAC-ELD, though limited to 16-bit integer output.
IgorC
post Jul 11 2012, 22:38
as well as ELD/LD-AAC encoder.
saratoga
post Jul 12 2012, 00:04
QUOTE (06_taro @ Jul 11 2012, 17:33) *
Not much in the way of ARM assembly code though, so probably no faster then existing arm decoders.
hlloyge
post Jul 12 2012, 09:37
Is this available on windows?
D404
post Jul 12 2012, 16:01
Post #15
QUOTE (hlloyge @ Jul 12 2012, 04:37) *
I had posted one but it was removed due to :patents: (even though the VisualOn binary is still allowed... I dunno why.)
Looks like you'll have to compile from source yourself, of use the magic of the Internet to find one.
Garf
post Jul 12 2012, 16:40
Post #16
Server Admin
Group: Admin
QUOTE (D404 @ Jul 12 2012, 17:01) *
Fixed, thanks for pointing this out.
2012
post Jul 12 2012, 17:45
Post #17
It looks like low pass decisions are broken in CBR for bitrates >192kbps (2 channels/ 44100Hz).
It seems to never go above 17kHz even if the bitrate is set to 512kbps.
D404
post Jul 12 2012, 20:22
Post #18
QUOTE (2012 @ Jul 12 2012, 12:45) *
Seems to be settable in the API, and should be added as an option to avconv soon, I think.
benski
post Jul 12 2012, 20:31
Post #19
Winamp Developer
QUOTE (D404 @ Jul 12 2012, 11:01) *
I am not a lawyer, but here is the part of the license that is problematic for use of this source code in other projects
  51 3.    NO PATENT LICENSE
  52
  53 NO EXPRESS OR IMPLIED LICENSES TO ANY PATENT CLAIMS, including without limitation the patents of Fraunhofer,
  54 ARE GRANTED BY THIS SOFTWARE LICENSE. Fraunhofer provides no warranty of patent non-infringement with
  55 respect to this software.
  56
  57 You may use this FDK AAC Codec software or modifications thereto only for purposes that are authorized
  58 by appropriate patent licenses.
This post has been edited by benski: Jul 12 2012, 20:32
saratoga
post Jul 12 2012, 21:01
Post #20
QUOTE (benski @ Jul 12 2012, 15:31) *
  52
  56
I don't think that would be a problem for most open source licenses. Off hand I can't think of any that force you to also provide patent licenses to go with the software license, since in practice that would be almost impossible to know which patents were covered and which were not. IIUC, that basically leaves you in the same place as the GPL, you're allowed under copyright law but patent law is up to you and your country.
Garf
post Jul 12 2012, 21:48
Post #21
Server Admin
Group: Admin
The extra statements in the license are there because it's a BSD-style license, and there's some line of legal arguing (not confirmed in court. and quite arguable, but still) that says that BSD licensed software comes with an implicit patent license. FhG especially doesn't want to give you such a license because they make money from AAC patents, which is why they add that clarification.
(Note that even if FhG had given an implicit or explicit license, there are still many AAC patents they don't own. So you can't distribute AAC encoder binaries without a patent license. Please don't post illegal stuff here, which means no encoder binaries unless you have an actual licensing deal.)
hlloyge
post Jul 13 2012, 17:29
Post #22
How do I fit it into foobar2000 for encoding?
Canar
post Jul 13 2012, 18:42
Post #23
QUOTE (hlloyge @ Jul 13 2012, 09:29) *
It needs to be compiled and released somewhere first. Whether Rarewares is an acceptable site to host such material seems to be a topic of discussion right now.
You cannot ABX the rustling of jimmies.
No mouse? No problem.
skamp
post Jul 13 2012, 19:55
Post #24
I'd settle for instructions on how to compile avconv (libav) with support for fdk-aac. Or would that be illegal too?
Garf
post Jul 13 2012, 20:15
Post #25
Server Admin
Group: Admin
QUOTE (skamp @ Jul 13 2012, 20:55) *
Nothing wrong with that. Publishing source code is OK, talking about patented technologies is OK too (we wouldn't have much to discuss if it wasn't :-)
6 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 29th November 2014 - 08:51
