17 Pages V  « < 15 16 17
foo_softplaylists, Aggregated playlists from last.fm's loved track feature
marc2003
post Jan 26 2013, 10:11
Post #401
authentication failed
double check your username/password.
This post has been edited by marc2003: Jan 26 2013, 10:18
EpicForever
post Jan 26 2013, 13:19
Post #402
Hey, I can still scrobble what I'm paying... I see it on my last.fm profile...
EDIT:
OK, I'm an idiot. I haven't entered my username and password in softplaylist config :/
This post has been edited by EpicForever: Jan 26 2013, 13:23
nikolai4ik
post Jan 26 2013, 16:06
Post #403
Hi, what's the command for loving/unloving a track for a columns splitter script?
I'm trying to change this script to love/unlove using softplaylists.
$if($stricmp('FOO_LASTFM',$left(%path%,10)),
    $imageabs2(14,14,0,0,0,0,$get(x),$get(y),'./images/curacao/bt/mood_off.png',nokeepaspect)
    $ifgreater(%MOOD%,0,
        $button($get(x),$get(y),0,0,14,14,'./images/curacao/bt/mood_on.png','./images/curacao/bt/mood_off.png',TAG:SET:MOOD:0,TOOLTIP:"Unset")
        $button($get(x),$get(y),0,0,14,14,'./images/curacao/bt/mood_off.png','./images/curacao/bt/mood_on.png',TAG:SET:MOOD:1,TOOLTIP:"Set")
How do I find which command to use instead of tag:set?
WilB
post Jan 26 2013, 16:42
Post #404
You can see the list of available commands by going to the panel stack splitter script tab and choosing context in the drop down menu at bottom left. I think that the commands you want are there.
This post has been edited by WilB: Jan 26 2013, 16:43
nikolai4ik
post Jan 26 2013, 19:58
Post #405
QUOTE (WilB @ Jan 26 2013, 19:42) *
I've tried that before but it only inputs the name of that function, for example selecting "ReplayGain/Apply album ReplayGain to MP3 data" adds the same text to the script window.
EpicForever
post Jan 26 2013, 23:12
Post #406
I noticed one bad thing. Banning tracks from foo_softplaylists works - I see "banned tracks list" on my L.fm profile, but foo_audioscrobbler just scrobbles them and they are still visible in my recently played list and become entries in my L.fm library... It may be problem with Last.FM servers/web software, but I'm not sure, maybe there's something that could be done inside client software to prevent this behaviour... I think I should also post it in audioscrobbler thread, as I don't know which plugin may be responsible for this.
nikolai4ik
post Jan 27 2013, 06:32
Post #407
QUOTE (EpicForever @ Jan 27 2013, 02:12) *
I'm pretty sure banning tracks only works for last.fm radio.
EpicForever
post Jan 27 2013, 10:13
Post #408
QUOTE (nikolai4ik @ Jan 27 2013, 06:32) *
Ah, OK. Last.fm radio is the feature that I never used, so I forgot about it smile.gif . Thanks.
WilB
post Jan 27 2013, 12:53
Post #409
@nikolai4ik
Did you put CONTEXT: in front of the command; e.g. CONTEXT:Properties;? I know this example works and so you can use it as a check to ensure that there are no other errors in your code. CONTEXT:Last.fm Love Track; in panel stack splitter ought to work the same as it does with the softplaylists right click menu item but I do not use that feature so I haven't tested it. I did test CONTEXT:Last.fm Artist Top Tracks; which is also a softplaylist context command and it works.
This post has been edited by WilB: Jan 27 2013, 13:48
flaviocfneto
post Jan 27 2013, 14:19
Post #410
This might be a bit out of topic, but is there a way to automate (in a periodical way or at least at foobar's startup or shutdown) the fetching of Last.fm playlists by foo_softplaylists?
Regards,
nikolai4ik
post Jan 27 2013, 16:33
Post #411
QUOTE (WilB @ Jan 27 2013, 15:53) *
@nikolai4ik
This works in a splitter code but not in the track info mod panel for some reason, but that doesn't matter. Thanks.
Do you know if there's a command to check if the track is loved? So the button I'm making would act as a toggle instead of having two different buttons.
marc2003
post Jan 28 2013, 14:06
Post #412
QUOTE (nikolai4ik @ Jan 27 2013, 15:33) *
you might be interested in my WSH panel mod script here....
http://www.hydrogenaudio.org/forums/index....showtopic=76772
if a track is already loved, clicking the button will unlove it.
nikolai4ik
post Jan 28 2013, 15:40
Post #413
QUOTE (marc2003 @ Jan 28 2013, 17:06) *
Used to use it, but I've moved away from unneeded extra tags and databases. I've added two separate buttons to the default button toolbar for now. Some wsh last.fm panels are able to fetch the loved info to display the heart icon so it should be possible without custom db.
kapa6ac
post Feb 15 2013, 14:12
Post #414
QUOTE (slyman @ May 26 2011, 03:18) *
QUOTE (.misiek @ Apr 15 2011, 15:50) *
First of all it is a brilliant plugin, but i've noticed that when i'm listening streaming radio from internet plugin reports:
foo_softplaylists: failed to love track: title and/or artist tag not present
, although title and artist is visible in foobar on both playlist and item details info, and plugin foo_audioscrobbler reports:
Audioscrobbler: Submitting track...
Audioscrobbler: Submission succeeded.
I suspect, that plugin takes title and artist directly from file tag instead of variables %title% and %artist%. Is that correct?
im having the same problem did you ever figure this out?
Anybody resolved this problem of tags and variables from online streaming?
anybody? )
Innomen
post Apr 23 2013, 17:32
Post #415
Problem signature:
  Problem Event Name:    BEX
  Application Name:    foobar2000.exe
  Application Version:    1.2.5.0
  Application Timestamp:    51727b8b
  Fault Module Name:    foo_softplaylists.dll
  Fault Module Version:    0.0.0.0
  Fault Module Timestamp:    4d4cbe4f
  Exception Offset:    00035a64
  Exception Code:    c0000417
  Exception Data:    00000000
  OS Version:    6.1.7600.2.0.0.256.1
  Locale ID:    1033
  Additional Information 1:    2649
  Additional Information 2:    2649cd0ebbcba5b93a1c084b3e56b1b7
  Additional Information 3:    ab25
  Additional Information 4:    ab25449ea2b79ac193486f0c7a295159
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
What have I done wrong?
Is this not the most recent version?
http://www.foobar2000.org/components/view/foo_softplaylists
17 pages of ancient comments. This plugin is awesome, it needs an actual page of its own smile.gif
WilB
post Apr 23 2013, 17:36
Post #416
Did you try the patched version in post #387?
hymerman
post Apr 23 2013, 17:40
Post #417
The latest version is broken - it's using an old last.fm API key and handles that by crashing smile.gif Someone (romor) fiddled with the DLL to patch it up a few pages back - that version works - but the 'official' version hasn't had its source updated so still crashes, and the original author has disappeared so it will probably never be fixed. Here's the link to the post with the fixed version: http://www.hydrogenaudio.org/forums/index....st&p=811096
Or if you only want it for "So and so's top tracks" (that's all I used this component for), foo_bestversion will do that, and is a little bit smarter about matching tracks to your library too: http://www.hydrogenaudio.org/forums/index....howtopic=100019
Innomen
post Apr 23 2013, 21:16
Post #418
QUOTE (hymerman @ Apr 23 2013, 11:40) *
Thank you!
QUOTE (romor @ Oct 10 2012, 13:46) *
He was using test API key wchich is now deprecated: http://www.last.fm/group/Last.fm+Web+Servi...21604/_/2188288
Here is patched version that works (with my api_key): http://goo.gl/zwKi7
I'll remove the file, when Johan resolves it
(From the linked thread)
Thank you too!
lemond
post Sep 4 2013, 09:32
Post #419
I was able to save and load an xspf playlist involving a folder in the library. I also listen to files remotely located such as an mp3 direct link to a file stored on an internet accessible resource or an audio stream. Can the (fb2k)library->foo_softplaylists plugin handle these as well?
Kougeru
post Feb 10 2014, 05:00
Post #420
I don't understand this XSPF playlist stuff. CAn someone explain it to me or at tell me what's wrong. I have a playlist with 8513 files. I saved it as an XSPF using this compontent. I loaded the new playlist and it only added 3995 files on it. I couldn't find a logical explaining for this. For example, it had track 2 and 3 of one CD but not track 1 despite the only difference in tagging was the title of the first track and the track number. Second, I moved "track 2" of that same CD to different location and tried to play it to test to see if the claims were true and Foobar said no file was found.
Is my component busted? I have the latest version as listed a few posts up. I thought there might be some unicode issues (which is why I switched to m3u8 playlists years ago) but a lot of the tracks that remain are unicode and are just fine.
BenB
post Feb 10 2014, 18:50
Post #421
You can search the forums and the internet for more information in regard to XSPF playlists in general.
Now, as to XSPF playlists created via foo_softplaylists. Looking at a playlist in a text editor shows me that this implementation stores no location information (making it portable, duh). This means that the playlist is entirely dependent upon the media application reading it to find matching entries.
Sooooo... when you load an XSPF playlist with foo_softplaylists, the component depends upon foobar's media library database having matching entries to load the playlist (whether or not the XSPF playlist was created by foo_softplaylists because I'm guessing location information is ignored even when it is present. I'll test this conjecture at some point, maybe, but not right now). Thus any entries not matching anything in foobar's media library or files that the media library fails to locate (dead entries) will not load.
Further inspection of the playlist reveals that entries with odd-sized durations/durations of "0" (internet radio streams, for example) will also fail to load.
Hopefully this explains why so many entries failed to load for you. Then again, creating an XSPF playlist with more than a few dozen items at most is a bit...
This post has been edited by BenB: Feb 10 2014, 18:55
Jubei
post Apr 20 2014, 13:54
Post #422
QUOTE (hymerman @ Apr 24 2013, 00:40) *
Thanks for the info. Haven't been using this plugin for a while and crashed when I did use it. Figured it was some deprecated API issue and was worried since the plugin hasn't been updated for a while. Good to know there is a temp work around
FuzzyNL
post Sep 20 2014, 08:26
Post #423
Anyone has the sources of this project? I noticed it was posted 2 years ago with a dropbox link but the link is dead sad.gif
Kougeru
post Feb 3 2015, 04:51
Post #424
QUOTE (BenB @ Feb 10 2014, 11:50) *
So I figured out (a year later lol) what's wrong. It's CHANGING my artists OR the song titles for some reason. For example, "One More Time, One More Chance" by "山崎まさよし" is being written as "山崎まさよぁE" Under "Creator", So it's not being imported. An example of the track being changed is "想い出は遠くの日々" as the track and creator is "天門". The track on the xspf is written as "想ぁEx81Eは遠くxE3x81E日、E"
Changing them manually doesn't seem to work, I wouldn't know why maybe because editing it with notepad++ doesn't actually do anything. Idk, but half my songs from pretty much any random playlist of any length are being excluded because of this. That's the only thing consistent with files that don't work that I can find though. This happens with English songs too though. They will randomly have the letter "E" and a symbolized "x81" or whatever randomly in between letters. Anyone have any ideas how to fix this?
edit: It seems like it's only happening with Japanese songs or English songs that have apostrophes or other symbols. Is this a Unicode issue then? It works fine for thousands of songs but randomly not others. One song that works even has the exact same title as one that doesn't work, just has an "E" added to the end and some weird x(NumbersHere) coding....really makes no sense to me why some work and others don't. I'd be honestly happier if NONE worked just because it would make sense to me lol.
This post has been edited by Kougeru: Feb 3 2015, 05:11
marc2003
post Feb 4 2015, 11:05
Post #425
if the problem is only with saving xspf files, you might be able to knock something up with foo_utils (the text tools section) to save your playlists.
RSS Lo-Fi Version Time is now: 30th July 2015 - 09:43
