6 Pages V   1 2 3 > »
Text to speech component
paulski
post Jun 23 2003, 21:10
I've just finished a little plugin that speaks aloud the artist and track whenever a new song starts. This is handy for when I'm in the shower and don't have access to my screen, but still want to know who's playing.
Is anyone interested in this? If so, I'll make it available.
Paulski
<edit>
Here is the url for foorbar 0.667: tts plugin
and for foorbar 0.7: tts plugin
</edit>
This post has been edited by paulski: Aug 19 2003, 22:45
meischder
post Jun 23 2003, 21:58
Why not? Sounds very funny! If Peter has nothing against it, but why? smile.gif
Edit: I have got it! How does it work? I can't get it to work sad.gif
This post has been edited by meischder: Jun 24 2003, 00:17
Celeron 1300 Tualatin @ 1589, 512 MB Micronchip CL2, 0,5 TB HD, Audigy 2 ZX Platinum Pro, Sony MDS-JE530 DAC, Sony STR-GX 311 Ampifier, Sennheiser HD 570 Headphones, Creative Inspire T7700 7.1
WavOX
post Jun 24 2003, 05:45
After I have extracted the DLL to foobar2000 directory, I start my foobar.
but a dialog is popped up that the DLL requires MSVCR70.dll.
Could you pls let me download the run-time dll fr your site also?
~ WavOZip+ <i><span style='color:green'>Heroes Edition</span></i>
~ <a href='http://www.geocities.com/waveofx/index.html' target='_blank'>WavOX</a>
picmixer
post Jun 24 2003, 06:59
You should be able to get msvr70.dll fom this site: http://fb2k-plugins.hydrogenaudio.org/General.html.
Several plugins require it to function.
Gemini
post Jun 24 2003, 07:03
i just keep clicking on random songs to hear stuff
its even funnier cuz i have a lot of asian songs with romanized titles, and the pronunciations are completely funky biggrin.gif
mlejeune
post Jun 24 2003, 07:17
Would be cool if we could disable it in the prefs though.
Mat
Yatta!
paulski
post Jun 24 2003, 07:38
It is admittedly very basic at the moment. I'll add some prefs to it (especially the option to disable speech) and let you know when its updated. I'll also include the source code and the MSVCR70.dll file.
Paulski
paulski
post Jun 24 2003, 09:37
meischder - do you have the same problem as WavOX? If not, it may be that your system does not have not have a speech engine installed.
If you use windows XP, it should run "out of the box" using the SAPI 5.1 speech runtime binaries. Look at the "speech" options in the windows XP control panel to see if you have any voices installed and enabled.
If you use windows 2000 then you are using an older version of the speech runtime library (SAPI 4.1). I assumed that these versions are compatible from an API call point of view, but I will look into it to be sure.
Any older version of windows means that you may need to download and install the runtime environment for the Microsoft TTS engine yourself: Microsoft SAPI 4.
Paulski
KosciaK
post Jun 24 2003, 09:42
Hello!
I've just downloaded it and installed in Foobar2000 directory, I've got MSCR70.DLL installed. But this plugin does nothing. sad.gif
There's no error messages, it's listed in components list in preferences.
Using win2k, Foobar v0.667
KosciaK
paulski
post Jun 24 2003, 13:22
Ok, I have found the problem: SAPI 5.x (the windows XP speech environment) is NOT compatible with SAPI 4 (win2K and earlier).
For now, I suggest only winXP users bother with the plugin until I get a win2k compatible version together.
<edit>
For win98/win2k users:
You could of course download the SAPI 5.x SDK which installs the compatible speech engine for SAPI 5 but this is 68 MB!!!!!
</edit>
I'll keep you posted
Paulski
This post has been edited by paulski: Jun 24 2003, 16:26
paulski
post Jun 24 2003, 18:38
For XP users only: there is a new version of the plugin available that allows you to enable or disable speech output within foobar settings (TTS settings). See 1st post for link.
paulski
post Jun 24 2003, 19:43
I've found a nice link to the Microsoft speech 5.1 runtime files for windows 98 and windows 2000 systems. It's a 6 MB download:
sapi51 runtime install
Goto www.aldostools.com for more info on how to install.
Have fun
Paulski
Canar
post Jun 24 2003, 23:32
QUOTE (paulski @ Jun 23 2003 - 12:10 PM)
What would be really nifty would be to implement this as an input plugin as well.
2. Assume good faith.
ak
post Jun 24 2003, 23:42
Musepack Developer
Heh, I can swear that evil MS Sam is singing along on some tracks he announces.
It's when he goes 'Tricky - She makes me wana die', starting from 'makes' he's perfectly in synch with Martina's singing.
This is the only case so far, but I think he's adapting to do more. ph34r.gif
Nice plugin btw.
spase
post Jun 24 2003, 23:54
Post #15
is there a way to get new speech packs, besides microsoft sam?
http://www.last.fm/user/spase
-spase-
upNorth
post Jun 25 2003, 00:11
Post #16
I think it would be a nice feature to be able to hear the name of the song, before playback starts.
It's sometimes hard to hear what he says.
Canar
post Jun 25 2003, 02:14
Post #17
Another nice feature would be the ability to specify what the plugin says.
paulski
post Jun 25 2003, 08:59
Post #18
I'm already working on your last suggestion Canar, but I'm not sure what the advantage of using it as an input plugin is. Can you expand on that?
upNorth - I'm not sure if it's possible to delay playback of the audio until the speech has finished because I currently use the callback from foobar that a song has just started as a trigger to speak. Any suggestions?
Paulski
Gemini
post Jun 25 2003, 11:15
Post #19
I'm also wondering if its possible to get different voices. I had the SDK already and used a speech program to convert text to mp3's, and I used different voices for that. I'm sure its possible with this as well.
Luxus
post Jun 25 2003, 11:22
Post #20
QUOTE (Gemini @ Jun 25 2003 - 02:15 AM)
yes where i get nice voices?
i hate sam :/
paulski
post Jun 25 2003, 11:50
Post #21
Go to the aldostools link I gave earlier. You can get Microsoft Mike and Mary using their installation. Although Mary sounds more like a castrated Mike, they're certainly better than Sam. I would love to get my hands on the AT&T natural voices engines - they sound soooo much more realistic, but you have to pay for them.
nexus
post Jun 25 2003, 16:13
Post #22
Nice plugin, i like it, but it would be so much better if you'll add option to change the tts engine options...
like replace between female - male voices.. speed and such. thanks.
paulski
post Jun 25 2003, 22:17
Post #23
There's an update that lets you choose a specific voice within the plugin.
Coming next: change voice rate, voice volume and text fields (3 of them) for specifying which tag fields (e.g. artist tag field) should be read aloud. Still thinking on how to speak the next track between songs (i.e. with no music playing until speech has finished). Maybe pause the track or turn down the volume until its finished speaking - I'll set it up as an option.
Paulski
This post has been edited by paulski: Jun 25 2003, 22:26
Canar
post Jun 25 2003, 23:29
Post #24
QUOTE (paulski @ Jun 24 2003 - 11:59 PM)
Just makes foobar a text-file-compatible audio player. wink.gif I've seen image viewers that were text-file compatible as well. Just an interesting idea, is all. Pure geek value. Like PC Speaker output. That would be cool. biggrin.gif
upNorth
post Jun 25 2003, 23:52
Post #25
QUOTE (Canar @ Jun 25 2003 - 11:29 PM)
Vocal remover, lyrics as input and you can have Sam sing your favourite tune... biggrin.gif
This post has been edited by upNorth: Jun 25 2003, 23:52
6 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 27th February 2015 - 09:36
