Topic: How to eliminate GAP between tracks in iTunes (Read 4569 times) previous topic - next topic
I am ripping some classical music CDs into iTunes. Those tracks are continuing music, but iTunes seems to separate them between tracks by 1 second. How can I eliminate the gap(you would feel sudden stop, and then hear the next track) when I am playing those files in iTunes?
Thanks a lot!!
AAC files produced by iTunes are not gapless, so, you can't.
There is a workaround (but not perfect): you can set crossfader to 0 seconds.
Thanks a lot!!
I believe what you want to do is go under the Advanced menu when you're ripping and select "Join CD Tracks"
Regards,
-JD-
Thanks a lot!!
Regards,
-JD-
Will that join them all or just the ones that were originally that way?
"The future is already here, it's just not evenly distributed." - William Gibson
"I like the future; I'm in it." - Firesign Theater
Thanks a lot!!
Regards,
-JD-
The whole CD comes out as one file IIRC.
That would seem to introduce a much bigger problem than it "solves."
Yes, because, you don't have individual tracks then, so you can't tag them...
Can I produce "GAPLESS" AAC files by other programs which can also access CDDB, and then put tracks back to iTunes?
The reason I want to use iTunes is it can manage/search some hundreds albums in a very good way. Or, should I move to other programs with good managing interface? Please suggest.
Thanks a lot for your guys' answering..
