7 Pages V  « < 5 6 7
Autosave & Autobackup (foo_jesus), Free salvation for your configuration, playlists and soul.
marc2003
post Dec 22 2014, 18:04
Post #151
with foobar open, hold shift and click file>browse configuration folder. (that's assuming WINE can handle the command to open whatever file browser it uses)
fohrums
post Dec 22 2014, 23:20
Post #152
QUOTE (fohrums @ Dec 22 2014, 16:30) *
QUOTE (Andreasvb @ Dec 20 2014, 17:38) *
QUOTE (fohrums)
Foobar2000 directory stores all necessary information?
If it's in portable mode, yes.
huh.gif So, where and what are these files? This is because I don't have mine installed as portable.
To properly understand this plugin, the opening should say "Works better if you have foobar2000 installed as 'portable'"
Now the contents of my .zip backup works when I extracted it to my foobar2000 directory.
This post has been edited by fohrums: Dec 22 2014, 23:20
fohrums
post Dec 22 2014, 23:24
Post #153
QUOTE (lvqcl @ Dec 19 2014, 22:57) *
IIRC playlists and PlaybackStatistics.dat entries are now obsolete.
How can I backup the playback statistics from foo_playcount? Most importantly how can I found out how to backup a particular item?
**UPDATE**
I found out that these correlate to foobar2000's directory. As directories themselves or files.ext. This is what you call control! loving it!
This post has been edited by fohrums: Dec 22 2014, 23:39
DustMagnet
post Dec 23 2014, 01:01
Post #154
QUOTE (fohrums @ Dec 22 2014, 14:20) *
To properly understand this plugin, the opening should say "Works better if you have foobar2000 installed as 'portable'".
Not really. The only reason the description was inadequate for you is because you're not using the plugin.
In which case it helps to understand that since Vista (some 8 years ago), by default Windows expects configuration information to be saved to the user profile folder.
In the case of foobar2000, it's:
C:\Users\xxx\AppData\Roaming\foobar2000\
where xxx is your username.
The portable installation of foobar2000, where everything is in the program folder, is not normal. I don't think it's normal for any modern OS, actually.
That's so plausible, I can't believe it.
Andreasvb
post Dec 23 2014, 01:51
Post #155
I like to have everything in one folder, easier to manage with portable.
When using Windows' own management it can sometimes end up either in roaming, local, or documents.
And you may not know what the folder is called, some use their company name, other the product name.
Windows 8.1u3 Pro x64 Media Center // foobar2000 1.3.8
fohrums
post Dec 23 2014, 11:44
Post #156
QUOTE (DustMagnet @ Dec 23 2014, 01:01) *
QUOTE (Andreasvb @ Dec 23 2014, 01:51) *
Same, I love the idea of everything in one folder. The only reason for it to be in window's configuration 'appdata" is for registry purposes (shell link, shortcuts, etc), you know the useless stuff that windows apparently thinks is important dry.gif .
johnniewalker39
post Feb 8 2015, 01:47
Post #157
QUOTE (Yirkha @ Jan 8 2009, 23:51) *
Yirkha, GOD BLESS YOU!
Power surges made my playlist changes disappear... i had to save them by hand... THANK YOU!
I'm learning to be brave in my beautiful mistakes.
7 Pages V  « < 5 6 7
RSS Lo-Fi Version Time is now: 6th July 2015 - 21:47
