17 Pages V  « < 14 15 16 17 >
foo_softplaylists, Aggregated playlists from last.fm's loved track feature
Chainyk
post Dec 16 2011, 23:41
Post #376
How 2 create a column with loved tracks ?
Maeldun
post Dec 23 2011, 17:44
Post #377
Feature Request:
This might be a longshot, but can you use the last fm feed to parse something a little more complex than the standard overall/12/6/3 month feed from last.fm?
Specifically, is it somehow feasabile to implement a feature that could create soft playlists from scrobbles from within a given time period? Instead of loading up my most listened tracks over the last year, I would like to load up my most listened tracks from August 2008, or the first 5 weeks of 2010, for instance. I know that Last.fm keeps the data required for something like this (through the scroblle cart history browser - http://www.last.fm/user/Maeldun/charts?charttype=weekly) however it doesn't serve the data in an outright manner.
Using this, you could have something like a "nostlagic" playlist builder from within your music library - music you relate to a certain time period.
I'm thinking you could download the raw profile data off last.fm and have the plugin do the parsing locally. What are your thoughts?
tberman333
post Feb 6 2012, 16:12
Post #378
QUOTE (hanshans @ Jan 17 2010, 16:24) *
I am searching for a way to synchronize my playlists between two foobar installations on different machines.
In a perfect world, this would be possible through an online service, like it is possible with xmarks to sync bookmarks in firefox.
But maybe it also could be done by using the xspf file format and a network share?
Would it be possible to export all playlists automatically to an specified directory from time to time? every x minutes or when the playlist has been changed? Maybe only some playlists which are explicitly selected.
THX so far for this great component
I am trying to do something similar to this, but I can't even figure out how to save a playlist as xspf (it seems to only give me the option for my entire library). Does anyone know if anything like this is possible?
GO WHALE!!!
[url="http://www.toddberman.com"]My Website[/url]
r3ddy
post Jun 15 2012, 08:39
Post #379
Hi! Functions from context menu like "like, ban, unban" don't work. What can be the problem?
bulletproof2k
post Jun 15 2012, 13:57
Post #380
QUOTE (r3ddy @ Jun 15 2012, 10:39) *
You need update scripts "marc2000" use serch on forum :]
♪ ♪ ♪ (((d[^_^]b))) ♪ ♪ ♪
marc2003
post Jun 15 2012, 14:37
Post #381
QUOTE (bulletproof2k @ Jun 15 2012, 13:57) *
@r3ddy, if the context menu isn't working for you as expected, check for messages in the foobar console found on the view menu. also make sure your username and password are correctly set (file>preferences>tools>soft playlists)
bulletproof2k
post Jun 16 2012, 19:11
Post #382
mXENO
post Sep 29 2012, 22:26
Post #383
Is there a limit on playlist size or am I doing something wrong? My "Loved Tracks" always tops out at 460, even though Last.FM states I have 600+ loved tracks.
This post has been edited by mXENO: Sep 29 2012, 22:27
Fractal_Mortalit...
post Oct 10 2012, 01:34
Post #384
Uh oh, this component appears to no longer be working for me. Foobar crashes as it queries for loved tracks. Has last.fm changed something to prevent this from working?
http://www.last.fm/user/magnumforce2006
gabzibabzi
post Oct 10 2012, 09:14
Post #385
QUOTE (Fractal_Mortality @ Oct 10 2012, 01:34) *
On my pc's (vista, seven, xp) plugin always crush system now. I think it's last.fm problem with incorrect feed.
This is very sad.
Joffi
post Oct 10 2012, 19:19
Post #386
Crashed here as well upon attempt to love via foo_softplaylists. f2k crash submitted.
QUOTE (gabzibabzi @ Oct 10 2012, 04:14) *
This is very sad.
Indeed...
romor
post Oct 10 2012, 19:46
Post #387
He was using test API key wchich is now deprecated: http://www.last.fm/group/Last.fm+Web+Servi...21604/_/2188288
Here is patched version that works (with my api_key): http://goo.gl/zwKi7
I'll remove the file, when Johan resolves it
scripts: http://goo.gl/M1qVLQ
gabzibabzi
post Oct 10 2012, 20:07
Post #388
QUOTE (romor @ Oct 10 2012, 19:46) *
Big thanks for You and Johan!
I use foobar only for this great feature. It's realy help discovery new music on my hard drive.
This post has been edited by gabzibabzi: Oct 10 2012, 20:07
Fractal_Mortalit...
post Oct 10 2012, 20:17
Post #389
QUOTE (romor @ Oct 10 2012, 13:46) *
Many Thanks!
Maeldun
post Oct 21 2012, 19:39
Post #390
Had the same problem. The patched component further up apparently fixed it for me as well.
Many thanks.
hymerman
post Oct 22 2012, 09:50
Post #391
romor - how did you patch the component up? Do you have access to the source or did you literally patch up the dll? I asked Johan for the source a few times a while ago since I wanted to make some changes but didn't get a response and have now started writing a similar component from scratch, if the source is available though that would be a much better option!
romor
post Oct 22 2012, 18:55
Post #392
Just the dll
I don't have access to Johan's source files, and unfortunately it seems like you'll have to reinvent the wheel again.
I think it would be sensible and noble, if developer looses interest, to make source code public or at least available on demand. But it's not like it happens for the first time
Here is some old thread, maybe it would reveal something helpful, maybe not: http://www.hydrogenaudio.org/forums/index....st&p=519493
hymerman
post Oct 22 2012, 19:10
Post #393
Ok, I thought that might be the case - no problem. I'll carry on, and will definitely be making source available once I have something interesting.
Thanks for the link - I saw it before starting to write my new component and used it as a base but it's pretty much indistinguishable from that now!
bananaboat23
post Nov 10 2012, 09:00
Post #394
I want to create a playlist of all the artists I have on last.fm from all my music on my hard drive. Can I do that with this plugin?
JohanDeBock
post Nov 27 2012, 14:59
Post #395
I have almost no time left to work on this so I will zip the sources when I dig them out of my archive and make them available.
Would be nice that somebody puts them in an online version repository, then I can still follow up a bit.
Sorry for the late reaction.
This post has been edited by JohanDeBock: Nov 27 2012, 15:00
foo_softplaylists: http://tiny.cc/kh9m9
JohanDeBock
post Nov 27 2012, 20:52
Post #396
Have fun with it smile.gif :
https://www.dropbox.com/s/cf0p2mdpzpwfhco/f...lists-source.7z
mll
post Dec 17 2012, 13:36
Post #397
QUOTE (romor @ Oct 10 2012, 20:46) *
Thanks romor, works for me too.
And thanks Johan for making it OS.
Innomen
post Dec 30 2012, 21:49
Post #398
Recently crashing when trying to create Loved tracks listing.
"downloading last fm loved tracks feed"
Everything is updated.
Maeldun
post Jan 7 2013, 01:40
Post #399
Use the upated component file in the google link just above.
The component is currently out of active dev with it's original author - but with the sources online there is still hope for future development. smile.gif
QUOTE (Innomen @ Dec 30 2012, 22:49) *
EpicForever
post Jan 25 2013, 20:56
Post #400
How about this?
from console:
Graphic Equalizer: initialized (SSE support: 3)
Startup time : 0:00.484281
Seekbar: taking GDI path.
Seekbar: Frontend initialized.
Opening track for playback: "M:\CD-DA\Diego Hostettler\Diego – Instant Reality (KA85CD) (2003)\03 Diego – Me Fragments.flac"
Audioscrobbler: Handshake successful.
Audioscrobbler: Submitting 2 cached tracks...
Opening track for playback: "M:\CD-DA\Diego Hostettler\Diego – Instant Reality (KA85CD) (2003)\04 Diego – Sacrament.flac"
Audioscrobbler: Submission succeeded.
foo_softplaylists: feed downloading: error
foo_softplaylists: failed to love track: authentication failed: empty reply
foo_softplaylists: failed to love track 'Sacrament' by 'Diego'
I use foobar 1.2.2 with
foo_audioscrobbler.dll (2012-11-22 15:41:48 UTC)
Audioscrobbler 1.4.7
foo_softplaylists.dll (2013-01-25 19:31:19 UTC)
Soft Playlists 2012-10-10
This post has been edited by EpicForever: Jan 25 2013, 21:02
RSS Lo-Fi Version Time is now: 26th October 2014 - 02:18
