Media Player Classic 6.4.8.3 released, Great news
AtaqueEG
post Mar 7 2005, 05:42
Group: Members (Donating)
A new version of this awesome player has been released
Get it here
Changelog
Changes:
A long time has passed since the last release. There are many changes I cannot remember, but here are most of them:
- The tray icon mode bahaviour has been changed a bit. Like it or not, now there is a taskbar button when the main window is not minimized. This change was needed to make mpc appear in taskman and the alt+tab window, and because the taskbar button was not always activating together with the window (bug in windows I guess).
- The playlist remembers its items after closing and relaunching the player.
- In capture mode, presets can be added to the playlist just like files and saved into a new playlist file format created for this purpose in the first place (.mpcpl).
- Image saving to the root directory fixed.
- A few "after playback" actions (close, shutdown). It can be found under the Play menu.
- Pixel shader effects and a little editor with basic autocomplete abilities. Requirements: dx9 renderless output mode + textured 3d blending + video card with pixel shader support (v2.0+ prefered). Besides the fun it can be used as a little sandbox to experiment with shaders in real-time. The code you write gets compiled on-the-fly and applied onto the video. Disassembled code and other compiler messages can be viewed in the output window. Even if you can't program in any language, there are a few samples to get you started.
- Left alt + numpad keys can rotate the picture with certain renderers (see the Output page in the options). Useful when you need to mirror the picture for some reason, or to correct the perspectivity a bit.
- Edge-transparency bug of the subtitle renderer fixed. It occured when more shapes were painted on top of eachother.
- New capture format: dsm, in addition to the already existing avi, ogm (needs external muxer) and matroska formats.
- Online subtitle database. The player can upload, search and download subtitles for recognized movie files in a semi-automatic way. The website was designed to run at different places at the same time, accessing a common database. If you want you can host a mirror yourself, just contact me about it.
- Internal webserver can also serve external files now (please don't forget to contribute nice pages smile.gif. To extract the pages for the first time, go to the options of the webserver and use the Deploy... button. There is also a new player interface page (an MPC look-a-like!) with cool javascript supported features to update everything in real-time without reloading the page, you should arm yourself with the latest browsers though. Be warned, what you can see, others can see too! smile.gif To prevent that, there is a checkbox to allow localhost connections only.
- Internal source filters can reopen files seemlesly when their file handle becomes invalid (wifi...). This has annoyed me for a long time, you'll be pleased if you experience similar problems smile.gif The read-ahead buffer was also increased from 1 to 5 megabytes.
- Real's API changed the volume level behind MPC's back, but now it is trapped and eliminated using the detours lib (2k/xp only).
Misc changes to the main menu:
File:
- properties/details: A short summary about the currently used codecs. The details depend on how well the source filter can fill in the mediatype structure. Don't be surprised if there is not bitrate or frame-rate, it's normal.
- properties/resources: Viewer tab for embeded files inside mkv or dsm. This page is only visible when there is something to view. Save As... button can save the files onto the hard disk, while double clicking opens them in the default browser served using MPC's webserver, when enabled of course.
- utils/dsm muxer: With this you can remultiplex your favorite files/streams into dsm. It has a clean and simple interface, conversion should be easy for anyone. Just be sure to try the right mouse button everywhere to find the available options, the context menu is different for different tree item types. Tagging, chapters, attached files and of course video/audio/subtitle streams can be saved into dsm.
Options:
- output: There is "lock back-buffer before..." checkbox to fix VMR9's vsync problems. Though it might not work for everyone, or with every video card.
- subtitles: "round up to power of two". In the past this option was always on, now it can be turned off to save a little video memory bandwith at higher resolutions. Older video cards don't support it, or have problems texturing the 32bpp subpictures on 16bpp desktop.
- subtitles/def.style: "position subtitles relative to the video frame". You will notice that this checkbox have three states. It is undefined for every custom style, therefore the value you set here for the default style gets inherited by them.
Filters:
- New mp3/aac source filter. Handles vbr files much better than the mpeg-i splitter of dshow. Another improvement is how the duration becomes more accurate as more samples are played. This filter is also more error resistant to corrupted id3 tags.
- Dirac decoder was upgraded to use the 0.5.0 lib.
- Mpeg splitter can seek discontinous streams much more reliably now. It just falls back to "seek by bitrate" mode when it detects something wrong in the continuity of the timestamps. Also, it is now able to play streamed mpeg over http (for example vlc's output).
- Latest DSM splitter and muxer included.
- New decoder for ps2's mpeg audio formats: pcm, adpcm (mostly found in .pss files). Please note that such files can't be seeked by design. If you try the sound will simply mute. It's because the data can be decoded only by starting from the beginning of the file.
- Matroska splitter can seek newer mkv files and display their duration.
I'm the one in the picture, sitting on a giant cabbage in Mexico, circa 1978.
Reseņas de Rock en Espaņol: www.estadogeneral.com
music_man_mpc
post Mar 7 2005, 06:07
I think you mean 6.4.8.3
AtaqueEG
post Mar 7 2005, 09:46
Yes, indeed
Mods, please
Digga
post Mar 21 2005, 10:38
http://sourceforge.net/project/showfiles.p...ackage_id=84358
v6.4.8.4 is out.
Changes:
- remembering playlist items can be turned off in the context menu
- fixed shaders randomly disappearing from the menu
- aspect ratio presets at view/video frame/override aspect ratio (default, 4:3, 5:4, 16:9)
- ctrl held during resizing keeps the window tight around the video
capture mode:
- better compatibility with terratec cinergy and other cards which output audio themselves
- the television standard can be set indirectly by the country code at the open device dialog (there is no other way in directshow...)
- a deinterlacer filter is loaded when the height is larger than 288 lines, only for previewing (the following color formats are supported: yuy2/uyvy/yv12/i420/iyuv)
- if there is only one video format offered by the video capture pin (320x240 for example) then mpc adds several other standard resolutions to the combo box
vmr9 renderless: (changes by Haali)
- bilinear + bicubic resizers, using pixel shader 2.0 (3d mode only)
- speed issues on secondary display may be fixed now (the file has to be opened there)
webserver:
- fixed the bug of serving external files from certain paths
- cgi support (tested with php only)
- default page can be set (index.html, etc.)
Nothing but a Heartache - Since I found my Baby ;)
zilexa
post Apr 8 2005, 00:02
does anyone know what filters to deselect? heard for better audio in avi/mpg files, it is better to switch some built in filters off...
CiTay
post Apr 9 2005, 00:24
Administrator
Group: Admin
QUOTE (zilexa @ Apr 8 2005, 01:02 AM)
I only disable MPEG-1 Video decoding.
yong
post Apr 9 2005, 06:40
QUOTE (CiTay @ Apr 9 2005, 07:24 AM)
If you move the mouse cursor to "tranform filter", "mpeg1 viddeo"
tooltips will pop-up: "6.4.0.0 based on libmpeg2 (mpeg1 video decoding is bogus)" tongue.gif
Currently ffdshow(but libavcodec still broken if decoding mpeg1 video, use libmpeg2 instead) is my chioce. biggrin.gif
This post has been edited by yong: Apr 9 2005, 06:42
http://foobar2000.xrea.jp/
RSS Lo-Fi Version Time is now: 19th September 2014 - 03:31
