IPB
Which Vorbis encoder/settings to use.
Guest_Dex4now_*
post Sep 19 2003, 12:39
Post #1
Guests
Hi folks; I notice that while the mp3 and mpc forums seem to have clear cut stickies on the best current encoder/settings to use, both Ogg and AAC don't seem to have these. But on to my question . . .
Due in large part to various hardware devices I've acquired for home/auto use, I've pretty much settled in to using mp3's with Lame 3.90.3 --alt-preset standard. I haven't played with Ogg Vorbis in some time, but I'ld like to check out where the latest is at. So, what is the current Ogg encoder/decoder and settings to use if I want to compare it to the above mp3 settings?
Thanks all, Dex
Go to the top of the page
+Quote Post
indybrett
post Sep 19 2003, 12:47
Post #2
Group: Members (Donating)
Garf's GT3B1 version at -q5 would be a good place to start. That's what I use.
http://rarewares.hydrogenaudio.org/ogg.html
flac>fb2k>kernel streaming>audiophile 2496>magni>dt990 pro
+Quote Post
Guest_Dex4now_*
post Sep 19 2003, 13:07
Post #3
Guests
Thanks Indybrett, but . . . I'ld rather look like an idiot than start off wrong. There seems to be quite a few Ogg selections there. Could you be more specific about which one I should download. I noticed three different GT3B1 dll's.
Thanks for your time and effort, Dex
Edit: Ooops, I think I see it, its the one at the top! tongue.gif
This post has been edited by Dex4now: Sep 19 2003, 13:13
+Quote Post
Volcano
post Sep 19 2003, 13:46
Post #4
I'd use Oggenc2.3 GT3b1.
Set up the EAC Compression Options like this:
  • [x] Use external program for compression
  • Parameter passing scheme: User Defined Encoder
  • Use file extension: .ogg
  • (specify path to oggenc2.exe)
  • Additional command line options: -q 5 -a "%a" -t "%t" -l "%g" -d "%y" -N "%n" -G "%m" %s -o %d
  • Bit rate: Doesn't matter, you can set it to 160-192 kbps for a better file size estimation
  • [ ] Use CRC check
  • [ ] Add ID3 tag
HTH,
Dominic
+Quote Post
QuantumKnot
post Sep 19 2003, 15:28
Post #5
Group: Developer
I've edited my post in that sticky thread so it gives more information about vorbis encoders, settings, etc. Let me know if I missed out something.
http://www.hydrogenaudio.org/forums/index....t=0#entry131596
Also, does anyone know if the vorbis plugin in winamp 2.x has had that vendor tagging bug fixed? I've provided a link to version 1.3.5 of the plugin (which I'm hosting) which doesnt have the bug but that may be redundant if the newer versions of winamp 2 have the bug fix.
This post has been edited by QuantumKnot: Sep 19 2003, 15:28
+Quote Post
indybrett
post Sep 19 2003, 15:36
Post #6
Not sure about the DLL's. I suppose it depends on what program you are using to rip+encode.
I actually don't encode while ripping. I rip first, then use OggDrop to encode later.
+Quote Post
Guest_Dex4now_*
post Sep 19 2003, 19:11
Post #7
Guests
QuantumKnot: Your edit was perfect. Thats should really help folks to figure out whats what. biggrin.gif
indybrett: While I normally use AudioGrabber or EAC, when it comes to Ogg, I do what you do and encode to OggDrop. Thanks.
Dex
+Quote Post
Weird Music Mafi...
post Oct 1 2003, 23:23
Post #8
Group: Members
I'm still using Win98SE and I'm getting always 'Unicode translation error 87' - but compression nevertheless takes place and I can use the resulting files. What is going wrong?
+Quote Post
john33
post Oct 1 2003, 23:30
Post #9
xcLame and OggDropXPd Developer
Group: Developer
QUOTE (Weird Music Mafia @ Oct 1 2003, 10:23 PM)
oggenc2.3 incorporates the Unicode patch that Peter Harris produced. This is known not to work correctly on Win98SE. If it causes a problem other than an error message, let me know and I'll produce a version, tell me which one you want, with the Unicode patch removed.
John
My compiles and utilities are at http://www.rarewares.org/
+Quote Post
Peter Harris
post Oct 2 2003, 00:11
Post #10
Group: Members
QUOTE (john33 @ Oct 1 2003, 05:30 PM)
Actually, my unicode patch is a no-op on Win9x. That error message is coming from the broken pseudo-unicode code path that existed before my patch. That error is one of the reasons I created the patch in the first place.
Unfortunately Win9x doesn't really do Unicode, it just pretends to. Otherwise I would have extended the patch to do something on 9x too.
That said, feel free to try both with and without the patch if you like. If the behaviour changes on 9x, then it is a bug in my patch.
+Quote Post
john33
post Oct 2 2003, 10:42
Post #11
Group: Developer
Rather than do a fresh compile now, could you try this one: http://homepage.ntlworld.com/jfe1205/oggenc2.2.zip and tell me if you get the same error? Also, were you using wave file input, or a lossless format?
John
+Quote Post
Weird Music Mafi...
post Oct 3 2003, 00:48
Post #12
Group: Members
@ john 33
QUOTE
John, the error only occured when I tried to compress a .wav from HD with EAC's 'Compress WAV' command - and I was using Volcano's command line from above:
q 8,3 -a "%a" -t "%t" -l "%g" -d "%y" -N "%n" -G "%m" %s -o %d
Of course oggenc2 can't know anything about artists etc. when I only compress a .wav file without further information. When I will be ripping directly to .ogg from CD (o.k. EAC still uses a temporary .wav first) with that command line everything is o.k. with both compiles oggenc2.2 and oggenc2.3.
Sorry for making trouble - my fault. Since I'm just starting with ogg (I have worked only with mp3, mpc and ape before but forthlooking to firmware upgrades supporting ogg it's time know to deal with this format) the firt thing I tested yesterday was to find the quality setting appropriate for me. It's 8.3 ...
This post has been edited by Weird Music Mafia: Oct 3 2003, 00:49
+Quote Post
john33
post Oct 3 2003, 09:52
Post #13
Group: Developer
QUOTE (Weird Music Mafia @ Oct 2 2003, 11:48 PM)
So, this basically happens when using the above command line in convert, ie., when EAC doesn't have the CDDB info and, therefore, the tags are empty? If so, that's probably not worth looking at as EAC may be passing any sort of garbage.
@Peter Harris: Any view on this?
John
+Quote Post
Weird Music Mafi...
post Oct 3 2003, 16:10
Post #14
Group: Members
QUOTE
Yes, seems to happen only then - when I rip from CD directly with CDDB data (or manual input...) everything is fine.
+Quote Post
john33
post Oct 3 2003, 16:48
Post #15
Group: Developer
QUOTE (Weird Music Mafia @ Oct 3 2003, 03:10 PM)
Hmmm, I would have no idea what EAC is trying to pass, if anything, to the encoder in this situation. If you've ripped to wav and want to encode and tag, you may want to look at oggdropXPd. It has fairly extensive tagging facilities.
John
+Quote Post
Peter Harris
post Oct 3 2003, 16:57
Post #16
Group: Members
QUOTE (john33 @ Oct 3 2003, 03:52 AM)
I agree; that would be my first guess, too.
Passing parameters program-to-program isn't quite the same as typing them in on the command line. That also may have something to do with it.
Given that the files produced are fine, I'm inclined to not worry about it.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 2nd October 2014 - 05:12
