21 Pages V  « < 14 15 16 17 18 > »
Nero Releases FREE Reference Quality MPEG-4 Audio Encoder, Nero Releases Command Line MPEG-4 & 3GPP AAC Solution
adamjk
post May 12 2006, 11:21
Post #376
QUOTE (Garf @ May 12 2006, 07:37) *
QUOTE (kwanbis @ May 12 2006, 00:17) *
QUOTE (Ivan Dimkovic @ May 11 2006, 13:38) *
Currently with Foobar - but command line tagging will come very soon.
one question, maybe allready asked, why is it that it does nothing and then it suddenly finishes? would be better to see a sinning simbol, or something. or at least one:
"Working, please wait ..."
Many thanks, but where this version is available?
Garf
post May 12 2006, 15:36
Post #377
Server Admin
Group: Admin
QUOTE (adamjk @ May 12 2006, 12:21) *
Available on the next update.
This post has been edited by Garf: May 12 2006, 15:36
sven_Bent
post May 12 2006, 19:28
Post #378
QUOTE (gaekwad2 @ May 11 2006, 19:33) *
QUOTE (sven_Bent @ May 11 2006, 18:33) *
Found te bug. is has nothing to due with the encoder.
If i extract the .wav and run the commandline myself, the files playbacks perfectly.
What version of CDex did you use?
I tried 1.60 from rarewares with different bitrates but couldn't get Winamp to barf.
my version is 1.51 but my bug was caused by the ID3 tag that CDex adds to the file.
Disable the id3 tag and the files should playback perfectly.
Sven Bent - Denmark
Axon
post May 12 2006, 20:41
Post #379
Group: Members (Donating)
Super high level question:
Is there a set of test results to compare this encoder against LAME, in particular at high bitrates? Can we safely use the last published set of results for Nero's encoder?
Garf
post May 12 2006, 20:56
Post #380
Server Admin
Group: Admin
QUOTE (Axon @ May 12 2006, 21:41) *
It has had several important bugfixes as well as quality improvements[1] since then. I know we always say this but it's true! smile.gif
[1] <nitpick>TOS 8 violation!</nitpick>
Daijoubu
post May 12 2006, 23:01
Post #381
On a P3 933Mhz, the nero encoder acheived 5.4x (36 secs) while CT+dimzon CLI (25 secs) one encoded at 7.8x (timed with a stop watch...)
3:16 song, CBR 64kbps HE-AAC
Gonna try with a longer track on my A64 3200+ (SSE2) later
manuelator
post May 13 2006, 03:49
Post #382
If you want to reconvert yo aac (or m4a or mp4) audio to wav mono use ffmpeg with the aac codec and do:
ffmpeg.exe -i 2.mp4 -ac 1 test.wav biggrin.gif easy
jevinsweval
post May 13 2006, 22:45
Post #383
How do we add album art?
[url=http://www.jevinskie.com]jevinskie.com[/url]
Sofronis
post May 14 2006, 02:16
Post #384
I found an interesting sample (it’s an artificial sound of a vehicle) taken from the Star Wars Episode III movie. I was able to ABX it all the way up to Q 1 (~420kbps) using some cheap Philips speakers (didn’t have my headphones around). The problem is located in the left channel, at the beginning of the track (0 - 0.4 sec), where there is some sort of distortion on those high frequency (~12khz) short “clicks”. If you find it hard to ABX, try a lower quality setting (for example Q 0.4) which will accentuate the problem, making it easier to spot.
You can find the 48khz stereo track which I used for the encodings (downmixed from a 5.1 channel, ac3 track) here.
foo_abx 1.3 report
foobar2000 v0.9.1
2006/05/14 03:15:21
File A: E:\New Folder\audio test\q 1.mp4
File B: E:\New Folder\audio test\Utapau_chase.wv
03:15:21 : Test started.
03:16:58 : 01/01  50.0%
03:18:02 : 02/02  25.0%
03:19:35 : 03/03  12.5%
03:21:47 : 04/04  6.3%
03:23:13 : 05/05  3.1%
03:26:13 : 06/06  1.6%
03:28:58 : 06/07  6.3%
03:30:17 : 07/08  3.5%
03:32:13 : 08/09  2.0%
03:37:31 : 09/10  1.1%
03:42:17 : 10/11  0.6%
03:48:36 : 11/12  0.3%
03:51:36 : 12/13  0.2%
03:53:02 : 13/14  0.1%
03:55:17 : 14/15  0.0%
03:55:22 : Test finished.
Total: 14/15 (0.0%)
Let us so live that when we come to die even the undertaker will be sorry. -Mark Twain
torok
post May 14 2006, 02:38
Post #385
QUOTE (Sofronis @ May 13 2006, 18:16) *
foo_abx 1.3 report
foobar2000 v0.9.1
2006/05/14 03:15:21
Total: 14/15 (0.0%)
Would the fact that it's coming from AC3 be an issue?
http://www.pkulak.com
auldyin
post May 16 2006, 10:43
Post #386
I am about to try using Foobar 0.9.1 to transcode some wv files to m4a using the new Nero codec. Trouble is I have no idea about command line stuff.
Can any of you chaps tell me the command line for Foobar to transcde my wv files to ~ 128 m4a files.
Sorry to be a bof (boring old fart)
Cheers
Garf
post May 16 2006, 10:45
Post #387
Server Admin
Group: Admin
QUOTE (auldyin @ May 16 2006, 11:43) *
Cheers
http://www.hydrogenaudio.org/forums/index....showtopic=44310
This post has been edited by Garf: May 16 2006, 10:46
auldyin
post May 16 2006, 11:46
Post #388
Thanks Garf.
I saw that
-ignorelength -q 0.5 -if - -of %d
but didn't know what this bit meant
-if - -of
In my ignorance I thought that "something" had to be placed between the "if" and the "of"
Cheers
Garf
post May 16 2006, 12:06
Post #389
Server Admin
Group: Admin
QUOTE (auldyin @ May 16 2006, 12:46) *
Thanks Garf.
I saw that
-if - -of
Cheers
if = input file
of = output file
you'll notice there's an "-" inbetween, which means "standard input". This system avoids writing a temporary file and is supported by foobar2000.
So, it means, take input from standard input, output to %d (filled in by fb2k)
This post has been edited by Garf: May 16 2006, 12:06
auldyin
post May 16 2006, 13:54
Post #390
Cheers Garf!!
euphonic
post May 16 2006, 16:08
Post #391
Just a little suggestion, to have minimum OS requirements listed on http://www.nero.com/nerodigital/eng/Nero_Digital_Audio.html
Specifically, so that folks like myself and others earlier in the thread who likewise downloaded the programme will know a unicode-capable OS is required. Looking at http://www.nero.com/nerodigital/eng/Nero_D...quirements.html gives a misleading impression.
Cheers.
towolf
post May 23 2006, 13:06
Post #392
QUOTE (Garf @ May 5 2006, 01:28) *
QUOTE (emtee @ May 5 2006, 01:16 AM) *
Sounds really promising, wish I could give it a try. How long till the UNIX version? Can you elaborate on that?
Thanks a lot for the generous offer.
Either
1 Nero Month.
or
Just wondering, compared to the moon-related one, is the Nero Month longer or shorter?
Or are we even in the second conditional already?
LaserSokrates
post May 23 2006, 15:18
Post #393
I think that "1 Nero Month" and "When it's done" is pretty much the same, at least for the customer.
torok
post May 24 2006, 16:58
Post #394
I was wondering if a dev could take a look at a tagging problem that I've been having:
http://www.hydrogenaudio.org/forums/index....showtopic=44454
Basicaly, if I take a Nero-encoded file and tag it with AtomicParsley Foobar can't read it, but if I encode the same wav with iTunes then tag with AP, all is well.
Of course, if tagging gets bundled into the executable, this problem goes away and I won't have to try to rely on programs that try to "douche" foobar2000 tags. biggrin.gif
Ivan Dimkovic
post May 24 2006, 17:00
Post #395
Nero MPEG4 developer
We will issue a new update in the few days, which will among other things also include a command line tagger.
alfa156
post May 24 2006, 17:09
Post #396
sorry for the perhaps lame question but is there a free frontend we could use?
kwanbis
post May 24 2006, 17:35
Post #397
Group: Developer (Donating)
QUOTE (alfa156 @ May 24 2006, 16:09) *
MAREO: http://www.webearce.com.ar
jarsonic
post May 24 2006, 18:03
Post #398
dbPowerAmp, Foobar2000, and apparently one is in development over at doom9.org. Look upward in this thread for more info.
This post has been edited by jarsonic: May 24 2006, 18:12
Maurits
post May 25 2006, 13:02
Post #399
QUOTE (Ivan Dimkovic @ May 24 2006, 17:00) *
Will this solve all the 'non-compliant tagging' disputes that several developers in the AAC/M4A world seem to blame eachother for?
This post has been edited by Maurits: May 25 2006, 13:06
wylistener
post May 25 2006, 13:24
Post #400
QUOTE (Ivan Dimkovic @ May 24 2006, 11:00) *
Will that commandline tagger enable the single mp4 feature such as CUE sheet, album art, etc? The feature stated in the first post of this thread is:
"* Store Entire Audio Album in a Single .mp4 File with all the Features of an Audio CD embedded inside, but at a fraction of the space!"
RSS Lo-Fi Version Time is now: 22nd October 2014 - 04:56
