14 Pages V  « < 4 5 6 7 8 > »
BASSMIDI MIDI synthesiser for Windows XP/Vista/7, A new SoundFont based MIDI synth for Win7/Vista/XP
raygrote
post Feb 8 2012, 21:01
Post #126
Hi DB1989,
My sincere apologies!
I didn't see you murged it. I will be much more careful next time. I posted that last message in a hurry this morning.
Mudlord, I don't know exactly what you mean by Run regsvr /u bassmididrv.dll on the driver dll. Since I'm visually impaired I can't see the image you posted. what steps should I take to get to it?
The rest looks pretty easy.
db1989
post Feb 8 2012, 21:23
Post #127
It’s no problem! It was a lot of writing to do again; I bet you now wish that you’d spared your fingers all that extra work. biggrin.gif
Whilst I can’t presume to speak for mudlord, I’ll try to help.
First, you can run the suggested command by clicking the Start button and selecting Run (or use the shortcut: hold the Windows key and press R) and then typing “regsvr /u bassmididrv.dll” and clicking OK/pressing Enter.
Next, his image: It’s a screenshot of Registry Editor, viewing this registry entry:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\Windows NT\CurrentVersion\Drivers32
Do another Run command, but this time with the text “regedit”. Next, use the newly opened program to navigate to said registry key, and follow mudlord’s instruction of deleting any values therein that mention bassmididrv.dll. Next, use a Windows file search to find any instances of said DLL, and delete them. Finally, restart.
raygrote
post Feb 9 2012, 00:11
Post #128
Those instructions were exactly what I needed. However several more problems presented themselves.
First, I am using XP SP3 here. I will have to upgrade soon. Anyway, that may be helpful when I explain the following things.
when I went to the run dialog and typed that command, Windows said it couldn't find regsvr. So, I downloaded a program called regsvr32 from the microsoft support center. I ran that command through it, and it said that unregistration of bassmididrv.dll succeeded.
The only bassmididrv.dll file I have is in the system32 folder. That's probably expected. I cannot delete it because when I
do, it brings up the typical file is already in use message. I'm guessing then that the registry thing didn't work out. But, I haven't restarted yet, I just ran regsvr then tried to delete the file. Maybe a restart is in order? I got the impression that I should delete the file first before the restart though.
There are a few references to bassmididrv.dll in my registry as well. Most of them are in folders I never heard of, nothing like the directory in your post. If anyone wants a list I can try to make one, but I haven't even counted them yet. Then again a registry was meant to have folders nobody knows about. ohmy.gif I'm thinking it would be safe to delete those references but I haven't touched them yet.
I'm not in familiar territory here. Any further advice?
mudlord
post Feb 9 2012, 00:23
Post #129
Group: Developer (Donating)
Maybe delete the registry keys in the Drivers32 repository ONLY and unregister the DLL, then restart? Then delete the dll?
kode54
post Feb 9 2012, 02:31
Post #130
Group: Admin
The exact command is regsvr32. And you may need to supply the full path to bassmididrv.dll, which is in C:\windows\system32. And since you are using a 32-bit operating system, the registry path does not include the Wow6432Node part.
raygrote
post Feb 9 2012, 12:03
Post #131
Hi all,
Mudlord, the suggestion was very helpful. I counted three Bassmidi references to get rid of. Then I restarted and the DLL went without a problem. I deleted the whole bassmididrv folder while I was at it.
Code54, I figured those little differences out with a tiny bit of research, and by accident. Thanks for clearing that up, as I wasn't so sure.
So Bassmidi 1.06 is working flawlessly on here now, and it is only showing up once. Things are good.
Even though I am still using an older version,I am very much looking forward to see what comes next. Hopefully this issue won't be one of those things. AT least I know what to do if I forget to uninstall the old version. smile.gif
mudlord
post Feb 12 2012, 06:09
Post #132
I thought we already added functionality to detect versions already installed to the installer, so if you run a newer installer, it will uninstall the old. ohmy.gif
EDIT: yes, current SVN does so o.o
This post has been edited by mudlord: Feb 12 2012, 13:39
mudlord
post Feb 13 2012, 14:30
Post #133
QUOTE (raygrote @ Feb 9 2012, 05:03) *
mainly spent time trying to fix some last standing latency/stuttering issues in the winmm code base.
mudlord
post Feb 27 2012, 00:27
Post #134
I would like to know of any games that have issues with the current driver.
mudlord
post Feb 27 2012, 09:42
Post #135
there, 3.0 out. major changes on the winmm driver.
ex-driver
post Mar 2 2012, 04:17
Post #136
Still crashes on Winamp and Games like Final Fantasy 7. I installed the 2.01 again....
http://giantsoundfont.npage.de/
ex-driver
post Mar 2 2012, 04:20
Post #137
The Problem exist since the 2.02 Version.
mudlord
post Mar 2 2012, 05:39
Post #138
weird, I tried winamp the other day and it worked.
what OS?
ex-driver
post Mar 2 2012, 12:37
Post #139
Windows 7 Professional 64 bit
revangel
post Mar 2 2012, 17:28
Post #140
If you want a absolutely great experience listening to old Game Midis, search for the 055.1mg sound canvas v1.0 bank.sf2 soundfont. Its absolutely worth it, I never experienced Midis so close to the hardware-level with BASSMIDI and that soundfont. Link is http://www.sf2midi.com/soundfonts/file-det...nk-sf2-200.html
ex-driver
post Mar 2 2012, 22:59
Post #141
There must be a reason for this problem. All Versions before wokrs fine. After 2.02 it began...
mudlord
post Mar 3 2012, 02:04
Post #142
Try downloading again, it has a fix for BASS init.
This post has been edited by mudlord: Mar 5 2012, 23:13
ex-driver
post Mar 3 2012, 12:51
Post #143
No crashes in FF7 or Winamp and your latest driver fixed also the missing Midi track bugs on FF7 ( 2nd drumkit channel )
Good Job !! wink.gif Now I can testing your latest driver with no interruption wink.gif
Great THX !!
mudlord
post Mar 4 2012, 02:21
Post #144
hooray >_>
ex-driver
post Mar 7 2012, 13:45
Post #145
One bug I noticed. It was fixed with v2.0 and occurs again in v3.0
-fixed a GS rhythm channel allocation bug.
On Winamp testet:
(XM Play works right with this MIDIS)
with GS MIDIs with 2 drumkit channels
Bank MSB 127
for example:
Device 095 / 127 (sweep pad) v2.0
Device 095 / 127 (drumkit) v3.0
mudlord
post Mar 7 2012, 13:48
Post #146
will refer to kode54 to fix up that.
kode54
post Mar 8 2012, 01:27
Post #147
Group: Admin
That was fixed in what was originally the newer DirectMusic based driver, but never applied towards the original driver. An update has been pushed, I'll wait on mudlord to take care of uploading a new installer.
mudlord
post Mar 8 2012, 02:11
Post #148
and done..redownload from same link.
ex-driver
post Mar 8 2012, 02:37
Post #149
ex-driver
post Mar 8 2012, 03:56
Post #150
I tested the game Final Fantasy VII where I noticed this bug. A sound problem during normal sound and BassMIDI driver during the game. After 3 trys starting the game one of them works a bit.
Here is a mp3 (packed in rar) file where you can hear this strange problem. Only noticed in this game. It works fine with the v2.01 BassMIDI driver with drumkit 2nd channel missing bug which is fixed in V3.0.
The mp3 file contains: game start> loading a save file > battle and ending > close the game.
http://www.file-upload.net/download-417289...er-3.0.rar.html
I hope you got any idea what it could be.
RSS Lo-Fi Version Time is now: 18th September 2014 - 16:28
