2 Pages V   1 2 >
Is compression used in CDs?
plazz
post Jul 10 2002, 18:48
Is any kind of compression at all used in audio CD's? I know that there is on DVD's, just at a huge bitrate.
rjamorim
post Jul 10 2002, 18:50
Rarewares admin
Nope. Plain old RAW PCM.
http://www.rarewares.org
Speek
post Jul 10 2002, 19:47
Yes, there are only 44100 samples per second (per channel) on a CD. Uncompressed music has an unlimited amount of samples. But this is a somewhat unusual view smile.gif
bryant
post Jul 10 2002, 20:05
WavPack Developer
Group: Developer (Donating)
And the data is also truncated to 16 bits, which is yet another form of compression. No wonder CDs sound so bad! :mad:
But, by convention, linear PCM at any bit depth or sample rate is considered "uncompressed".
rjamorim
post Jul 10 2002, 20:09
Rarewares admin
WHA?
Are you meaning my beloved Floyd CDs sound bad?
fewtch
post Jul 10 2002, 20:22
Originally posted by rjamorim
WHA?
Bring back dynamic range... www.loudnessrace.net
The Belgain
post Jul 10 2002, 20:27
Can anyone tell the difference between 16bit 44.1 kHz music and stuff sampled at a higher frequency or bitdepth (such as DVD-Audio, SACD, etc...)?
Was 44.1 kHz chosen randomly as a result of the amount of data that could be put on a CD and the play length they were looking for or is it chosen to bear some kind of relation to the upper frequency limit of human hearing?
rjamorim
post Jul 10 2002, 20:41
Rarewares admin
I would believe that, when Sony and Philips engineers developed the CD standard, they looked for settings that sound good for almost everyone: 44.100Hz, 16bit, stereo.
Some people, like Filburt, and some bats might be able to hear differences. 99+% of the humanity won't.
Pio2001
post Jul 10 2002, 21:05
Moderator
It's a bit like the sound of CDR : there is the same data in them, but some crappy CD Players can make some sound different.
Some crappy converters don't sound as good at 44.1 kHz 16 bits than at 96 kHz 24 bits, while (unless you play your records at @ 120 db) there is no more audible info in the 96 kHz 24 bits data.
bryant
post Jul 10 2002, 21:29
WavPack Developer
Roberto, you can say anything you like about my cat, but unless you can reliably ABX her with a reference cat then it doesn’t mean anything! biggrin.gif
The 16/44 standard is basically the minimum required to provide transparent audio reproduction based on generally accepted models of human hearing. And, I believe, it has been shown that people are unable to reliably differentiate between an original analog signal and its 16/44 reproduction, just like it has been shown that they cannot hear differences between well designed amplifiers or CD players or audio cables.
But, I believe that it is more complex than that and that there may very well be advantages to higher resolution reproduction (or less “compression”). Here’s an interesting article to start with:
http://www.cco.caltech.edu/~boyk/spectra/spectra.htm
BTW, much of this was discussed at length in this thread:
http://www.hydrogenaudio.org/forums/showth...=&threadid=2165
Frank Klemm
post Jul 10 2002, 21:38
MPC Developer
The first compression stage is called "microphone". A 3D longitudinal
field is reduced to 1...5 scalars. For typical rooms and frequencies
this is a compression by 1 : 10^7.
-- Frank Klemm
plazz
post Jul 10 2002, 22:12
Sony and Philips developed the CD, but the "blueprint" for encoding audio digitally at 44.1KHz was developed in the 1920's or 30's, by a guy who died a few months ago. Can anyone remember his name? I remember the newspapers crediting him as one of the founders of the "digital revolution".
[JAZ]
post Jul 10 2002, 22:38
Man! at that time things were analog! not digital (even the "wannabe computers".)
The reason of the 44100Hz , as I've read somewhere, is due to the VHS. They chosed a rate that could contain the "usual" human hearing ( 20hz-20Khz), and that it was a multiple of .... something about the VHS... can't remember.. but it is related to that.
There was already the intention of leaving some extra margin, to avoid the nyquist frequency problem, and it is the reason of why CD are said to have a lowpass filter at 20Khz (or that they should).
Frank Klemm
post Jul 10 2002, 22:39
MPC Developer
Refutable.
The 44.1 kHz can't be discussed in 1920's or 30's.
This would violate the principle of causality.
(44.1 kHz is TV norm based which were introduced in the 40's and 50's).
Claiming something without any proves seems to be standard in the common time.
-- Frank Klemm
smg
post Jul 10 2002, 22:41
Post #15
Originally posted by Frank Klemm
Refutable.
Amen
bryant
post Jul 10 2002, 22:47
Post #16
WavPack Developer
The only person I can think of would be Harry Nyquist. His work in the 20's was originally related to telegraph signals but became the basis of modern sampling theory. But I think he died many years ago. For someone to do work in the 20's and die now, they would have to have lived to 100.
plazz
post Jul 11 2002, 00:02
Post #17
I stand corrected. I has thinking of Alec H. Reeves, who invented pulse-code modulation (PCM) in 1937. The first use of PCM wasn't until 1962.
Frank Klemm
post Jul 11 2002, 01:44
Post #18
MPC Developer
U.S. TV is 60 Hz field. Europe is 50 Hz. Least common multiple is
300 Hz. A PCM -> Video converter should work with a multiple of
300 Hz if this device should work with all video recorders.
20 kHz was a common agreement about the upper limit of human hearing
in the late 60's. Before you often find 16 kHz (octavitis: 32, 63, 125,
250, 500, 1k, 2k, 4k, 8k, 16k). A common agreement of this time also was
the +10% (people like numbers starting with 1 followed by only zeros).
20 kHz * 2 * ( 1 + 10% ) = 44 kHz
Next frequency divisible by 300 Hz is 44100 Hz.
This is the right frequency for NTSC free systems. For NTSC systems
the field frequency was adjusted by ca. 0.1% to 59.994... Hz in the
50's to better interleave audio carrier, video carrier and line frequency
to reduce color-in-audio.
So NTSC recodings actually have 44055.9... Hz.
Multiples of these base frequencies you can also find in every Pentium 4-PC
(Timer 0 base clock, because first PCs used CPU clock for color
carrier generation for PC-on-TV usage).
When field frequency in Europe would be 48 Hz (best fit with cinema), the
CD sample frequency would never be 44100 Hz, but may be 44160 Hz.
Field frequency of TV in Europe was fixed in the late 40's.
48 kHz is also a multiple of 300 Hz, but you need 320 lines for 50 Hz
and 267 lines for 60 Hz. But PAL has only 312 lines and NTSC only 262
and lines during the sync pulse are often damaged.
For 48 kHz sample frequency TV has to few scan lines ... ;-)
CD used the common usage sample frequency introduced in the late 70's
by PCM machines. At this time there were a lot of other frequencies from
32 kHz...54 kHz.
-- Frank Klemm
SometimesWarrior
post Jul 11 2002, 02:57
Post #19
Thank you for the history lesson, Mr. Klemm!
It's funny how many technological conventions today are so related to each other. It just emphasizes the importance of getting it right the first time, because you may never get another chance to fix it!
gdougherty
post Jul 11 2002, 04:46
Post #20
First, on topic comment. *Some* CD's do use compression, but they're not really considered CD's even though they use CD in their name. DTS CD's use DTS compression and are recorded on CD media. Standard CD's that conform to Red Book and are playable on any CD player do not use any compression.
Now, the off-topic reply to Bryant's comment.
Due to the distortion inherent in any PCM sampled audio, 44.1Khz requires a low pass filter, which, if poorly designed and implemented, does have an effect on the audio. 96, or 88.2Khz sampling rates move these distortions way up into the inaudible range and negate the need for a low pass filter. Arguably a very well designed 44.1 DAC would sound as good as any decent 96Khz DAC unless you're one of the extremely rare people who can hear above 20Khz.
Bit depth shouldn't make any real difference except in edit calculations. 24bit over 16bit just gives you more headroom before the signal clips, so a proper 16-bit recording is capable of having just as much audible dynamic range. Most equipment (both recording and playback) has enough inherent noise that the dynamic range issue is truly moot. The public expects music to be squashed down these days anyways, and 14dB of average dynamic range is considered to be a good amount of dynamics that far exceeds the average of any modern pop or rock album. Classical and Jazz are the real bastions of dynamic range and even there 16-bit as a playback medium is very adequate.
Contrary to your statement there isn't any inherent bit truncation that occurs with 16-bit files. Music properly recorded at 16-bit and never digitally amplified past the zero mark of 16-bit would never be truncated as I understand things. Generally 24-bit resampled down to 16-bit using a very good algorithm doesn't necessarily truncate the signal and toss out the dynamic range in the 24-bit sample. Anything in the dynamics that would be tossed are likely inaudible unless you've got things up so loud that the louder sections would make your ears bleed (ie, it drops the bottom, not the top of the signal).
Listening tests have shown that good digital equipment is on par with analog while also having better s/n ratios. Crappy analog often "fails" more gracefully than digital, which is the major difference. Really, digital or analog, good equipment sounds good, bad equipment sounds bad. IMO, most of the people who ooh and aah over analog are generally hearing what they want to hear or simply prefer the distortions, compression and "warm" inaccuracies often added by analog equipment.
G
JonPike
post Jul 11 2002, 04:55
Post #21
Actually, in an indirect sense, the answer may be yes.
I don't know the details, but I have heard a lot of talk that for the anti-skip feature in portable CD player, you have a memory buffer, AND audio compression. For a reasonalble amount of anti-skip time, you need either a expensively large amount of memory, or you can do compression on the data, making your smaller ram buffer "bigger", and not spend as much... therby more profit for you and/or cheaper players for your customers. If this is true, it would seem the compression isn't the best in the world.. (Hmmm.. developers, need to port Lame or MPC to those little micro's the CD's use! If they have the grunt to handle it, that is!)
I'd like to hear about this from someone who knows.. many audiophile types say that anti-skip degrades the sound.. and you want a player that either dosen't have it or truly bypasses it when turned off. I think I might believe them, on my player with my KSC-35's on.. I think I notice a loss of dynamic range, slightly muddy highs, etc..
But my CD software can't run ABX...
Jon
godzilla525
post Jul 11 2002, 06:30
Post #22
I have a portable CD player that has anti-skip memory in it (Panasonic SL-291C). Just for fun I played a 20-20kHz sine sweep through it. With anti-skip turned off, the sweep played fine. When I turned anti-skip on, the disc spindle speed went up to 2x, and pretty much anything above 10kHz in the sweep was trashed--a lot of strange beeping, an increase in background hiss in some places...
I'd say just to leave anti-skip off unless you really need it.
I will say this, though: This player seems to do incredibly well with quasi 20-bit recordings when using headphones (anti-skip OFF).
Speaking of which, quasi 20-bit is a method of CD-audio compression that uses dithering to make standard PCM 16-bit audio 'sound' more like 20-bit (expands dynamic range), though it injects a small amount of noise into the signal.
godzilla525
bryant
post Jul 11 2002, 06:45
Post #23
WavPack Developer
My statement, like Speek’s, was meant half in jest. People consider the word “uncompressed” to mean that all the original information is available, when actually an enormous amount is discarded when converting from analog to digital and, as Frank points out, there’s an enormous amount discarded even before that when converting from the 3D sound field to a simple microphone feed. If I convert 16/44 LPCM to 8/22 LPCM nobody would call it “compression”, but obviously it is a form of [particularly] lossy compression.
I agree that music originally recorded in 16-bits would not be explicitly truncated, but a 16-bit ADC has an implicit truncation. And when 24-bit data is compressed to 16-bit, the final step is truncation, even if there are noise shaping and dithering operations performed first to lessen the audible impact.
JonPike
post Jul 11 2002, 07:02
Post #24
Good test.. I'll have to burn a sweep CD, and spectum analyze the playback on mine..
And, you probably could hear enough artifacts and errors, by just listening, to make it worth bringing one to a store to test players you're considering buying.
Hmmm... wonder if I could use the Creative Labs "what you hear" recording input to get wav files of RightMark's test tones on a CD?? Then play back the output when the program is listening, and fool it into thinking I'm looping back while playing the CD player? Hmmm... (probably "testing" too many things)
Jon
godzilla525
post Jul 11 2002, 07:57
Post #25
RightMark's test tones are way too short. They don't even use a sweep, but more of a weird buzz. It would also be tricky to get it timed just right.
I wish I knew of any open-source or free software tools for making sine sweeps and such. Hopefully someone else does. ???
godzilla525
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 27th November 2014 - 03:47
