81 Pages V  « < 71 72 73 74 75 > »
foo_upnp, UPnP/DLNA client and server (previously foo_upnp_mediaserver)
RYoda
post Oct 8 2013, 13:04
Post #1801
At first I want to say thank you for this great foobar plugin.
I use this for stereo and for multichannel tracks and all tracks are playing without problems on an Oppo BDP-93.
With one exception.
If I choose 'Playback Stream Capture' (PSC) I can't stream multichannel tracks (5.1 Ch Flac) because the plugin always tries to send stereo tracks. Chooosing the same track within the 'media library' streams without problems.
But for me it's more simple to choose the tracks within foobar and not via the Oppo GUI. Because of this I like to choose PSC.
Is it correct to say that the PSC is designed as a 2-channel stream or is there somewhere a switch which I have not recognized ?
Any ideas of what I can do to solve this problem?
Update : When reading this thread more in detail I found out that other users have the same problem.
So I think it is made by design.
Is there any chance that a future version will accept 5.1 tracks with the Playback Stream Capture ?
RYoda
This post has been edited by RYoda: Oct 8 2013, 13:25
noxx
post Oct 31 2013, 18:05
Post #1802
hi
i need a download link. the link on the foobar page dont work
regard
eahm
post Oct 31 2013, 18:07
Post #1803
QUOTE (noxx @ Oct 31 2013, 10:05) *
hi
regard
It works here.
noxx
post Oct 31 2013, 19:26
Post #1804
Now it works, THX.
A question. Is it possible to run foobar as Windows service?
alainbryden
post Nov 13 2013, 18:00
Post #1805
Is this on github? I wouldn't mind making a pull request to try and fix a few bugs that are really getting under my skin, like how it hangs then crashes foobar every time there's a hiccup in your internet connection while streaming.
This post has been edited by alainbryden: Nov 13 2013, 18:00
Jan S.
post Nov 13 2013, 18:01
Post #1806
It seems 5.1 files fail if you try to transcode to mp3:
Could not read info (Unsupported format or corrupted file) from:
Source:
Sample rate : 48000 Hz
Channels : 5: FL FR FC BL BR
Bits per sample : 24
Bitrate : 3164 kbps
Codec : FLAC
Using "Convert 5.1 to stereo" doesn't change anything.
If I try to use "Convert 5.1 to stereo" without transcoding I get a wav file that plays but it is 5 channels... So it seems the "Convert 5.1 to stereo" DSP doesn't really do anything... Or am I doing something wrong?
My poor internet connection here cannot keep up with the 3164 kbps bitrate sad.gif
Jan S.
post Nov 14 2013, 11:54
Post #1807
Another thing. Enabling "Convert 5.1 to stereo" forces transcoding to mp3 or decoding to wav. Would it be possible to only force this when the DSP actually does something? That is if it is stereo and only "Convert 5.1 to stereo" is enabled then supply the original file.
bubbleguuum
post Nov 14 2013, 14:32
Post #1808
QUOTE (Jan S. @ Nov 13 2013, 19:01) *
Source:
Bitrate : 3164 kbps
Codec : FLAC
I briefly tested streaming a 88.1/24 multichannel FLAC transcoded to 320K mp3 and it worked.
Make sure you have modified the foobar2000 streaming profile mp3 section with
- "transcode" set to "never"
- "except" set to empty string
- "lossless and" checked
- "internet" checked
This will only transcode lossless to mp3 when streaming over the Internet (uncheck "internet" if you want to test transcoding on the LAN)
Transcoding to mp3 forces stereo so there is no need to use DSPs.
This post has been edited by bubbleguuum: Nov 14 2013, 14:35
bubbleguuum
post Nov 14 2013, 14:34
Post #1809
QUOTE (Jan S. @ Nov 14 2013, 12:54) *
Not possible as it is not possible for the plugin to know in advance how a DSP chain is going to modify channel count, samplerate etc.
So PCM (WAV or LPCM) is always forced when there is a DSP chain associated to a profile.
bubbleguuum
post Nov 14 2013, 14:36
Post #1810
QUOTE (alainbryden @ Nov 13 2013, 19:00) *
It is not open source thus not github.
Jan S.
post Nov 14 2013, 15:45
Post #1811
QUOTE (bubbleguuum @ Nov 14 2013, 14:32) *
Source:
Bitrate : 3164 kbps
Codec : FLAC
That is what I tried.
I get
Could not read info (Unsupported format or corrupted file) from: "XXXXXXXXXXX.mp3?profile_id=1&convert=mp3"
Unable to open item for playback (Unsupported format or corrupted file):
"http://XXXXXXXXXXXX.mp3?profile_id=1&convert=mp3"
Can I supply you with a sample file? Or how should I proceed to find the problem?
QUOTE (bubbleguuum @ Nov 14 2013, 14:34) *
May I suggest a transcoding exception then: "multichannel" or similar. Since I guess often if you stream you are using a limited device and not a full surround environment anyway.
bubbleguuum
post Nov 14 2013, 17:21
Post #1812
QUOTE (Jan S. @ Nov 14 2013, 16:45) *
Yes, send me a link (bubbleguuum@free.fr) where I can download your FLAC.
Can you explain your exact use case (expected behaviour, streaming to what device, on which network connection, ...) ?
On the LAN, even if stereo files are streamed as PCM even if not necessary, this doesn't have an impact on SQ. It just uses a bit more bandwidth.
This post has been edited by bubbleguuum: Nov 14 2013, 17:22
Jan S.
post Nov 14 2013, 17:50
Post #1813
Link is in your mail.
QUOTE (bubbleguuum @ Nov 14 2013, 17:21) *
Right now I am streaming to foobar on another computer or through bubbleUPNP to a tablet. All through internet ATM.
I would like to stream directly if possible. Mainly to preserve tags. Of course saving precious BW is a bonus.
Only problem with this setup is multi-channel files where my BW is too low to stream. So to get tags to pass through when at all possible I would like a way to only transcode if it is needed due to BW considerations basically.
Another idea would be to transcode based on a maximum bitrate.
bubbleguuum
post Nov 14 2013, 18:33
Post #1814
QUOTE (Jan S. @ Nov 14 2013, 18:50) *
Thanks, could reproduce the problem.
To transcode to mp3, foo_upnp must first generate a stereo PCM stream (using foobar2000 decoding APIs) that is fed to libmp3lame.
In that scenario, it knows how to convert mono to stereo or 5.1 to stereo (using internally the "convert mono to stereo" and "convert 5.1 to stereo" DSPs),
but not any other channel count to stereo. Since your FLAC is 5 channels, it cannot convert it to stereo and fails (when console logging is enabled on the server, there's a mention of the failure). I tested with a 5.1 FLAC and that's why it worked.
This can be made to work adding the "Channel mixer" DSP in the profile to force prior conversion to stereo, but then it will force PCM on all tracks, probably not what you want from your previous messages.
short version: transcoding to mp3 is only compatible with mono, stereo and 5.1 files unless using "Channel mixer" and its side effects (more bandwidth) are acceptable.
It can probably be fixed but I have to think more about how. Probably without relying on DSPs for converting to stereo.
Ok thanks for the details. No promise but I'll think on what can be done (which is also linked to problem above).
This post has been edited by bubbleguuum: Nov 14 2013, 18:35
BenB
post Nov 14 2013, 19:10
Post #1815
QUOTE (bubbleguuum @ Nov 14 2013, 12:33) *
As of 1.2.7, the "Convert 5.1 to stereo" DSP was replaced with the "Downmix channels to stereo" DSP which supports more channel configurations, although I don't know exactly which additional configurations that support includes (yet).
bubbleguuum
post Nov 14 2013, 19:22
Post #1816
QUOTE (BenB @ Nov 14 2013, 20:10) *
Thanks, this is the thing I need.
Jan S.
post Nov 14 2013, 21:52
Post #1817
I can confirm that v1.2.9 works when adding "Downmix channels to stereo" as DSP.
Wouldn't it do what I need if the "stereo only" restriction in the renderer capabilities used the new DSP?
bubbleguuum
post Nov 15 2013, 12:56
Post #1818
QUOTE (RYoda @ Oct 8 2013, 14:04) *
No, as the PSC channel count must be constant as long as it is streaming to the target renderer.
Since most audio is stereo, it is forced to stereo.
If I added the ability to make it 5.1 (which I will not do), then all audio would have to be converted to 5.1.
bubbleguuum
post Nov 15 2013, 13:09
Post #1819
QUOTE (Jan S. @ Nov 14 2013, 22:52) *
I have uploaded v0.99.47 on the components site.
It now uses the "Downmix channels to stereo" DSP internally when transcoding to mp3, which means all channel counts are supported.
So you do not need to add this DSP manually and some files are not forced to PCM due to the presence of the DSP chain.
Also in this new version:
- transmit composer and year in album containers (both are displayed in BubbleUPnP in album lists, in Large mode)
No, this setting is only used when there is no transcoding to mp3 (which is always stereo).
This post has been edited by bubbleguuum: Nov 15 2013, 13:11
Jan S.
post Nov 15 2013, 13:43
Post #1820
With the new version I get:
Failed to load DLL: foo_upnp..dll
Running foobar v1.3 b5
fuffi
post Nov 15 2013, 13:53
Post #1821
foobar 1.3b5, windows7, ntfs
Hi, I get the above message too...
I updated today within foobar after checking for updatable components.
After restarting foobar,
I now have two folders in my foobar's user-components path, named
"foo_upnp"
and
"foo_upnp."
When foobar starts, i get the message:
I cannot delete/rename the "foo_upnp." folder. (also not after a Reboot) also, I cannot go into the folder. So the "broken" component is hidden inside this folder, which I cannot delete/move, so foobar always gives the error-message at start.
For testing
I downloaded the "foo_upnp.fb2k-component" from the website and it contains a file "foo_upnp..dll"
maybe thats the failure origin ?
Any Help on how to delete this "foo_upnp." folder would be very appreceated.
This post has been edited by fuffi: Nov 15 2013, 13:59
bubbleguuum
post Nov 15 2013, 13:58
Post #1822
The .fb2k-component was bad containing foo_upnp..dll instead of foo_upnp.dll . I've uploaded a fixed version.
You may have to remove manually foo_upnp..dll in the components dir.
fuffi
post Nov 15 2013, 14:02
Post #1823
QUOTE (bubbleguuum @ Nov 15 2013, 14:58) *
It seems that is not possible, because I cannot delete that folder, nor can I move into that folder to delete the file.
strange!
Windows tells me, that the folder does not exists, if I try to delete or rename it (after telling me, that I should be careful to rename the extension of the folder...)
Jan S.
post Nov 15 2013, 14:30
Post #1824
Same here. cannot enter the foo_upnp. folder. nor delete it.
bubbleguuum
post Nov 15 2013, 14:40
Post #1825
Make sure to exit foobar2000 ?
Reboot ?
3 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
1 Members: MordredKLB
RSS Lo-Fi Version Time is now: 30th July 2015 - 14:54
