36 Pages V  « < 32 33 34 35 36 >
[Not my release] foo_uie_panel_splitter, A Columns UI plugin that works similarly to Panels UI
mire777
post Jun 15 2012, 02:11
Post #826
QUOTE (WilB @ Jun 10 2012, 20:17) *
Thank you so much 'WilB', I installed wsh panel mod for xp from this site: https://sites.google.com/site/jk7800/foobar2000
works perfectly,now I don't have problem with letters transparency, also foobar still can be transparent if I select this in columns ui preference
emte
post Sep 14 2012, 15:48
Post #827
Hello,
I add an image button to my config but it doesn't work at all. It should active one of the DSP settings. Can anyone tell me what's wrong? (When I add a keyborad shortcut for it, the keyboard shortcut works) Here's the code:
$imagebutton(0,0,34,9,$get(skin_path)/stereo.png,$get(skin_path)/stereo_hov.png,COMMAND: 'Playback / DSP Settings / stereo';REFRESH,,)
$imagebutton(38,0,45,9,$get(skin_path)/binaural.png,$get(skin_path)/binaural_hov.png,COMMAND: 'Playback / DSP Settings / binaural';REFRESH,,)
marc2003
post Sep 15 2012, 11:41
Post #828
you don't need the spaces or quotes there. try it like this...
COMMAND:Playback/DSP Settings/stereo
http://marc2003.x10host.com/updates
emte
post Sep 15 2012, 12:29
Post #829
QUOTE (marc2003 @ Sep 15 2012, 12:41) *
Still isn't working...
WilB
post Sep 15 2012, 12:42
Post #830
Such a command doesn't appear to exist. To see available commands see the PSS menu and context command list or keyboard shortcuts list - its not listed on my set up but may be you have another component that provides it. There is just Playback/DSP settings on my set up.
This post has been edited by WilB: Sep 15 2012, 12:45
macarych
post Oct 9 2012, 09:35
Post #831
foo_uie_panel_splitter_mod.7z modified by equinox.
sokeking
post Oct 16 2012, 18:22
Post #832
Hey guys,
sry for the newbe question, but is there a command for changing the active playlist?
what i wanna do is to separate my library from my playing playlists. however i want to use the esPlaylist for the library, i need to have it following the active playlist, which should be 'filtered results' in order to get the CIU filter panels to work with the esPlaylist.
so when pushing a button to go to the library the active playlist should be switched to the 'filtered results' playlist the CUI filter is working on. when going back to the now playing view, the script should switch to the one playing a song or to the last one viewed before entering the library!!!
now: is this possible?!
thanks a lot!!!
This post has been edited by sokeking: Oct 16 2012, 18:24
Elevory
post Oct 20 2012, 20:44
Post #833
Is it possible to specify a background image location using a variable like %APPDATA%? This would allow me to distribute my theme without expecting users to manually change the location of this file.
SardonicWrath
post Oct 21 2012, 01:37
Post #834
QUOTE (macarych @ Oct 9 2012, 10:35) *
to anyone wondering what exactly this is, I checked on the russian forums.
Its a small modification of the settings dialog. Everthing else stays the same.
From what I got, the size is changed and there i a different font in the script tab.
QUOTE (Elevory @ Oct 20 2012, 21:44) *
Didn't try it, but you probably did that yourself... if it didn't work, there is your answer tongue.gif
I suggest you just draw the background image with imageabs(0,0,%_width%,%_height%,%themepath%background.jpg).
You can either set the path manually with $set_ps_global(themepath,'[your path]'), or use %ps_foobar2000_path%(path of foobar2000.exe) or %ps_user_profile_path% (user profile path.)
This post has been edited by SardonicWrath: Oct 21 2012, 01:38
sokeking
post Oct 23 2012, 17:41
Post #835
I'm not sure if my question is just nonsense, but since nobody gave me some advice i'll just ask again:
Is there a way for me switching to a certain playlist (not just "View/Columns playlist/Activate now playing") when pushing a button? Can i somehow implement such a functionality?
Falstaff
post Oct 23 2012, 18:55
Post #836
QUOTE (sokeking @ Oct 23 2012, 18:41) *
no way in PSS, but you can do it with WSH Panel Mod (jscript). With PSS, just set your wsh panel where you want, the panel fit the button size and you can also add it in the CUI toolbar... you can ask help about a such panel in the WSH Panel Mod discussion thread in 3rd party components.
HTH
http://br3tt.online.fr/
sokeking
post Oct 24 2012, 11:04
Post #837
Ahhh ok i see!!! The PSS then defines the appearance of the button and refers to a command or function, which is specified in the WSH Panel, right?
Thank you so much for your answer!! :-)
This post has been edited by sokeking: Oct 24 2012, 11:05
marc2003
post Oct 24 2012, 13:21
Post #838
no - you'd have to make the button in WSH panel mod as well. but because you can position the panel anywhere you like in PSS it can appear seemlessly with a bit of styling.
sokeking
post Oct 24 2012, 13:43
Post #839
Ok, i guess i will have to dig into that stuff first...
Anyways, thank you so much for helping me so far ;-)
Bratman
post May 5 2013, 23:40
Post #840
Is there a way to move the same panel using two buttons? I have two buttons, both move the same panel but to different positions. Or is there a way to make one button do three different things so it can be clicked three times?
$if($isvisible_c(Artist)
$imagebutton($sub($get(bar.width),72),$get(play.button2.top),30,18,$get_ps_global(image.path)'/bt/list_off.png',$get_ps_global(image.path)'/bt/list_on.png',PANELSHOW:Artist:0;REFRESH,,)
$movepanel_c(Artist,1,$add($get(button.top),46),$get(bar.width),$sub(%_height%,78))
$movepanel_c(Graphical Browser,0,0,0,0)
$imagebutton($sub($get(bar.width),72),$get(play.button2.top),30,18,$get_ps_global(image.path)'/bt/list_off.png',$get_ps_global(image.path)'/bt/list_on.png',PANELSHOW:Similar:0;PANELSHOW:List:0;PANELSHOW:Artist:1;REFRESH,,)
$movepanel_c(Artist,$get(playlist.left),$sub($add($get(playlist.top),$get(playlist.h)),$get(playtabs.h)),$get(playlist.w),$get(playtabs.h))
$imagebutton($sub($get(bar.width),36),$get(play.button2.top),30,18,$get_ps_global(image.path)'/bt/list_off.png',$get_ps_global(image.path)'/bt/list_on.png',PANELSHOW:Artist:0;REFRESH,,)
$drawrect(0,330,$add($get(bar.width),2),25,60-60-60,25-25-25,RESERVED)
$font(Myriad Web,10,bold)$drawtextex(%artist% | %genre%,0,334,$get(bar.width),,$get(track.color2),hcenter vtop end_ellipsis)
$movepanel_c(Artist,1,$add($get(button.top),46),$get(bar.width),280)
$movepanel_c(Graphical Browser,0,355,$add($get(bar.width),1),$sub(%_height%,383))
$imagebutton($sub($get(bar.width),36),$get(play.button2.top),30,18,$get_ps_global(image.path)'/bt/list_off.png',$get_ps_global(image.path)'/bt/list_on.png',PANELSHOW:Similar:0;PANELSHOW:List:0;PANELSHOW:Artist:1;REFRESH,,)
Using this code both buttons move the artist panel to the same place?
This post has been edited by Bratman: May 5 2013, 23:41
marc2003
post May 6 2013, 07:30
Post #841
rather than use PANELSHOW, i'd use global variables to save 3 different "states". each button click would cycle through them.
//sets state to 1 on first run. after that, the stored setting will be used.
$init_ps_global(state,1)
//note you don't need $get_ps_global, you can just wrap the variables in %% to access them. make sure they don't conflict with any tags/special fields that are in use.
$select(%state%,
//code here to show/hide/move panels if value is 1
//code here for 2
//code here for 3 etc
then in your button use this
SETGLOBAL:$select(%state%,2,3,1);REFRESH;
if the value of state is current 1, set it to 2.
if value is 2, set it to 3
if value is 3, set it back to 1 again.
Bratman
post May 10 2013, 20:31
Post #842
QUOTE (marc2003 @ May 6 2013, 07:30) *
$select(%state%,
//code here for 2
That works as I expected, thanks again foowizard.
Yokulus
post May 15 2013, 15:50
Post #843
How to affect "sibling" (= parent's child) pss?
I hope I post in the right thread since I am new to this forum (in fact I just registered because of my question) unsure.gif
I recently rediscovered Foobar and its vast amount of cusomization options, so I wanted to do my first own "theme" inspired by my needs as well as some skins seen around the internet.
It all went pretty well until now: I want to have a "Display-Switch", that means a button to change the whole appearance. So I created multiple "panel stack splitter" inside my main (empty) panel splitter. The buttons are coded in the main pss script, so I can swap appearance via $showpanel. Since the button is always located in the upper right corner it shouldn't be a big problem, BUT: I want it to be more included into the whole theme, not only to be "toolbar-like". E.g. one possible display should look like this: big album art on the left, and on the right in vertical order: buttons, pss ( wsh - track info ), pss ( virualization ; wsh - seekbar ). Not that much - and I got all to work, the display as well as the buttons - but I just can't combine them if I want the buttons to be in the display's parent pss' script, not in the display's script (that's easy cool.gif ).
I found two solutions/workarounds:
1. Move the Display Panels a bit down so I get free Space on top - makes the buttons appear
2. Create the buttons in the display's main pss' script and update ($showpanel) in the parent pss' per second section - the delay creates a bad feeling AND the buttons don't work when paused/stopped. A command to refresh the parent pss would be very helpfull, but I looked it up in the components documentation and couldn't find anything.
Picture, created by using method 1:
Related Code: (NOT using method 1)
MAIN PSS SCRIPT:
//---------GLOBAL VARIABLES---------
$init_ps_global(display.switch,1)
// ----- PANELS -----
$movepanel(0,0,0,%ps_width%%ps_height%)
$movepanel(1,0,0,%ps_width%,%ps_height%)
$movepanel(2,0,0,%ps_width%,%ps_height%)
// ----- SHOWPANEL -----
$showpanel(0,$ifequal(%display.switch%,1,1,0))
$showpanel(1,$ifequal(%display.switch%,2,1,0))
$showpanel(2,$ifequal(%display.switch%,3,1,0))
//------- APPEARANCE SWITCH BUTTONS ---------
$puts(bar.length,$mul($div($sub(%ps_width%,%ps_height%),4),1))
$puts(bar.x,$sub(%ps_width%,$get(bar.length)) )
$gradientrect($get(bar.x),0,$get(bar.length),14,237-237-237-255,26-26-26-255,horizontal aa,0)
$gradientrect($get(bar.x),1,$sub($get(bar.length),1),12,237-237-237-255,255-255-255-255,horizontal aa,0)
//-------- BUTTONS ------------
$puts(btn.w,26)
$font(Calibri,11,)
$puts(btn.x,$sub($sub(%ps_width%,25),$get(btn.w)) )
$drawrect($get(btn.x),1,$get(btn.w),12,46-46-46-255,46-46-46-255,aa)
$textbutton($get(btn.x),1,$get(btn.w),12,LIB,LIB,SETGLOBAL:display.switch:3;REFRESH,fontcolor:192-192-192,fontcolor:255-255-255)
$puts(btn.x,$sub($sub($get(btn.x),18),$get(btn.w)) )
$textbutton($get(btn.x),1,$get(btn.w),12,B/W,B/W,SETGLOBAL:display.switch:1;REFRESH,fontcolor:192-192-192,fontcolor:255-255-255)
I tried almost everything from moving the panels via script, forced layout, fake transparency and everything I could imagine to help, but nothing worked - perhaps I just combined the wrong settings?
Thanks in advance for your help!
Have a nice day
This post has been edited by Yokulus: May 15 2013, 16:44
WilB
post May 15 2013, 18:45
Post #844
If I understand you correctly, you want a refreshall command (the refresh command available only refreshes code in the containing panel). Unfortunately there isn't a refreshall command and so some sort of workaround is needed that forces the code to run in the child panels when a button is clicked in the parent panel.
One workaround is below.
Include $get(p.p) as a button command this will refresh most child panels and is documented earlier in the thread.
$puts(p.p,$if(%ps_ispause%,COMMAND:Playback/Play;COMMAND:Playback/Pause,$if(%ps_isplaying%,COMMAND:Playback/Pause;COMMAND:Playback/Play,COMMAND:Playback/Play;COMMAND:Playback/Pause)))
$textbutton(x,y,w,h,,,$get(p.p);REFRESH,,)
    I have never found this to interfere with playback and it also works with $imagebutton. The rapid change in playback state causes the code to run. It works best with the panels positioned with $movepanel and forced layout.
Another possibility is to force a small resize of the child panels (e.g. 1 pixel height or width difference toggle when the button is pressed more difficult to code - but can trigger the code to run and help.
I hope that helps and that I understood your post correctly.
This post has been edited by WilB: May 15 2013, 18:58
Bratman
post May 15 2013, 22:32
Post #845
Marc I can't get your global variable code to work, I thought it was working but looks like I've messed it up or I'm doing it wrong. Could you please check this for me?
$init_ps_global(banner,1)
$select(%banner%,
$drawimage($sub(%_width%,1226),0,1226,27,$get_ps_global(image.path)'/texture.png',OPTIONS,n,180)
$drawimage($sub(%_width%,1226),0,1226,27,$get_ps_global(image.path)'/texture2.png',OPTIONS,n,180)
$drawimage($sub(%_width%,1226),0,1226,27,$get_ps_global(image.path)'/texture3.png',OPTIONS,n,180)
$imagebutton(0,450,30,18,$get_ps_global(image.path)'/bt/list_on.png',$get_ps_global(image.path)'/bt/list_off.png',SETGLOBAL:$select(%banner%,2,3,1);REFRESH;)
I've been trying to make it work for the last two days am I missing something?
WilB
post May 15 2013, 22:38
Post #846
This isn't setting the global:
Try:
SETGLOBAL:banner:$select(%banner%,2,3,1);
marc2003
post May 15 2013, 22:40
Post #847
obviously i missed it out to check people are awake... rolleyes.gif laugh.gif
Bratman
post May 15 2013, 23:12
Post #848
I'M GOING TO KILL YOU MARC!
I have been changing it for ages I nearly threw the keyboard out the window.
*Does this work as a global variable, the button only works if it's in the same PSS as the code? I thought it would be like $set_ps_global.
Quick question also is it more efficient to use title formatting than using $get and $puts?
This post has been edited by Bratman: May 15 2013, 23:37
Bratman
post May 16 2013, 02:05
Post #849
This is slower than my old method?? Now it lags when I click the button, the panel shows in three laggy pieces.
$init_ps_global(utils99,1)
$select(%utils99%,
$movepanel_c(Utils,$get(l.panel.left),$get(l.panel.top),$get_ps_global(l.panel.w),$add($get(l.panel.h),5))
$movepanel_c(Utils,0,0,0,0)
$imagebutton($add($get(l.panel.button.left),$mul($add($get(l.panel.button.x),$get(l.panel.button.sep)),4)),$get(l.panel.button.top),$get(l.panel.button.x),$get(l.panel.button.y),$get_ps_global(image.path)'/bt/blank_off.png',$get_ps_global(image.path)'/bt/blank_on.png',SETGLOBAL:utils99:$select(%utils99%,2,1);REFRESH;)
This method is instant:
$if($isvisible_c(Utils),
$imagebutton($add($get(l.panel.button.left),$mul($add($get(l.panel.button.x),$get(l.panel.button.sep)),4)),$get(l.panel.button.top),$get(l.panel.button.x),$get(l.panel.button.y),$get_ps_global(image.path)'/bt/blank_on.png',$get_ps_global(image.path)'/bt/blank_on.png',PANELSHOW:Cover:1;PANELSHOW:Filter:0;PANELSHOW:Artist:0;PANELSHOW:Lyrics:0;PANELSHOW:Bio:0;PANELSHOW:Info:0;PANELSHOW:Customize:0;PANELSHOW:Utils:0;REFRESH,,)
$movepanel_c(Utils,$get(l.panel.left),$get(l.panel.top),$sub($get_ps_global(l.panel.w),$get(l.panel.left),$get(l.panel.right)),$get(l.panel.h))
$movepanel_c(Cover,0,0,0,0)
$imagebutton($add($get(l.panel.button.left),$mul($add($get(l.panel.button.x),$get(l.panel.button.sep)),4)),$get(l.panel.button.top),$get(l.panel.button.x),$get(l.panel.button.y),$get_ps_global(image.path)'/bt/blank_off.png',$get_ps_global(image.path)'/bt/blank_on.png',PANELSHOW:Cover:0;PANELSHOW:Filter:0;PANELSHOW:Artist:0;PANELSHOW:Lyrics:0;PANELSHOW:Bio:0;PANELSHOW:Info:0;PANELSHOW:Customize:0;PANELSHOW:Utils:1;REFRESH,,)
$movepanel_c(Cover,$get(l.panel.left),$get(l.panel.top),$get_ps_global(l.panel.w),$add($get(l.panel.h),5))
This post has been edited by Bratman: May 16 2013, 02:06
Yokulus
post May 16 2013, 09:53
Post #850
QUOTE (WilB @ May 15 2013, 18:45) *
Thanks for the quick reply!
Although I needed it the other way round (refresh the parents' code when a child panel's button is clicked) your code did exactly this and no delay is audible!
Have a nice day!
RSS Lo-Fi Version Time is now: 4th March 2015 - 14:42
