WAV to FLAC error with greek filenames, Impossible to convert wav to flac when wav filename in greek.
adrien.ha
post Oct 27 2012, 21:13
Hi all,
i'm new in flac ripping. I installed EAC and configured it. When i tried to rip a CD to flac, at the end of every track, it told me : Warning "The external compressor returned an error".
In the end, all the tracks had been made to .wav files but they hadn't been converted into flac files.
I tried converting the wav files to flac files without EAC, by using the FLAC Front End alone, and it made an error : Run-time error '53': File not found.
When i give as input a wav file with latin caracters there is no problem at all.
So i'm quite sure the problem comes with wav files containing greek caracters in their name.
Does anybody have a solution or any idea about that ?
Thank you
pablogm123
post Oct 27 2012, 22:09
Try an alternative app which uses Unicode character set. I own in my collection music with japanese titles (which suffers from the same issue), so that I have made a tests, and Foobar2000 converter handles finely music files with japanese titles.
mjb2006
post Oct 27 2012, 23:27
This is the downfall of EAC's reliance on command-line apps instead of DLLs for external encoding. flac.exe is being invoked through a command shell, which is like a DOS prompt, so the characters are converted to what's valid there. This will only be 8-bit characters, whatever your system's ANSI set is (Windows-1252 for most folks). So probably things like and will work but Greek is not an option unless you're using a Greek version of Windows.
adrien.ha
post Oct 28 2012, 00:21
Thanks guys,
so it seems i won't be able to use EAC..It's a pitty as i read it's "the best".
I'll try Foobar2000 then.
Does any of you know if dbPowerAmp will work ? (with greek filenames)
I've read dbPowerAmp does a great job (though i'll have to pay 35$ or something... dry.gif ). Do you have any preference between these two, as FLAC ripping is concerned?
This post has been edited by adrien.ha: Oct 28 2012, 00:22
pablogm123
post Oct 28 2012, 01:20
dBpoweramp is fully Unicode compatible, and I have performed a test, converting a music file with dummy greek title, and can handle finely.
You don't have to pay for using dBpoweramp, as long as you run just the basic functions, as detailed here:
http://www.dbpoweramp.com/db-versions.htm
adrien.ha
post Oct 28 2012, 01:43
QUOTE (pablogm123 @ Oct 28 2012, 02:20) *
Thanks pablogm123, i've just ripped the greek cd with Foobar2000 and it worked great. ! smile.gif
Do you think there is a quality difference in flac ripping between Foobar2000 and dBpoweramp ?
Thank you
pablogm123
post Oct 28 2012, 10:59
To rip CDs in good/excellent condition there is absolutely no difference, because any decent drive can rip in a go any CD in good shape without reporting any C2 error . However, dBpoweramp will outperform other programs when you own a drive with good C2 support and you want to rip somewhat damaged CDs, because take into account C2 pointers in re-reads (and can do hundreds of re-rips), so that dBpoweramp can rescue more accurate data from damaged CDs. And don't forget that programs
Anyway, a rip verified by Accuraterip is always a very good thing. If verified by Accuraterip, doesn't matter if was extracted by EAC, dBpoweramp, Foobar 2000, at 8x speed, at 32x speed...
adrien.ha
post Oct 28 2012, 11:15
Thanks pablo
pablogm123
post Oct 28 2012, 12:35
Try this ripper too:
http://www.cuetools.net/wiki/CUERipper
Free, Open-Source, and secure ripper which uses C2 pointers even in burst mode.
According to this http://www.cuetools.net/wiki/CUETools_Changelog, supports Unicode from 1.9.2 Update 8.
Porcus
post Oct 28 2012, 12:46
An alternative carrying the zero price tag, could be CUETools/CUERipper. It has UTF support, at least on the functionality I have been using – I have however not done much ripping with it (I use dBpoweramp reference).
Edit: Too late. Anyway, yes, try it.
This post has been edited by Porcus: Oct 28 2012, 12:48
adrien.ha
post Oct 28 2012, 22:47
thanks guys i'll have a look on CUETools/CUERipper, but before i'll check if my CD drive is C2 capable.
Does Foobar2000 manage C2 ?
Porcus
post Oct 29 2012, 00:04
QUOTE (adrien.ha @ Oct 28 2012, 23:47) *
No: http://wiki.hydrogenaudio.org/index.php?ti...n_of_CD_rippers .
adrien.ha
post Oct 29 2012, 00:05
thanks Porcus
RSS Lo-Fi Version Time is now: 3rd August 2015 - 07:53
