5 Pages V  « < 3 4 5
A multicore FLAC encoder
Glenda
post Jan 22 2011, 03:40
Post #101
QUOTE (GeorgeFP @ Jan 18 2011, 06:47) *
If you haven't installed the Visual C++ redistributables yet, you can download them here. They are required.
Duh, I missed that part. Running like a dream now, compresses so fast all I see is a flicker of the fpFlac.
Thankyou
seanyseansean
post Jan 22 2011, 13:41
Post #102
Group: Members (Donating)
1 question though - is it still subject to the same bug as in the Windows version of FLAC - i.e. is it limited to files of around 2GB due to the libraries used?
Reason I ask is because I try to merge all my multi-disc titles into 1 file, with the standard Windows FLAC I have to split them into around 2/3 disc files.
Thanks again!
p.s. the bug I am on about is referenced here:
http://www.hydrogenaudio.org/forums/index....st&p=483172
lvqcl
post Jan 22 2011, 13:55
Post #103
1. from the very 1st post:
- Win64 version: The total WAV file size sum must not exceed 400GiB.
2. take a look at http://www.hydrogenaudio.org/forums/index....st&p=725304
seanyseansean
post Jan 22 2011, 14:10
Post #104
QUOTE (lvqcl @ Jan 22 2011, 13:55) *
Can't believe I missed that text in the FP, thanks, but double thanks for the Case version of the original FLAC encoder. You've just saved me a lot of grief and time smile.gif
GeorgeFP
post Jan 22 2011, 15:03
Post #105
QUOTE (seanyseansean @ Jan 22 2011, 13:41) *
The max supported file size of 4GB is limited by the WAVE format which is the only supported format in fpFLAC right now. Internally, fpFLAC is able to process files up to 500GB.
GeorgeFP
post Jan 22 2011, 15:11
Post #106
I haven't calculated the exact value but this limit is not because of the WAV format. It comes from the internal memory handling (max process virtual memory (2TiB) / number of memory buffers (4 or 5)) .
Vaako
post Sep 20 2012, 00:53
Post #107
if I use this command line options
-8 -f %s %d
and if I do the "Test encoder" or like to Save the settings I receive an error message: Invalid replacement tag found!
What would be a correct command line?
This post has been edited by Vaako: Sep 20 2012, 01:37
Vaako
post Sep 20 2012, 01:28
Post #108
QUOTE (GeorgeFP @ Dec 26 2009, 21:18) *
BTW, I've decided to add some missing command-line options into fpFLAC (-b, -m, -M, -e, -A, -l, -p, -q, -r and --replay-gain).
Can you list the total command-line options and it's intentions of fpFLAC?
lvqcl
post Sep 20 2012, 04:09
Post #109
QUOTE (Vaako @ Sep 20 2012, 03:53) *
-8 -f %s %d
It's a EAC related question.
GeorgeFP
post Sep 20 2012, 19:18
Post #110
QUOTE (Vaako @ Sep 20 2012, 02:28) *
Just call fpFLAC.exe in the command line to see the options.
wildstoo
post Jan 20 2013, 00:00
Post #111
Is it normal that fpFLAC creates files with different sizes than standard FLAC with the same compression setting? I'm a noob so feel free to educate me tongue.gif
Glenda
post Oct 12 2013, 10:40
Post #112
QUOTE (lvqcl @ Sep 19 2012, 23:09) *
-8 -f %s %d
EAC question or not fpflac.exe many of us can't get fpflac to work with the latest EAC. Something to do with the way EAC is handing filenames as far as I can tell. Anyone have a command line that works ?
This post has been edited by Glenda: Oct 12 2013, 10:41
Isabelxxx
post May 14 2015, 21:25
Post #113
I suposse this one is dead but... this is a copy of the post I put in the cuda encoder.
Hi Gregory, have been following yours and the fpflac implementation and noted there is one important missing feature (at least for me): the --test option.
Checking an existing flac file like you do with -v option but without the wav requirement and no output, just verifying if the calculated MD5 matches the stored signature.
I suppose in your implementation the idea would be a bit different than the work you have been done up to now since the point is not checking if the output matches the input with your new gpu encoding but making use of the GPU to calculate faster the MD5 hash, independent of the flac "enconding".
Just with that and a batch file you would make an entire 3TB audio database verification a matter of minutes instead of hours.
Gregory said the GPU would not be very good for that task so any possibility to make add it to the multicore enconder?
slks
post May 16 2015, 04:50
Post #114
Is there any advantage to a multicore encoder versus starting a separate encoder on each core (like foobar's converter?)
My experience with multicore encoders (not this particular one) has been that they keep my four cores at 60 or 75% usage, whereas simply starting four single threaded encoders will keep each core 100% utilized.
What I do with all the audio tech? This: http://last.fm/user/sls
Isabelxxx
post May 16 2015, 18:40
Post #115
The approach is totally different, not sure what are you asking.
A multicore encoder takes 1 file and use X cores in the process.
A multi-instance encoder takes X files and uses X cores.
Both have their advantages and limitations.
5 Pages V  « < 3 4 5
RSS Lo-Fi Version Time is now: 24th May 2015 - 12:52
