Topic: Curaçao by Br3tt (Read 335277 times) previous topic - next topic
Curaçao by Br3tt
And enjoy you all will, it is absolutely superb
Well done Br3tt, a stunning config, the best I've ever seen for F2K
Curaçao by Br3tt
this is by far the greatest config i have ever seen. keep up the great job Brett
Curaçao by Br3tt
The config is really great. Only thing that I noticed is that I'm missing buttons and lots of them.
Btw wouldn't it be better if you used %appdir%/foobar2000/ instead of C:/Program Files/foobar2000? Simply because Windows names the program folder differently in every language.
Curaçao by Br3tt
Wanted to drop a quick thank you br3tt, and this is a really great config:)
Curaçao by Br3tt
You need to put the folder called curacao in the images folder in the Foobar main folder, so C:\Program Files\foobar2000\Images\curacao
Curaçao by Br3tt
Thanks Br3tt!
Curaçao by Br3tt
just read help files available on my site before asking question, all is explain (i hope).
%appdir% not supported
thanx to you and everybody that enjoy it
Curaçao by Br3tt
This thing is great no problems in setting it up which is a good start the only problem is when switching to MilkDrop for the AVS I get The plugin crashed during initialization.
Curaçao by Br3tt
Sorry to disappoint but I'm not that dumb. The image folder is present. Well actually it's in C:\Programme\foobar2000\... since I'm using the German version of XP. But I changed the path (changed the foo_path definition to C:/Programme/foobar2000/) in PSS so I hope that would solve this problem.
Curaçao by Br3tt
I guess this isn't a Vista x64 friendly theme? I follow the instructions and when I click to play a song it immediately crashes.
Curaçao by Br3tt
not a curacao issue, but shpeck issue, be sure that your version of milkdrop is compatible with the version of your Shpeck component !
Curaçao by Br3tt
Looks really pretty, and it was incredibly easy to set up, really well done on that. It's kind of annoying that you have to create a playlist to view all of your music though, kinda defeats the purpose of having a library. There are no ultra customizable media library viewers though, so it seems to be the only solution.
Another thing, how do you get that exact visualization up? I have milkdrop 2 installed, don't know how to pick a particular vis though.
Cheers!
Curaçao by Br3tt
You should be using Milkdrop 2.0e really, what version do you have?
Curaçao by Br3tt
components make vista x64 crash, not the config dude.
foo_path variable have to be changed in many other panel in the config, i'll list them tomorrow.
bye
Curaçao by Br3tt
Downloading....
Thanks for another fine work.
Curaçao by Br3tt
bye
I just noticed. I changed it in a ton of different places. A hell of a lot of work. Especially if you have to do it frequently :\.
Looks great though once it's done.
Not sure if I'll keep it. Ibiza doesn't look as fancy but is easier to get working under my circumstances.
A shame that it's not possible to put a master setting for album, artist and foobar paths and let all parts of the config grab them from there.
Curaçao by Br3tt
which components would that be then? how would I figure out which one(s) it could be?
Curaçao by Br3tt
Is it possible to have all the unfocused groups collapsed like in Ibiza? Makes scrolling through the playlist a lot faster.
Curaçao by Br3tt
I get this a few times now after playing music.....I did a clean install and now it seems to be working fine except for the below crash that occurs. DEP keeps closing foobar2000 down....I tried to exclude it and Vista tells me this program needs DEP and I can't exclude it.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 62A3FAD4h
Access violation, operation: write, address: 62A3FAD4h
Call path not available.
Code bytes (62A3FAD4h):
62A3FA94h:  00 00 00 00 00 00 00 00 00 00 00 00 6C D8 B8 A0
62A3FAA4h:  88 27 1E 08 00 00 00 00 37 00 00 00 08 00 00 00
62A3FAB4h:  A8 FA A3 62 D4 FA A3 62 04 00 00 00 13 00 00 00
62A3FAC4h:  00 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00
62A3FAD4h:  8B F7 B8 D8 F1 B6 5F 50 B8 CC FA A3 62 5B DD 00
62A3FAE4h:  DD 1B C3 00 00 00 00 40 00 00 00 00 00 00 00 40
62A3FAF4h:  00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 40
62A3FB04h:  00 00 00 00 00 00 00 40 8B F7 B8 90 94 A7 5F 50
Stack (090FEB3Ch):
090FEB1Ch:  00000000 00000000 00000000 00000000
090FEB2Ch:  00000000 00000000 00000000 00000000
090FEB3Ch:  04A6F970 00000000 04A914E0 090FEB70
090FEB4Ch:  090FEB60 04A91508 00000368 7EFA6000
090FEB5Ch:  62A3FAD4 00000000 04A914E0 00000000
090FEB6Ch:  04A91508 090FED94 04A6DCB2 62A3FAD4
090FEB7Ch:  1670F0E8 04A725A8 62A3FAB0 090FF368
090FEB8Ch:  00000034 04A871B0 00000000 00000000
090FEB9Ch:  00000000 0000FFFF 00000000 00000000
090FEBACh:  FB14BC00 00004004 00000000 00000000
090FEBBCh:  D1F9DAEA 00004002 00000000 00000000
090FEBCCh:  00000000 00000000 00000000 00000000
090FEBDCh:  00000000 00000000 00000000 1670F0E8
090FEBECh:  00000000 00000000 00000000 00000000
090FEBFCh:  00000000 00000000 00000000 00000000
090FEC0Ch:  00000000 00000000 00000000 00000000
090FEC1Ch:  00000000 00000000 00000000 00000000
090FEC2Ch:  00000000 00000000 00000000 00000000
090FEC3Ch:  00000000 00000000 00000000 00000000
090FEC4Ch:  00000000 00000000 00000000 00000000
Registers:
EAX: 62A3FAD4, EBX: 04A91520, ECX: 7EFA6000, EDX: 00000368
ESI: 04A914E0, EDI: 04A91520, EBP: 090FEB70, ESP: 090FEB3C
Unable to identify crash location
Loaded modules:
foobar2000                      loaded at 00F50000h - 01089000h
ntdll                            loaded at 77780000h - 778E0000h
kernel32                        loaded at 75B50000h - 75C60000h
COMCTL32                        loaded at 74A30000h - 74BCE000h
msvcrt                          loaded at 772C0000h - 7736A000h
ADVAPI32                        loaded at 76060000h - 76126000h
RPCRT4                          loaded at 76210000h - 76300000h
Secur32                          loaded at 75930000h - 75990000h
GDI32                            loaded at 75AC0000h - 75B50000h
USER32                          loaded at 75E30000h - 75F00000h
SHLWAPI                          loaded at 75F00000h - 75F58000h
SHELL32                          loaded at 76470000h - 76F7F000h
ole32                            loaded at 76310000h - 76454000h
shared                          loaded at 10000000h - 1002A000h
UxTheme                          loaded at 74030000h - 740B0000h
COMDLG32                        loaded at 75D20000h - 75D93000h
IMM32                            loaded at 77380000h - 773E0000h
MSCTF                            loaded at 75F90000h - 76058000h
LPK                              loaded at 76130000h - 76139000h
USP10                            loaded at 76140000h - 761BD000h
wl_hook                          loaded at 00E40000h - 00EF5000h
AM30400                          loaded at 00AA0000h - 00AAC000h
ws2_32                          loaded at 75C60000h - 75C8D000h
NSI                              loaded at 76460000h - 76466000h
foo_uie_elplaylist              loaded at 02650000h - 026B7000h
gdiplus                          loaded at 719B0000h - 71B5B000h
foo_freedb2                      loaded at 00F10000h - 00F50000h
foo_uie_wsh_panel                loaded at 74890000h - 748BF000h
OLEAUT32                        loaded at 770A0000h - 7712D000h
foo_uie_vis_channel_spectrum    loaded at 025D0000h - 0260D000h
MSIMG32                          loaded at 73140000h - 73145000h
WINMM                            loaded at 73840000h - 73872000h
OLEACC                          loaded at 73800000h - 73839000h
foo_menu_addons                  loaded at 02730000h - 0278D000h
libmmd                          loaded at 02FD0000h - 03281000h
MSVCR80                          loaded at 74280000h - 7431B000h
foo_vis_shpeck                  loaded at 74860000h - 7488A000h
MSVCR90                          loaded at 73330000h - 733D3000h
foo_playback_custom              loaded at 02B00000h - 02B45000h
WINSPOOL                        loaded at 74480000h - 744C2000h
foo_lastfm_radio                loaded at 02C10000h - 02C56000h
foo_ui_std                      loaded at 036F0000h - 037C4000h
foo_uie_panel_splitter          loaded at 02C80000h - 02CCF000h
foo_rgscan                      loaded at 02D70000h - 02DCB000h
foo_albumlist                    loaded at 02E50000h - 02EBB000h
foo_converter                    loaded at 03390000h - 033FC000h
foo_uie_quicksearch              loaded at 03400000h - 03446000h
foo_skip                        loaded at 75740000h - 7574C000h
foo_dsp_std                      loaded at 039F0000h - 03A38000h
foo_uie_graphical_browser        loaded at 74720000h - 747B4000h
foo_cdda                        loaded at 03A90000h - 03AD1000h
foo_uie_trackinfo_mod            loaded at 03AE0000h - 03B36000h
MSVCP80                          loaded at 74320000h - 743A7000h
foo_input_std                    loaded at 03E20000h - 03F5C000h
foo_ui_columns                  loaded at 04060000h - 04192000h
foo_unpack                      loaded at 03570000h - 0359D000h
foo_fileops                      loaded at 03D80000h - 03DC6000h
foo_run                          loaded at 03DD0000h - 03DFE000h
foo_abx                          loaded at 043D0000h - 04401000h
foo_uie_lyrics                  loaded at 04470000h - 044CC000h
WININET                          loaded at 76F80000h - 77050000h
Normaliz                        loaded at 77370000h - 77373000h
iertutil                        loaded at 77050000h - 77095000h
mscms                            loaded at 70830000h - 70892000h
USERENV                          loaded at 757A0000h - 757BE000h
icm32                            loaded at 716F0000h - 71728000h
SXS                              loaded at 71610000h - 7166F000h
CLBCatQ                          loaded at 75C90000h - 75D14000h
jscript                          loaded at 69DE0000h - 69E5D000h
rsaenh                          loaded at 73E00000h - 73E3B000h
vis_avs                          loaded at 04A40000h - 04ABB000h
DDRAW                            loaded at 70740000h - 70825000h
DCIMAN32                        loaded at 71830000h - 71836000h
SETUPAPI                        loaded at 77130000h - 772BA000h
dwmapi                          loaded at 74430000h - 7443C000h
MSVFW32                          loaded at 74800000h - 74823000h
AVIFIL32                        loaded at 74840000h - 74859000h
MSACM32                          loaded at 73280000h - 73294000h
sud                              loaded at 69C00000h - 69D2E000h
ADVPACK                          loaded at 747D0000h - 747FE000h
VERSION                          loaded at 75790000h - 75798000h
PROPSYS                          loaded at 72C50000h - 72D0B000h
DUser                            loaded at 6B640000h - 6B670000h
AddBorder                        loaded at 05C80000h - 05C86000h
colormap                        loaded at 05C90000h - 05C9A000h
convolution                      loaded at 072E0000h - 072F0000h
fyrewurx                        loaded at 072F0000h - 07304000h
multifilter                      loaded at 07310000h - 07316000h
texer                            loaded at 07320000h - 07327000h
texer2                          loaded at 07350000h - 0735B000h
atiumdag                        loaded at 68C70000h - 69022000h
atiumdva                        loaded at 680E0000h - 6852F000h
browseui                        loaded at 69E60000h - 69FA6000h
tiptsf                          loaded at 6CD50000h - 6CDB0000h
apphelp                          loaded at 74CD0000h - 74CFC000h
urlmon                          loaded at 75990000h - 75AB9000h
DSOUND                          loaded at 69D70000h - 69DE0000h
POWRPROF                        loaded at 74700000h - 7471A000h
MMDevApi                        loaded at 732D0000h - 732F7000h
WINTRUST                        loaded at 74940000h - 7496D000h
CRYPT32                          loaded at 740B0000h - 741A1000h
MSASN1                          loaded at 749C0000h - 749D2000h
imagehlp                        loaded at 75F60000h - 75F89000h
AUDIOSES                        loaded at 732A0000h - 732C1000h
audioeng                        loaded at 71840000h - 718A6000h
PSAPI                            loaded at 76300000h - 76307000h
AVRT                            loaded at 73A00000h - 73A07000h
actxprxy                        loaded at 6CCF0000h - 6CD43000h
c_is2022                        loaded at 75750000h - 75756000h
c_iscii                          loaded at 756F0000h - 756F6000h
c_g18030                        loaded at 69FC0000h - 69FFA000h
dbghelp                          loaded at 71B70000h - 71C4C000h
Stack dump analysis:
Address: 04A6F970h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Address: 04A914E0h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Symbol: "winampVisGetHeader" (+00011D60h)
Address: 04A6DCB2h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Address: 04A725A8h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Address: 04A871B0h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Symbol: "winampVisGetHeader" (+00007A30h)
Address: 04A850F6h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Symbol: "winampVisGetHeader" (+00005976h)
Address: 04A871D0h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Symbol: "winampVisGetHeader" (+00007A50h)
Address: 04A73E97h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Address: 00E5DC9Ah, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 00EEB8E0h, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 777BD032h, location: "ntdll", loaded at 77780000h - 778E0000h
Symbol: "RtlInterlockedFlushSList" (+000000E9h)
Address: 00ED0D68h, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 01000414h, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 00ED0D98h, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 00E5EA5Ah, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 00E562E9h, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 00EEB3A8h, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 03000003h, location: "libmmd", loaded at 02FD0000h - 03281000h
Symbol: "_csqrtq_f90" (+0002D6C7h)
Address: 777AFA88h, location: "ntdll", loaded at 77780000h - 778E0000h
Symbol: "RtlTryEnterCriticalSection" (+000004F2h)
Address: 777D3081h, location: "ntdll", loaded at 77780000h - 778E0000h
Symbol: "RtlAllocateHeap" (+00000162h)
Address: 77832926h, location: "ntdll", loaded at 77780000h - 778E0000h
Symbol: "wcstombs" (+0000007Ah)
Address: 00ED12B8h, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 00E6BC4Ah, location: "wl_hook", loaded at 00E40000h - 00EF5000h
Address: 777AF26Ch, location: "ntdll", loaded at 77780000h - 778E0000h
Symbol: "RtlDeactivateActivationContextUnsafeFast" (+0000BBD0h)
Address: 04A75BB4h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Address: 04A871E8h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Symbol: "winampVisGetHeader" (+00007A68h)
Address: 707B5067h, location: "DDRAW", loaded at 70740000h - 70825000h
Symbol: "GetSurfaceFromDC" (+00038E18h)
Address: 7074DA25h, location: "DDRAW", loaded at 70740000h - 70825000h
Symbol: "DirectDrawCreate" (+00004480h)
Address: 04A7E11Ch, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Address: 04A8F8D8h, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Symbol: "winampVisGetHeader" (+00010158h)
Address: 777A35C0h, location: "ntdll", loaded at 77780000h - 778E0000h
Symbol: "RtlLeaveCriticalSection" (+00000000h)
Address: 04A7FECFh, location: "vis_avs", loaded at 04A40000h - 04ABB000h
Symbol: "winampVisGetHeader" (+0000074Fh)
Address: 02FFF9F8h, location: "libmmd", loaded at 02FD0000h - 03281000h
Symbol: "_csqrtq_f90" (+0002D0BCh)
Address: 02FFFB00h, location: "libmmd", loaded at 02FD0000h - 03281000h
Symbol: "_csqrtq_f90" (+0002D1C4h)
Address: 01060602h, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 00FF0000h, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 03040B0Eh, location: "libmmd", loaded at 02FD0000h - 03281000h
Symbol: "_csqrtq_f90" (+0006E1D2h)
Address: 01010504h, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 03060F0Fh, location: "libmmd", loaded at 02FD0000h - 03281000h
Symbol: "_csqrtq_f90" (+0008E5D3h)
Address: 01060603h, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 010603FEh, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 00F8F7FFh, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 00FFFE05h, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 03020206h, location: "libmmd", loaded at 02FD0000h - 03281000h
Symbol: "_csqrtq_f90" (+0004D8CAh)
Address: 010100FBh, location: "foobar2000", loaded at 00F50000h - 01089000h
Address: 01030505h, location: "foobar2000", loaded at 00F50000h - 01089000h
Version info:
foobar2000 v0.9.6 beta 5
UNICODE
Windows 6.0
Additional info:
WSH Panel (uie) 0.7.2  (foo_uie_wsh_panel)
Converter 1.2  (foo_converter)
Shpeck - Winamp vis plugins wrapper 0.2.4  (foo_vis_shpeck)
File Operations 2.1.1  (foo_fileops)
foobar2000 core 0.9.6 beta 5  (Core)
Menu Addons 0.4 (Intel SSE)  (foo_menu_addons)
ZIP/GZIP reader 1.0  (foo_unpack)
Run services 0.3.4  (foo_run)
Graphical Browser rev015  (foo_uie_graphical_browser)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Playback Statistics Custom 1.4.3  (foo_playback_custom)
Album List 4.3  (foo_albumlist)
Columns UI 0.3.5.1  (foo_ui_columns)
Panel Stack Splitter 0.3.6.2(alpha)  (foo_uie_panel_splitter)
Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]  (foo_uie_trackinfo_mod)
Skip Track 1.0.0  (foo_skip)
Channel Spectrum panel 0.17.2  (foo_uie_vis_channel_spectrum)
Default User Interface 0.9.5  (foo_ui_std)
Last.fm Radio 0.5  (foo_lastfm_radio)
ReplayGain Scanner 2.0.8  (foo_rgscan)
freedb Tagger 0.6  (foo_freedb2)
CD Audio Decoder 2.1.3  (foo_cdda)
Lyric Show Panel 0.3.3.4 [Nov 11 2008 - 19:42:37]  (foo_uie_lyrics)
ELPlaylist 0.6.3.0(beta)  (foo_uie_elplaylist)
RAR reader 1.1  (foo_unpack)
ABX Comparator 1.3.3  (foo_abx)
Standard DSP Array 1.0  (foo_dsp_std)
another crash
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 3EC3E38Ch
Access violation, operation: write, address: 3EC3E38Ch
Code bytes (3EC3E38Ch):
3EC3E34Ch:  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3EC3E35Ch:  00 00 00 00 1D A2 DB 84 76 B0 9A 08 00 00 00 00
3EC3E36Ch:  2F 00 00 00 08 00 00 00 68 E3 C3 3E 8C E3 C3 3E
3EC3E37Ch:  0E 00 00 00 13 00 00 00 00 00 00 00 00 00 00 00
3EC3E38Ch:  8B F7 B8 60 EB 31 23 50 B8 60 7F B2 04 5B DD 00
3EC3E39Ch:  DD 1B C3 E3 C3 3E B8 E3 C3 3E 05 00 00 00 B8 C4
3EC3E3ACh:  E3 C2 3E 05 00 00 00 B8 58 E8 31 23 10 00 00 00
3EC3E3BCh:  B8 58 E8 31 23 50 B8 C4 E3 C2 3E 5B DD 00 DD 1B
Stack (08FEE9E8h):
08FEE9C8h:  00000000 00000000 00000000 00000000
08FEE9D8h:  00000000 00000000 00000000 00000000
08FEE9E8h:  04AEF970 00000001 04B114E0 08FEEA1C
08FEE9F8h:  08FEEA0C 04B11508 00000F04 7EFA6000
08FEEA08h:  3EC3E38C 00000001 04B114E0 00000000
08FEEA18h:  04B11508 08FEEC40 04AEDCB2 3EC3E38C
08FEEA28h:  18332FB8 04AF25BF 3EC3E370 08FEF214
08FEEA38h:  00000034 04B071B0 00000000 00000000
08FEEA48h:  00000000 00000000 00000000 00000000
08FEEA58h:  00000000 00000000 00000000 00000000
08FEEA68h:  00000000 00000000 00000000 00000000
08FEEA78h:  00000000 00000000 00000000 00000000
08FEEA88h:  00000000 00000000 00000000 18332FB8
08FEEA98h:  00000000 00000000 00000000 00000000
08FEEAA8h:  00000000 00000000 00000000 00000000
08FEEAB8h:  00000000 00000000 00000000 00000000
08FEEAC8h:  00000000 00000000 00000000 00000000
08FEEAD8h:  00000000 00000000 00000000 00000000
08FEEAE8h:  00000000 00000000 00000000 00000000
08FEEAF8h:  00000000 00000000 00000000 00000000
Registers:
EAX: 3EC3E38C, EBX: 04B11520, ECX: 7EFA6000, EDX: 00000F04
ESI: 04B114E0, EDI: 04B11520, EBP: 08FEEA1C, ESP: 08FEE9E8
Loaded modules:
wl_hook                          loaded at 00070000h - 00125000h
AM30400                          loaded at 001F0000h - 001FC000h
foo_cdda                        loaded at 00CC0000h - 00D01000h
foo_run                          loaded at 00E20000h - 00E4E000h
foo_uie_graphical_browser        loaded at 74780000h - 74814000h
foo_freedb2                      loaded at 00E70000h - 00EB0000h
foo_menu_addons                  loaded at 02910000h - 0296D000h
libmmd                          loaded at 02D30000h - 02FE1000h
foo_uie_lyrics                  loaded at 02C70000h - 02CCC000h
foo_abx                          loaded at 00F10000h - 00F41000h
foo_uie_elplaylist              loaded at 03230000h - 03297000h
foo_uie_vis_channel_spectrum    loaded at 032C0000h - 032FD000h
foo_input_std                    loaded at 03750000h - 0388C000h
foo_fileops                      loaded at 03300000h - 03346000h
foo_converter                    loaded at 03420000h - 0348C000h
foo_lastfm_radio                loaded at 03350000h - 03396000h
foo_rgscan                      loaded at 03490000h - 034EB000h
foo_uie_panel_splitter          loaded at 039D0000h - 03A1F000h
foo_ui_columns                  loaded at 03CD0000h - 03E02000h
foo_uie_quicksearch              loaded at 03A20000h - 03A66000h
foo_uie_trackinfo_mod            loaded at 03F80000h - 03FD6000h
foo_ui_std                      loaded at 042E0000h - 043B4000h
foo_albumlist                    loaded at 03FE0000h - 0404B000h
foo_dsp_std                      loaded at 03F20000h - 03F68000h
foo_playback_custom              loaded at 04060000h - 040A5000h
foo_unpack                      loaded at 03990000h - 039BD000h
vis_avs                          loaded at 04AC0000h - 04B3B000h
MSVFW32                          loaded at 74830000h - 74853000h
AVIFIL32                        loaded at 74760000h - 74779000h
ADVPACK                          loaded at 74730000h - 7475E000h
convolution                      loaded at 07360000h - 07370000h
fyrewurx                        loaded at 07370000h - 07384000h
multifilter                      loaded at 07390000h - 07396000h
texer                            loaded at 073B0000h - 073B7000h
texer2                          loaded at 073C0000h - 073CB000h
atiumdag                        loaded at 68170000h - 68522000h
atiumdva                        loaded at 68BE0000h - 6902F000h
DSOUND                          loaded at 746C0000h - 74730000h
POWRPROF                        loaded at 69FE0000h - 69FFA000h
Address: 04AEF970h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04B114E0h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04AEDCB2h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04AF25BFh, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04B071B0h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04B050F6h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04B071D0h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04AF3E97h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 0008DC9Ah, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 0011B8E0h, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 00100D68h, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 00100D98h, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 0008EA5Ah, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 000862E9h, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 0011B3A8h, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 001012B8h, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 0009BC4Ah, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 00100008h, location: "wl_hook", loaded at 00070000h - 00125000h
Address: 04AF5BB4h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04B071E8h, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Address: 04AFFECFh, location: "vis_avs", loaded at 04AC0000h - 04B3B000h
Version info:
UNICODE
Windows 6.0
Additional info:
Curaçao by Br3tt
Hmmm, I changed all the foo_path and pictures path but I don't get Track Info and artist picture working. :/
Nevertheless Curacao looks really really great, but it's less practical for me.
Very nice work Br3tt.
Curaçao by Br3tt
I zipped up my complete Plugins folder which has got the latest versions of Milkdrop 2 and 8,606 presets (literally  )
It's about 65MB RAR'd down to 17MB, if anyone wants it...  http://rapidshare.de/files/40889036/Plugins.rar.html
It seems you will need Shpeck 0.3.0 Beta 2 to use Milkdrop 2.0e now the problem being it does not dock into the space it just floats in it's own window how do I change that?
