111 Pages V  « < 43 44 45 46 47 > »
Closed TopicStart new topic
Foobar Gallery, Everyone post your foobar
Sandman2012
post Jun 14 2005, 16:53
Post #1101
QUOTE (mazy @ Jun 14 2005, 03:45 AM)
my "temporary" setup, i'm too lazy to make better one with my custom string ...
Is that the Track info across the top there? I really like that idea of the big title across the top like that. smile.gif
mazy
post Jun 14 2005, 17:15
Post #1102
QUOTE (Sandman2012 @ Jun 14 2005, 04:53 PM)
yes, it is wink.gif. i like that too ... i have 3 different track info panels (just hex-edited their guids). hopefully next version will support multiple instances with separate config and font configuration directly in formatting.
info about my tag guesser script for foo_lua (preview version available):
http://www.hydrogenaudio.org/index.php?showtopic=16987
fabiospark
post Jun 14 2005, 19:48
Post #1103
Do you mean you tweaked the dll so now you can have 3 different panels each one with its own tagz and formatting?
I've been asking this many times.........
mazy
post Jun 14 2005, 20:54
Post #1104
QUOTE (fabiospark @ Jun 14 2005, 07:48 PM)
yep. it's here if you want it, but it's easy to do that by yourself. only problem is that they all have same name, so it takes some time to learn which panel is which. there has been better version of 2nd track info panel, complete re-compile with changed name etc, but it's not working as it should.
This post has been edited by mazy: Jun 14 2005, 20:56
Strictly4me
post Jun 15 2005, 01:37
Post #1105
New Player-Buttons with new icons, named "GANT Stock" and made by "Mattahan" <--- visit his page on deviantART
Download
((((( Strictly4me )))))
synth7
post Jun 15 2005, 03:46
Post #1106
mitchmalibu
post Jun 15 2005, 04:05
Post #1107
QUOTE (synth7 @ Jun 15 2005, 04:46 AM)
could you share your track info config please ?
emei
post Jun 15 2005, 08:10
Post #1108
untl55
post Jun 15 2005, 08:15
Post #1109
Indeed, very nice setup, synth7.
btw, what font are you using there?
enjoilax
post Jun 15 2005, 08:35
Post #1110
QUOTE (emei @ Jun 15 2005, 02:10 AM)
If its possible sir i would kindly like of you to give me your track info code please. biggrin.gif
rudefyet
post Jun 15 2005, 08:44
Post #1111
I like my foobar simplistic
http://www.rudefyet.com/foobar.jpg
although i am thinking of changing some colors in the playist
This post has been edited by rudefyet: Jun 15 2005, 08:45
synth7
post Jun 15 2005, 09:15
Post #1112
mitchmalibu and untl55, sure
Font: Arial Unicode MS 7pt
Background: R: 48, G: 48; B: 53
// Setup //
$puts(discinfo,$trim($if(%disc%,'(''Disc '%disc%[' '''%discname%'']')',)))
$puts(spacer,ffffffּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּ$char(10))
$puts(spacer2,ּ )
$puts(headline,$rgb(255,255,255))
$puts(main,$rgb(208,128,16))
$puts(info,$rgb(185,185,185))
$puts(text,$rgb(255,255,255))
$puts(grayed,$rgb(150,150,150))
$puts(gaincolor,$rgb(110,170,210))
$puts(streamcolor,$rgb(120,210,110))
$puts(size,5)
// Progress Bar
$puts(progress_length,68)
$puts(progress_color1,$rgb(208,128,16))
$puts(progress_color2,$rgb(195,195,195))
$puts(progress_char,■)
$puts(progress_color1a,$blend($get(progress_color1),$rgb(0,0,0),1,4.5))
$puts(progress_color2a,$blend($get(progress_color2),$rgb(0,0,0),1,5.7))
$puts(progressbar,
$puts(progress,$muldiv(%_time_elapsed_seconds%,$get(progress_length),%_length_seconds%))
$transition($repeat($get(progress_char),$get(progress)),$get(progress_color1a),$get(progress_color1))
$transition($repeat($get(progress_char),$sub($get(progress_length),$get(progress))),$get(progress_color2a),$get(progress_color2))
// OUTPUT //
$get(info)Mode: $get(text)$caps(%_trackinfo_mode%)$char(10)
$if(%_length%,$char(1)C$get(headline)d2aa6e▪ 9a7030▪ 705123▪ 1080d0P R O G R E S S705123 ▪ 9a7030▪ d2aa6e▪$char(10),)
$if(%_length%,$char(1)C$get(progressbar)$char(10),)
$if(%_length%,$get(spacer),)
$if(%_length%,
$char(1)C$get(headline)d2aa6e▪ 9a7030▪ 705123▪ 1080d0S O N G I N F O705123 ▪ 9a7030▪ d2aa6e▪$char(10),
$char(1)C$get(headline)d2aa6e▪ 9a7030▪ 705123▪ $get(streamcolor)S T R E A M I N F O705123 ▪ 9a7030▪ d2aa6e▪$char(10)
$if(%title%,$get(spacer2)$get(info)'Title:' $get(main)$caps(%title%)$char(10),)
$if(%artist%,$get(spacer2)$get(info)Artist: $get(text)$caps(%artist%)$char(10),)
$if(%_length%,,$get(spacer2)$get(info)'Listened For:' $get(streamcolor)%_time_elapsed%$char(10))
$if(%_length%,,$get(spacer2)$get(info)'Bitrate:' $get(streamcolor)$if2($pad(%__bitrate_dynamic%,3)'kbps',$if2(%__bitrate%'kbps',))$char(10))
$if(%_length%,,$get(spacer2)$get(info)'Location:' $get(streamcolor)$replace(%_path_raw%,%_filename_ext%,)$char(10))
$if(%album%,$get(spacer2)$get(info)Album: $get(text)%album%[ $get(grayed)$get(discinfo)]$char(10),)
$if(%tracknumber%,$get(spacer2)$get(info)Track: $get(text)$num(%tracknumber%,2)$char(10),)
$if(%genre%,$get(spacer2)$get(info)Genre: $get(text)%genre%$char(10),)
$if(%date%,$get(spacer2)$get(info)Date: $get(text)[%date%]$char(10),)
$if(%_length%,$char(1)C$get(headline)d2aa6e▪ 9a7030▪ 705123▪ 1080d0S T A T I S T I C S 705123 ▪ 9a7030▪ d2aa6e▪$char(10),)
$if(%__codec%,$get(spacer2)$get(info)Codec: $get(text)[%__codec%]$char(10),)
$if(%__bitrate%,$get(spacer2)$get(info)Bitrate: $get(text)$if(%__lame_profile%,1080d0--%__lame_profile%,%__bitrate% Kbit/s) $get(grayed)['('%__lame_version%')']$char(10),)
$if(%_time_total%,$get(spacer2)$get(info)Time: $get(text)%_time_elapsed% / %_time_total%$char(10),)
$if(%__samplerate%,$get(spacer2)$get(info)Samplerate: $get(text)%__samplerate% Hz$char(10),)
$if(%__replaygain_track_gain%,$get(spacer2)$get(info)Track Gain: $get(gaincolor)$cut(%__replaygain_track_gain%,$get(size)) dB$char(10),)
$if(%__replaygain_album_gain%,$get(spacer2)$get(info)Album Gain: $get(gaincolor)$cut(%__replaygain_album_gain%,$get(size)) dB$char(10),)
$if(%_filesize%,$get(spacer2)$get(info)Filesize: $get(text)$div(%_filesize%,1048576).$left($num($muldiv($mod(%_filesize%,1048576),1000,1048576),3),2)' MB'$char(10),)
$if(%__referenced_file%,$get(spacer2)$get(info)'CUE Reference:' $get(streamcolor)%__referenced_file%$char(10),)
$get(spacer)
// END //
blammo
post Jun 15 2005, 12:52
Post #1113
Kenny
post Jun 15 2005, 16:21
Post #1114
QUOTE (blammo @ Jun 15 2005, 12:52 PM)
wow nice! could you plz zip and upload your foobar-folder (without playlists folder)? foobar is standalone so i can get your complete settings.
i can give you ftp access if needed
emei
post Jun 15 2005, 17:11
Post #1115
//Colors, etc.
$puts(info_box_size,34)
$puts(default_color,ffffff)
$puts(leading_color,949494)
$puts(heading_color_l,ffffff)
$puts(heading_color_r,ffffff)
$puts(is_playing_color,ffffff)
$puts(len,43)
$puts(music,♪)
///////Song
// $transition( $repeat(,$add($get(info_box_size),4)),$get(heading_color_l),$get(heading_color_r))
// $char(10)$char(10)
$get(leading_color) TITLE: $get(is_playing_color)$replace(%title%,'(',6c8e93'(',')',')'$get(is_playing_color),'[',6c8e93'[',']',']'$get(is_playing_color))$char(10)
$get(leading_color) ARTIST: $get(default_color)%artist%$char(10)
$get(leading_color) ALBUM: $get(default_color)$iflonger(%album%,33,$cut(%album%,29)...,%album%) $if(%disc%,949494CD%disc%,)$char(10)
$get(leading_color) DATE: $get(default_color)%date%$char(10)$get(leading_color)
$get(leading_color) GENRE: $get(default_color)%genre%$char(10)
// $char(10)
///////Tech
// $transition(Tech Info $repeat(,$add($get(info_box_size),4)),$get(heading_color_l),$get(heading_color_r))
$get(leading_color) CODEC: $get(default_color)%__codec% $get(leading_color)$char(10)
$get(leading_color) BITRATE: $get(default_color)$if(%__lame_profile%,97cddd--%__lame_profile%,%__bitrate% 949494kbps)$char(10)
$get(leading_color) FILESIZE: $get(default_color)$div(%_filesize%,1048576).$left($num($muldiv($mod(%_filesize%,1048576),100,1048576),2),2)' 949494MB'$char(10)
// $get(leading_color)FILENAME: $get(default_color)$ifgreater($len(%_filename_ext%),$sub($get(len),14),$right(%_filename_ext%,$sub($get(len),14)),%_filename_ext%)$char(10)
// $get(leading_color)CHANNELS: $get(default_color)$caps($if($stricmp($codec(),MP3),%__mp3_stereo_mode%,$channels())) $get(heading_color_l)$if(%__samplerate%,%__samplerate% Hz,)$char(10)
$get(leading_color) LENGTH: $get(default_color)[%_time_elapsed% / ][%_length%] [949494'('%_time_remaining%')']$char(10)
$progress2(%_time_elapsed_seconds%, %_time_total_seconds%, 19,ffffff'█',9a9a9a'█')
just a modded version of someone else's. but i'm glad someone likes my config biggrin.gif
This post has been edited by emei: Jun 15 2005, 17:21
eliazu
post Jun 15 2005, 19:29
Post #1116
QUOTE (Kenny @ Jun 15 2005, 05:21 PM)
i would like that too.
mitchmalibu
post Jun 15 2005, 20:15
Post #1117
Cosmo
post Jun 15 2005, 20:19
Post #1118
QUOTE (mazy @ Jun 14 2005, 02:54 PM)
Besides editing the GUID, I also -
1) rename the dll to trackinf2.dll
2) around offset #6990, change "trackinfo.dll" to "trackinf2.dll"
3) around offset #6B10, change "Track info panel" to "Track info pnl-2"
4) around offset #6CA8, change "Track info" to "Track inf2"
- repeat process for panel # 3 ...etc.
- then the additional panels have new names in the menus ... works great smile.gif
tool++
post Jun 15 2005, 21:04
Post #1119
My foo: now in red.
Yeah, I'm happy because my win box looks like a copy of Knoppix STD (bblean + Twice style).
Ala..
moderation: please refrain from inlining images larger than roughly 800x600 and 80KB. please use thumbnails and/or links for large pictures instead. try PNG instead of JPEG for smaller filesize.
hi
blammo
post Jun 15 2005, 21:21
Post #1120
QUOTE (eliazu @ Jun 15 2005, 10:29 AM)
Sorry! I dont think the Foobar licence allows me to distribute my Foobar folder. However if you are interested I could try and post my Playlist tree and Columns IU configs.
This post has been edited by blammo: Jun 15 2005, 22:34
mj-barton
post Jun 16 2005, 04:18
Post #1121
Yes, please. I would like that--especially the Playlist tree. I thinks its the .col file.
This post has been edited by mj-barton: Jun 16 2005, 04:20
blammo
post Jun 16 2005, 06:48
Post #1122
QUOTE (blammo @ Jun 15 2005, 12:21 PM)
Its here (slightly modified)
playlist_tree.col
grindlestone
post Jun 16 2005, 09:04
Post #1123
Strictly4me
post Jun 16 2005, 10:09
Post #1124
QUOTE (blammo @ Jun 16 2005, 06:48 AM)
playlist_tree.col
LNCPapa
post Jun 17 2005, 04:39
Post #1125
Yes - fix linky please - very interested.
No mercy for the bandwidth impaired
RSS Lo-Fi Version Time is now: 19th September 2014 - 11:38
