2 Pages V   1 2 >
Headphone preamp on soundcard, Required or not?
Tripwire
post Jun 18 2003, 14:55
I got my Aureon 7.1 today, and it actually has a dedicated headphone preamp on the PCB (my old Audigy apparenly didnt). Now, when I set the master volume to 50%, I got my desired volume on the headphone, and seems to sound OK. When I turn on the preamp, it almost blows my head and the headphones at 50%. I need to turn the volume down to 10% when using the preamp to get the same perceptual volume as without.
Now the thing is, do I really NEED to use the preamp on headphones? Does it affect the quality using it or not?
indybrett
post Jun 18 2003, 15:27
Group: Members (Donating)
QUOTE (Tripwire @ Jun 18 2003 - 08:55 AM)
I have the Prodigy 7.1, which is the same card re-branded. I have to use the amp with my Sony V6 phones, and they are relatively easy to drive.
I would say that it depends on the sensitivity and impedance of the headphones that you are trying to drive.
Edit: let me know if you have any static/crackling problems. I downgraded from XP to Win2K and the problem seems to have gone away. Not sure yet.
This post has been edited by indybrett: Jun 18 2003, 15:29
flac>fb2k>kernel streaming>audiophile 2496>magni>dt990 pro
Tripwire
post Jun 18 2003, 15:58
I only hear my DVD drive spinning up and down, that's it, no crackling whatsoever. I'm running the Win2k3 360day Trial though.
sthayashi
post Jun 18 2003, 16:37
QUOTE (Tripwire @ Jun 18 2003 - 05:55 AM)
My guess is, with those headphones, probably not.
However, there are some high end headphones that DO require pre-amping, like the Sennheiser HD-600s, which have a 300 Ohm nominal impedence. That means that it takes a bit more power to drive it than your typical headphone, which probably have a nominal impedence of about 32 Ohms or so.
So, I wouldn't worry about it too much if it sounds pretty good without the amp.
Tripwire
post Jun 18 2003, 17:01
Ok, thanks!
RIV@NVX
post Jun 18 2003, 18:53
QUOTE (indybrett @ Jun 18 2003 - 04:27 PM)
What kind of crackling? Just curious.
indybrett
post Jun 18 2003, 19:42
QUOTE (RIV@NVX @ Jun 18 2003 - 12:53 PM)
Pretty bad, actually. You'll know it if you here it. Severe distortion.
Tripwire
post Jun 18 2003, 23:15
Blergh. I get noise when moving the transparent window frame around on window moving. :/
--edit: On 88200 and 96000 stuff
This post has been edited by Tripwire: Jun 18 2003, 23:22
indybrett
post Jun 19 2003, 00:18
QUOTE (Tripwire @ Jun 18 2003 - 05:15 PM)
Yes, exactly. Same problem I had. So it is (probably) the card after all, or the driver. I have switched back to Win2000. The problem is not as bad.
Edit: mine would crackle even at 48000
This post has been edited by indybrett: Jun 19 2003, 00:31
picmixer
post Jun 19 2003, 00:34
Am having those exact same problems with my Terratec SixPack as well. Static and very faint noises when moving things in the Windows (XP) GUI. Already wrote to the Terratec Support about it a few days ago. Didn't think it woud have to do with the OS though. Already tried moving the card to different PCI slots and that did not help either.
indybrett
post Jun 19 2003, 01:33
QUOTE (picmixer @ Jun 18 2003 - 06:34 PM)
I already wish I had bought the M-Audio...
Win2000 does not completely eliminate the problem, but it does seem to be a lot better than XP. I'll need to stress test it for a week.
Even so, I don't plan on running Win2K forever.
I had tried changing slots, changing IRQ's, changing drivers, etc.
Audiotrak suggested I change the latency. That didn't help. I suspect that there is a hardware problem here that can not be fixed with a driver.
I'll let you know how it works after a week with Win2K. One other thing to note is that my motherboard has a VIA chipset. Not sure if that matters.
Edit: spelling
This post has been edited by indybrett: Jun 19 2003, 01:38
indybrett
post Jun 19 2003, 03:01
Well, I just tried ripping a CD with EAC while listening to some MPC files. Started getting static immediately.
I set the latency to 1024 and the static stopped. Changing the latency did not help in XP, but seems to in Win2K.
Tripwire
post Jun 21 2003, 15:06
QUOTE (indybrett @ Jun 18 2003 - 03:18 PM)
I had no issues while listening to music when the box is under heavy load. Even with tons of screen refreshes per second. Just when moving windows around (Transparent frame, no contents). I can scroll a huge HTML page in IE tons of times up and down as fast as I can, no issues. Games with +100fps, no issues. Just moving the window frame on screen. That's the weirdest thing.
As said though, I run the Win2k3 Server trial. Newer kernel and base system than XP.
--edit: VIA 694D here.
This post has been edited by Tripwire: Jun 21 2003, 15:08
indybrett
post Jun 21 2003, 15:26
I after my CD ripping experience, I started to wonder why EAC was maxing out my cpu. Started thinking, and decided to download and install the VIA 4in1 drivers.
That solved that problem.
I still get some static from moving windows, but it is much less, and much less often. XP was really bad. Win2K with the VIA drivers is much better.
I think that if I had a different motherboard, and a current model CPU (I have a P3-800), the problem might go away completely.
I was planning to upgrade my MB and CPU soon anway. Probably be about a month before I do.
picmixer
post Jun 22 2003, 15:30
Post #15
QUOTE (indybrett @ Jun 21 2003 - 04:26 PM)
Don't want to discourage you. But I run a fairly recent system (Gigabyte 7VAXP Ultra, Athlon XP 2200, 512 MB RAM) and have those same problems you mentioned (Windows XP though).
indybrett
post Jun 22 2003, 15:45
Post #16
I looked up that board. Also a VIA chipset. Maybe just a coincidence.
It would be nice to hear from someone who has that card on a motherboard that doesn't have a VIA chipset to see if they have any problems.
Probabably will take some time for the card to be more widely used before we get more feedback.
picmixer
post Jun 22 2003, 15:48
Post #17
As I said, Iam running not exactly the same card as you do. Mine is a Terratech SixPack. But the problems I am suffering from are exactly the same ones as you do with your Prodigy aka Aureon 7.1.
Xenno
post Jun 22 2003, 16:17
Post #18
I don't know what you guys are using for players, but what playback mode are you using? As I'm sure y'all know, there's WaveOut, DirectSound, ASIO, and Kernel Mode. I've tried WO, DS, and Kernel. DS has worked the best. I'm using a 700 MHz PIII, with W2k (SP3), Turtle Beach soundcard (Montreal?) and Media Center set to DS. With the slider (more skip resistant <> more responsive) moved almost all the way over to more responsive, I get pops & clicks only when I run an intense application. To date, that's been one (Rhinocerous...a 3D modeler). It occurs when the cursor snaps to the grid or to object points (end, center, mid, etc.).
I did notice on a couple new Dells (2.56 GHz P4's running W2k) that when playing a CD from their RW drives (using Foobar), playback would pop everytime the disk was accessed. Changing playback mode did not help (so I left it set to DS). The solution was not to play CD directly from the drives. If they were mine, as God as my witness, I would have fixed it.
xen-uno
No one can be told what Ogg Vorbis is...you have to hear it for yourself
- Morpheus
picmixer
post Jun 22 2003, 16:22
Post #19
The static has nothing to do with what player I use. It is there constantly, wether any player is active or not. It will even be present if I mute the Headphone volume in the control panel. There are no issues when using the line out with any player.
Xenno
post Jun 22 2003, 16:32
Post #20
That is strange. Sounds like a ground problem but how could that be when it's in contact with the grounded case (plus it would probably show up where ever an analog signal leaves the card). Bad headphone implementation?
xen-uno
- Morpheus
picmixer
post Jun 22 2003, 16:39
Post #21
QUOTE (Xenno @ Jun 22 2003 - 05:32 PM)
Probably. But then switching back from Win XP to Win 2K seemed to really have improved things for Indybrett.
picmixer
post Jun 24 2003, 19:28
Post #22
Well, I decided to go for the most practical solution here and dug out a mixing panel. Got that plugged in to the line out of my soundcard now and take the headphones from the mixer. Problem solved, although not as intended it's still a good sollution and I don't have to break my head anymore about getting a new soundcard, or trying to fix a problem on the old one, that should not be there in the first place.
Can finally enjoy my music again without constant annoying static in the background.
SNYder
post Jun 24 2003, 19:56
Post #23
i had static problems using Windows XP too when I had my Terratec DMX 6Fire. Had it for about 5 months before I returned it. This was last year some time. I went a few months without a soundcard and in january I got the M-Audio Revolution. Now all is good smile.gif
GenjuroXL
post Jun 24 2003, 19:57
Post #24
Disabling line-in in the soundcard mixer worked wonders against crackling/static here. (Windows XP, Terratec DMX Xfire 1024)
indybrett
post Jun 24 2003, 20:37
Post #25
Anybody want to buy my Prodigy 7.1? PM me if you're interested.
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 18th September 2014 - 12:32
