IPB
> Hydrogenaudio Forum Rules
- No Warez. This includes warez links, cracks and/or requests for help in getting illegal software or copyrighted music tracks!
- No Spamming or Trolling on the boards, this includes useless posts, trying to only increase post count or trying to deliberately create a flame war.
- No Hateful or Disrespectful posts. This includes: bashing, name-calling or insults directed at a board member.
- Click here for complete Hydrogenaudio Terms of Service
Partitions, like 'em, hate 'em, what say you?, Split from Topic ID: 73235
odigg
post Jul 9 2009, 16:06
Post #1
Group: Members
QUOTE (andy o @ Jul 9 2009, 10:48) *
Actually, I'd say do NOT rip to C: (or wherever your OS resides). One nasty corruption, and you'll need another computer to extract your music (or anything else of value), whereas if you have it on another partition/disk, you can just reinstall your OS if you need to.
Backups on a separate drive my friend, backups! For whatever reason, some people dislike multiple partitions on the computer. My spouse wants a C: drive and that's it!
Go to the top of the page
+Quote Post
kornchild2002
post Jul 9 2009, 16:17
Post #2
Group: Members
I don't like having multiple partitions on a drive either. I always burn the backup partitions for my netbooks to a DVD and then reformat the entire drive giving me an extra GB or two. This may not sound like a lot but it really comes in handy for netbooks with 16GB or 32GB SSDs where every GB counts (a 16GB SSD will often give people 11-12GB of storage by the time the partition is added, that isn't a whole lot). Asus also likes to split their 160GB hard drives into two ~75GB partitions, it annoys the hell out of me.
I don't mind having multiple hard drives though. One drive used for primary operation and then another one used to store all of my media and as a backup for my primary drive.
+Quote Post
Tahnru
post Jul 9 2009, 19:34
Post #3
Group: Members
QUOTE (odigg @ Jul 9 2009, 10:06) *
I have found Windows' ability to map partitions to an empty folder to be very handy for this. One C drive for the user, multiple drives in reality.
+Quote Post
pepoluan
post Jul 13 2009, 14:41
Post #4
Group: Members
I personally partition the first (physical) drive into 2 partitions: 25 GiB for the system, rest for non-program non-system
The next (physical) drives are all formatted into a single partition.
Nobody is Perfect.
I am Nobody.
http://pandu.poluan.info
+Quote Post
PaJaRo
post Jul 27 2009, 19:40
Post #5
Group: Members
If you can add different hard disks (instead of partitioning) it will be great, however it is not always possible (it's expensive and some laptops can only handle 1 hard disk).
Since I'm a linux user, I need at least 2 partitions / and swap. I also have a /home partition, so If i run out of space on my home it won't affect my system stability.
Here you can check the Debian recommended partiotioning scheme http://www.debian.org/releases/stable/i386/apcs03.html.en . Note that in multiuser systems the recommendation is create up to 6 different partiotions: /, swap, /home, /usr, /var, /tmp.
So, I neither hate 'em or like 'em. In some cases partitioning is recommended and also a good practice, but other times it could be a little bit annoying.
+Quote Post
OmniCbex
post Oct 10 2009, 00:44
Post #6
Group: Members
If the computer that I am using only has one hard disk, I create a partition just for the OS and programs, and another one to save any media or documents. The upside to this is that you don't need to worry about losing those files if you need to reinstall the OS later. This method fails if the hard disc crashes though- you lose both partitions. Another con is that you kind of need to guess at about how much space you will need on C: for the OS and programs as this can be hard for a novice user and depends on your personal situation. Multiple hard disks (one physical hard drive for the OS, and one or more physical hard disks for media and saved documents) are a step up although if something happens to the whole computer (theft, fire, flood, ect.) then you are still screwed, or the document and media hard disk can still fail, losing all your work. Obviously the best tried-and-true fail-safe is to create a back-up of the media and documents outside of the computer (flash drive, dvds, ect.) every so often.
It's due for a good DEGAUSSIN'
+Quote Post
Conrado
post Dec 12 2009, 13:28
Post #7
Group: Members
Large HD: Three primary partitions. C: 32GB, D: 128GB E: rest of disk. C for system only, D for software, E for data.
+Quote Post
Meeko
post Dec 24 2009, 22:19
Post #8
Group: Members
One partition on the C: drive of my laptop. No point in breaking it into pieces with two external harddrives (one as a mirror of the C:) and the other as a backup. I've never seen a need for multiple "pieces" on a harddrive. Never had a harddrive fail on me (and you'd lose the whole drive, partitioned or not). So really, what benefit is there?
foobar2000, FLAC, and qAAC -V68
It just works people!
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 30th August 2014 - 18:25
