6 Pages V  « < 2 3 4 5 6 >
Closed TopicStart new topic
flac 1.3.0 pre-release
hidn
post Mar 17 2013, 13:16
Post #76
anyway, slower and less compression than flaccl
This post has been edited by hidn: Mar 17 2013, 13:17
Case
post Mar 17 2013, 13:58
Post #77
Group: Developer (Donating)
QUOTE (ktf @ Mar 14 2013, 21:49) *
Other news: The FLAC git has seen some changes on 2GB file limits on Windows. I didn't full understand the mailing list conversation, but apparently the limit was raised to 4GB and this can't be fixed until 1.3.1.
The fix has no such limits. Only API wasn't allowed to be changed, but that affects nothing but FLAC__metadata_simple_iterator_get_block_offset function. That means this function won't work if there's more than 2 GB worth of metadata. I have tested the modified code with 20 GB FLAC files without trouble.
Edit: I added experimental Unicode support to flac.exe last night. If anyone wants to experiment you can download this.
This post has been edited by Case: Mar 17 2013, 13:59
ktf
post Mar 18 2013, 09:11
Post #78
QUOTE (Case @ Mar 17 2013, 13:58) *
Great stuff, can't wait to see it make it into git! Thanks!
lvqcl
post Mar 18 2013, 15:31
Post #79
QUOTE (Case @ Mar 17 2013, 16:58) *
Does -o option work? Because when I use "flac -6 in.wav -o out.flac" it creates in.flac and outputs:
in.wav: wrote 21869264 bytes, ratio=0,731
ERROR: output file in.flac already exists, use -f to override
If -f is added, it encodes the file three times.
IgorC
post Mar 18 2013, 20:17
Post #80
QUOTE (ktf @ Mar 13 2013, 10:57) *
So now new FLAC decoder decodes -8 preset faster than old decoder -0 preset.
Not bad.
db1989
post Mar 18 2013, 23:00
Post #81
QUOTE (Case @ Mar 17 2013, 12:58) *
[coded support for files >2/4 GB and Unicode]
Also, more speed-ups? Great, but as if it wasn’t far enough ahead of all the competition already. tongue.gif
This post has been edited by db1989: Mar 18 2013, 23:02
Case
post Mar 19 2013, 20:56
Post #82
QUOTE (lvqcl @ Mar 18 2013, 16:31) *
Thanks for testing. I had missed a couple of functions that took filenames. Appropriate fixes have been made and my own quick testing found no more problems.
I updated the archive with latest changes and added metaflac in too. It contains the same unicode and wildcard treatment.
Porcus
post Mar 19 2013, 23:27
Post #83
15 percent increase in decoding speed? It is hardly much compared to how CPU power has evolved over the years, but still cool in the 'just because one can' department. (After all, this is the yardstick I have been evaluating other codecs against; can it touch FLAC on both speed and compression simultaneously?)
birdie
post Apr 4 2013, 11:44
Post #84
I've compiled FLAC 1.3 pre3 with GCC 4.8 (vanilla) on i686 but it keeps crashing:
Program received signal SIGSEGV, Segmentation fault.
(gdb) bt
#0  0x08078685 in FLAC__bitreader_read_rice_signed_block_asm_ia32_bswap.c0b0 ()
#1  0x00000000 in ?? ()
Compilation flags used are:
-O2/-O3 -pipe -march=native
(I've got an Intel Sandy Bridge CPU)
I configured it this way:
./configure --enable-sse  --disable-shared --enable-static
birdie
post Apr 4 2013, 11:52
Post #85
It also crashes when compiled with GCC 4.5.4 without "--enable-sse".
It also crashes when I used "-O2 -pipe".
OK, I give up, I've just compiled it with "-O0 -g" and it just doesn't work at all:
file.flac ERROR got FLAC__STREAM_DECODER_ERROR_STATUS_FRAME_CRC_MISMATCH while decoding FLAC input
file.flac ERROR: while decoding FLAC input, state = FLAC__STREAM_DECODER_SEARCH_FOR_FRAME_SYNC
I run flac this way:
./flac -f -8 -Ax2 --replay-gain -V *.flac
(This is how my files were originally compressed).
I even removed most flags:
./flac -f -V *.flac
The errors persist (STREAM_DECODER_ERROR).
Guys, is some magic required to compile the new FLAC? It seems totally broken.
This post has been edited by birdie: Apr 4 2013, 11:56
birdie
post Apr 4 2013, 12:02
Post #86
GIT version has the same problems.
Sigh.
chi
post Apr 4 2013, 18:38
Post #87
QUOTE (birdie @ Apr 4 2013, 11:52) *
Why are you trying to do a static build?
ktf
post Apr 4 2013, 18:43
Post #88
Static building never worked for me, but if you build shared, the flac utility will be static anyway (you'll have to run the script src/flac/flac and use src/flac/.libs/lt-flac after that), which does work here.
This release was mainly meant to fix built issues, so building should actually be easier.
chi
post Apr 4 2013, 19:57
Post #89
QUOTE (ktf @ Apr 4 2013, 18:43) *
Thats not actually true, lt-flac is still dynamically linked. Libtool only makes sure that the uninstalled libFLAC is being used:
$ ldd src/flac/.libs/lt-flac | grep FLAC
    libFLAC.so.8 => /home/chi/devel/flac/_bd/src/libFLAC/.libs/libFLAC.so.8 (0x00007f419de57000)
Unlike a statically linked binary, this will stop working if moved (it may either silently use the system-wide library, if there is any, or fail).
ktf
post Apr 4 2013, 22:28
Post #90
QUOTE (chi @ Apr 4 2013, 20:57) *
That’s not actually true
Oh right, I've been fooling myself apparently. huh.gif Sorry for talking BS, thanks for the warning.
This post has been edited by ktf: Apr 4 2013, 22:36
Case
post Apr 6 2013, 12:27
Post #91
The problems birdie has look very much like broken hardware to me. Bad memory stick could easily trigger such behavior.
I uploaded fresh Win32 binaries of 1.3pre3 + git fixes here.
ktf
post Apr 8 2013, 09:07
Post #92
QUOTE (Case @ Apr 6 2013, 13:27) *
These are with the UTF-8 runtime patches you made? There are still problems with them (it actually got worse). I tested them on Windows XP SP3 and Windows 7 SP1, and I got this when used on three files, one with Cyrillic, one with Arabian and one with Japanese text.
See these screenshots:
http://www.icer.nl/misc_stuff/flac-130pre3-test.png
http://www.icer.nl/misc_stuff/flac-130pre3-test2.png
It seems it doesn't remove enough characters (doesn't empty the line completely) before writing a new step.
Case
post Apr 8 2013, 11:09
Post #93
Ouch, thanks. I used such tiny files in testing that the verification finished too fast to show this problem. I'll fix it.
Case
post Apr 8 2013, 19:40
Post #94
Fixed the bug and repeating line bug with long filenames. Compiled version can be downloaded here.
ktf
post Apr 8 2013, 20:06
Post #95
QUOTE (Case @ Apr 8 2013, 20:40) *
We're getting there Case! Great job, finally the characters show up. However, I still have a bug to report. I can't catch it in screenshots this time.
Suppose I run flac.exe with 2 files, like flac.exe -t αβγδε.flac ζηθι.flac The first file shows up correctly:
flac 1.3.0pre3 [...]
αβγδε.flac: testing, 56% complete
However, the second filename is not displayed
αβγδε.flac: ok
testing, 12% complete
When finished, it does show the filename correctly:
αβγδε.flac: ok
ζηθι.flac: ok
Another bug is the following: when a file doesn't exist, flac returns the next message
αβγδε-n.flac: ERROR initializing decoder [...]
However, metaflac.exe returns something else:
αβγδε-n.flac: ERROR: reading metadata, status = "FLAC__METADATA_CHAIN_STATUS_ERROR_OP
ENING_FILE"
However, when the file exists, it works perfectly.
Still, I can't stress this enough, this is a *HUGE* improvement over no UTF-8 support at all, many thanks for fixing this smile.gif
This post has been edited by ktf: Apr 8 2013, 20:07
Case
post Apr 8 2013, 20:57
Post #96
I should hire you as my personal beta-tester. I reverted the long-line repeating fix as it obviously needs much more work. Here's a fresh set with above bugs fixed: flac-1.3pre3-mod.zip
eahm
post Apr 9 2013, 20:59
Post #97
New Winamp 5.70 Build 3364 Beta 4
* Updated: [libFLAC] FLAC 1.3.0
Isn't too early to integrate FLAC 1.3.x?
edit:
Tag 1.2.1 20070917, same as the "Pre" versions.
This post has been edited by eahm: Apr 9 2013, 21:33
SpaceAgeHero
post Apr 9 2013, 21:22
Post #98
QUOTE (eahm @ Apr 9 2013, 21:59) *
benski
post Apr 10 2013, 00:34
Post #99
Winamp Developer
QUOTE (eahm @ Apr 9 2013, 14:59) *
edit:
It's a beta release of Winamp. It's a good opportunity to test the FLAC release.
It's also worth mentioning that a vast majority of the changes for 1.3.0 were in the build scripts and the various tools. The core libFLAC library only received a minor amount of changes.
Case
post Apr 10 2013, 08:29
Post #100
I uploaded a test binary with properly made long filename display fix. In my own testing it performs now correctly, but perhaps ktf could give it a try before I send patches to flac dev list. Download at the usual location.
RSS Lo-Fi Version Time is now: 31st July 2015 - 23:51
