New with CD Software Question
JackSprat
post May 27 2010, 22:44
I recently found this forum looking to answer a question I have regarding my CDs.
I have about 125 CDs that have tracks divided into "sub-tracks" called indexes; and I'm looking for a way to get these indexes as separate tracks or computer files.
This is proving to be quite a challenge. I was able to find out it has something to do with what are called "PQ subcodes" on the CD; and I managed to find software (called DiscJuggler) that used this feature to identify these indexes, including the starting point, ending point, and duration. Unfortunately, it did not allow me to pull out the individual indexes into their own audio files or CD tracks.
There are (very expensive) programs that work with CDs in a database, but my CDs are not in any database; and I could not afford to spend hundreds of dollars if they were.
I'm wondering if anyone is aware of any program (preferably for Windows XP or Vista) that will do what I am looking to do in terms of "extracting" individual indexes?
If not, is there a program that would allow me to type in the index information (start time, length, etc.) I can get from DiscJuggler to isolate those particular parts of the CD?
greynol
post May 27 2010, 23:09
Exact Audio Copy
Action menu: Copy Selected Tracks Index-Based
DVDdoug
post May 27 2010, 23:20
...and I'm looking for a way to get these indexes as separate tracks or computer files.
I don't know how to do this automatically, but you can split/join tracks with an audio editor. (i.e. You can rip the entier CD to a single WAV file and split it up as you choose.)
Some popular audio editors:
Audacity (FREE)
GoldWave ($50 USD)
Adobe Audition ($350 USD)
I've never done anything special with indexes, but I've frequently edited the individual tracks from a "live" CD in order to fade-in and fade-out the crowd noise/applause. (I use GoldWave.)
JackSprat
post May 27 2010, 23:52
QUOTE (greynol @ May 27 2010, 17:09) *
Exact Audio Copy
I tried that on my PC with Vista, and it did not correctly or consistently recognize the indexes (other than 0 and 1). Where it did find those or any others, it gave me some error saying ""Filename construct does not contain track number '%N'." I could not figure out what that meant. I suppose I'll give it a try on my XP machine and see if I get the same problem.
greynol
post May 27 2010, 23:59
Based on all the reported problems I've seen with EAC and post-XP OSes (typically 64-bit versions), I'm not surprised.
It could be that your discs don't actually have indices >1, or your drive is not capable of determining them correctly with EAC. I would try a different drive if you have one first. I would then check the each gap detection method and also adjust the accuracy level if necessary, though it might not have any effect.
Otherwise you might need to rip as a single-file image, manually edit the cue sheet and re-split by index, or use a wave editor as DVDdoug suggested. If I were to manually edit the cue sheet, I would still probably use a wave editor to determine the index points, making sure to configure it so that is displays time in CDDA format (75fps).
This post has been edited by greynol: May 28 2010, 00:04
JackSprat
post May 28 2010, 00:40
I tried again using XP, and it does properly recognize the indexes as shown on a CUE sheet. However, I got the same error ("Filename construct does not contain track number '%N'") when I used "copy selected tracks index-based." Does anyone know what that error means?
I have used Audacity, and I can do so as a last resort. I was just hoping for something a little simpler and more precise.
greynol
post May 28 2010, 00:42
Yeah, put %N somewhere in your naming scheme:
EAC Options -> Filename tab
Here's mine:
%D\%C\%N - %T
Sorry I didn't tell you this earlier.
JackSprat
post May 28 2010, 03:32
QUOTE (greynol @ May 27 2010, 18:42) *
Here's mine:
%D\%C\%N - %T
RSS Lo-Fi Version Time is now: 2nd June 2015 - 16:45
