IPB
Dupe finder+grouping, Preferably based on acoustic fingerprinting
odyssey
post Apr 21 2010, 22:17
Post #1
Group: Members
I have quite a large library from buying a LOT of used CD's over time and therefore also many dupes of different kind. Most dupes I won't really get rid of, but just mark as "unsuitable for shuffle-playback" due to:
* seamless transitions on albums or crossfades on compilations
* different cuts of basically the same song (radio edit/album version/extended etc)
* slightly different masterings, remasters etc
* simply too many dupes (they occur too often)
... you probably get the idea
My biggest headache in this is different naming. I know I could "just" fix the tags, but still that's a lot of music and too many days of work and I haven't even decided with myself if a "standard"-version of a song on a single should be tagged as "radio edit" when the album version is completely identical. So to find all the dupes, the best way to do it would be a tool that uses acoustic fingerprinting. We have that with foo_biometrics smile.gif Unfortunately, my experience with it is that it often avoids identical songs also found in the library and I've also experienced large groups of false positives in the same search that returns neatly grouped dupes.
So to the question: Does anyone know of any other similar dupechecker? At least a dupechecker that can correlate a similarity threshold based on tags at least and group them together so I can (load them into foobar2000 and) decide for myself what to do with them?
(Note: Has to support FLAC's)
Go to the top of the page
+Quote Post
Teknojnky
post Apr 21 2010, 22:40
Post #2
Group: Members
music ip mixer might be helpful, but its pretty much been abandoned and no longer supported
http://www.amplifindmusicservices.com/what/downloads.php
Last.FM Nodes for your library @ http://build.last.fm/item/356
+Quote Post
sauvage78
post Apr 21 2010, 23:22
Post #3
Group: Members
I am also searching something similar, in my case (a collection only made of CDImage.flac with the offset "fixed" to the highest in the AR database) something that would grab all the already existing flac MD5 checksums of the audio data & compare them would be the perfect tool.
A while ago I had the idea of comparing .accurip with a classic dupe finder (non-audio specific) as I have fixed all the offset to the highest in database, so that I instantly find doublon if I open 2 .accurip manually. The problem is that the .accurip keeps record of the date/hour so it prevents me from being able to compare all my .accurip between each other as the date is always different (the increase in confidency is not really a problem as I can do it all within a month). If I don't find a better way I am wondering if I will not search for a software (a batch .txt editor) to erase the 1 line [Verification date: XX/XX/XXXX XX:XX:XX] of all my .accurip (after I renamed them as .txt), then I could finally compare them "easyly" ... as you see the idea is very tricky when the right tool for the job could do it in one click ...
Even if it's a complete waste of time to destroy all my . accurip to find doublons & then recheck a month later ... I guess that in my case (several teraoctets) it would be faster/easier than doing it manually.
This post has been edited by sauvage78: Apr 21 2010, 23:47
CDImage+CUE
Secure [Low/C2/AR(2)]
Flac -4
+Quote Post
odyssey
post Apr 22 2010, 00:04
Post #4
Group: Members
Thanks for the suggestion. I was very optimistic about MIP - I used it some time ago as a background service to create nice mixes. However, I couldn't make it find "dupes" until i added a copy of the files on a different location to it, so it doesn't seem to use it's nice fingerprinting technique for that sad.gif
+Quote Post
Robertina
post Aug 2 2010, 16:24
Post #5
Group: Banned
I just discovered a freeware called Similarity.
As yet I have not tried it myself and I don't know whether it would suit your needs in detail but I thought I should mention it because it looks promising with its configuration options and support for mp3, flac, WavPack and other formats.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 2nd February 2015 - 00:16
