Topic: ffmpeg vs. SoX for resampling (Read 35243 times) previous topic - next topic
I just found out that TAudioConverter, although it has SoX support, uses ffmpeg for bitdepth changes, resampling, and dither. I don't use those functions very much, but I'm curious if anyone has done a quality comparison between the two.
I’m no authority, but there’s always good old http://src.infinitewave.ca/
SoX 14.4.0:
Let’s, er, let’s hope FFmpeg has evolved by leaps and bounds since that version was released only about half a year ago.
It has, it now uses SoX
January, 7, 2013, FFmpeg 1.1
We have made a new major release (1.1) It contains all features and bugfixes of the git master branch. A partial list of new stuff is below:
- SOX Resampler support in libswresample
You have to give a command-line option though:
http://ffmpeg.org/trac/ffmpeg/wiki/FFmpeg%...SoX%20Resampler
SoX 14.4.0:
FFmpeg 0.10.4:
Well, FFmpeg is now up to version 1.1.1, and Peter has incorporated it into fb2k, so I think we can assume the program's improved. Whether it's improved for this functionality is another question. Of course, there's a 14.4.1 version of SoX just out, too.
I did notice the large disparity in version numbers between 0.10.4 and now, but I found that 0.10.6 was released as recently as October, so I had to emphasise that the resampling may or may not have had the massive improvements that it so blatantly needs.
Edit: I just saw bandpass’s post, which I missed due to jkauff posting in the interim. Phew! That’s a relief.
Oddly, SoX itself is a little behind the curve: 14.4.1 contains the same (slow, by comparison) version of the resampler that's been there for some years, so until SoX 14.5 is released (couple of months I think), the ffmpeg route will give better performance (about 2-3 x faster).
Don't know if it made it into 1.1.1 or not, but I saw that ffmpeg has also recently ported (most of) SoX's dither code.
Downloaded TAC(0.7.5.938)(portable).7z. It contains FFmpeg version N-49352-gc46943e built on Jan 26 2013 (Zeranoe build).
And this build wasn't compiled with --enable-libsoxr option, so TAudioConverter resampling should be similar to FFmpeg 0.10.4 from post#2.
... (slow, by comparison) ...
I am not sure speed is the correct measure of quality.
The conversion quality is the same (graphs for the newer version are @ infinitewave under Audacity 2.0.3); the performance is higher cos it's faster than before.
Zeranoe takes ffmpeg build requests at: http://ffmpeg.zeranoe.com/forum/viewforum.php?f=10
Regardless of different options and builds, something has to be done about the standard of resampling demonstrated by that graph.
I've posted a request for a ffmpeg build with libsoxr support to the link bandpass supplied. I'm waiting for a response.
Quoting the FAQ:
Are most SRCs really that bad?
No. If you look at the decibel scale to the right from the graphs, you can see that the range of these graphs is very wide: down to -180 dB. The distortions generated by most properly designed SRCs are below -100 dB and can hardly create audible artifacts. However SRCs differ in the transition band of the low-pass filter and in the amount of pre-/post-echo and aliasing. The bottom line is that most tested SRCs range from fairly good to excellent, but the graphs are very sensitive to emphasize the differences.
Seems to me that those reflections of the actual input signal may still be quite a bit above –96 dB. Does that fall within the remit of “properly designed SRCs”? Even the background static does not look far below –100 dB.
Besides, even if that explanation were applicable, is it really anything other than hand-wringing when there is no real excuse for the algorithm to perform to such a poor standard? Other free programs can resample with many, many times less noise. Why give a free pass to some SRCs just because their distortions might not be audible? Again: “might”.
I thought this was a site that focusses on perceptual quality, sure, but doesn’t skimp on theoretical quality when there’s no good reason to do so.
the noise floor on a CD is around -110 dB, considering that the spectrogram display shows a power spectral density, not the waveform level. So, the regular 16-bit dithering noise is actually represented by this color. Here is the graph of the CD noise floor with a standard TPDF dither:
+ a thread about ffmpeg resampling: http://www.hydrogenaudio.org/forums/index....showtopic=79106
FFmpeg native is even worse going the other way (i.e. upsampling); here's a look at the latest (1.1.1):
96k 0dBFS -> 44100
Artefacts at around -75 (ignoring the main alias).
44100 0dBFS -> 96k
Artefacts at around -67 (ignoring the main image) and easily audible in the last second.
No surprises when using ffmpeg's soxr option:
and it's around 3 times faster than the native one.
It would be good if FFmpeg could drop the native resampler completely, but it's still needed for drift compensation in some circumstances (between async clocks on 2 soundcards, I think).
That's a fascinating site.
I'm curious though, why are some so bad? It doesn't look like anyone should need to reinvent the wheel so to speak, as there are amazing open-source (SoX) and proprietary (Adobe Audition) options, and hell, even Apple CoreAudio from 5 years ago is decent.
http://src.infinitewave.ca/images/Tone/ffmpeg.png
ffmpeg's resampler isn't that bad but some lines are at -105 -100 dB which is a bit above inaudible threshold (-110 dB).
Obviously SoX has much more headroom.
These spectral peaks are not bad only for a 1 kHz tone, but they get much worse for higher-frequency tones (as can be seen on a spectrogram).
Highest setting of Apple CoreAudio resampler has really (unnecessarily) high SNR, but is 10x or more slower than SoX (at least on Windows).
And even Microsoft resampler of Windows Media Foundation (CLSID_CResamplerMediaObject) has reasonablly good quality / performance, but read this bug on Win7 WaveOut:
http://www.hydrogenaudio.org/forums/index....st&p=788882
It seems that their left hand doesn't know what the right hand is doing.
I see there already is a new build with libsoxr support
zeranoe kindly supplied it after my request.
So, where is TOS#8 when everyone agrees on looking at graphs? Not trying to troll, I just smell some bigottery.
Unless someone claims that there is an audible difference, I don't have a problem with looking at spectra.
