Easiest way to convert my flac files using the ffmpeg library?
Fractal_Mortalit...
post Apr 27 2011, 03:36
This is an odd request, but I use audiogalaxy, which has problems with libFLAC, but not ffmpeg. I was wondering if there's a program that would make it easy to convert my flac library using ffmpeg?
http://www.last.fm/user/magnumforce2006
Fandango
post Apr 27 2011, 05:08
Uhm, is it that Audiogalaxy? The one which was one of the first peer-to-peer music sharing services in the 90s?
Anyway, a little bit of more information about what it is that you are actually trying to do would be helpful. Convert FLAC to what for example?
Fractal_Mortalit...
post Apr 27 2011, 05:39
QUOTE (Fandango @ Apr 27 2011, 00:08) *
I'm actually converting flac to flac. But instead of using LibFlac, I want to use ffmpeg (which is what Audiogalaxy uses to decode).
btw, audiogalaxy is actually a streaming service now... You can stream your whole music collection to your android device and what have you: http://audiogalaxy.com/
Kohlrabi
post Apr 27 2011, 09:20
The program making it easy to convert FLAC with ffmpeg is... ffmpeg. You can use it as a command line encoder for say foobar2000 or EAC with no problems:
ffmpeg -i inputfile -vn -sn -acodec flac out.flac
You can specify "-aq x" to tune the compression ratio at the cost of compression speed.
To use it as command line encoder in foobar2000 you can use pipes:
ffmpeg -i - -vn -sn -acodec flac %d
I'm still unsure what the point of converting FLAC to FLAC really is, though.
This post has been edited by Kohlrabi: Apr 27 2011, 10:09
Ceterum censeo Masterdiskem esse delendam.
_mē_
post Apr 27 2011, 10:21
ffmpeg & copy /b in.flac out.flac
Fractal_Mortalit...
post Apr 27 2011, 16:39
Aight. Sorry to be such a noob, but I really am when it comes to encoding... where would I get the ffmpeg. exe to use in foobar?
Justin Ruggles
post Apr 27 2011, 16:59
QUOTE (Fractal_Mortality @ Apr 27 2011, 10:39) *
you can try http://win32.libav.org/
and you can use the -compression_level option for better compression. the -aq option has no effect, as quality is not an issue since flac is lossless.
Fractal_Mortalit...
post Apr 28 2011, 03:12
I'm just going to post a screen of my setup for the encoder:
And here's what happens when I try to convert
no idea what I'm doing wrong here, lol
This post has been edited by Fractal_Mortality: Apr 28 2011, 03:12
marc2003
post Apr 28 2011, 08:00
try removing "ffmpeg" in the parameters - the encoder dialog is already pointed directly at the .exe file.
This post has been edited by marc2003: Apr 28 2011, 08:02
Kohlrabi
post Apr 28 2011, 09:17
QUOTE (Justin Ruggles @ Apr 27 2011, 17:59) *
You sure that -aq isn't mapped to compression level? Damned if ffmpeg doesn't try to keep its option names consistent. mad.gif Let's hope libav will have proper documentation of options.
This post has been edited by Kohlrabi: Apr 28 2011, 09:20
Fractal_Mortalit...
post Apr 28 2011, 11:56
QUOTE (marc2003 @ Apr 28 2011, 03:00) *
That worked, thanks
Justin Ruggles
post May 1 2011, 16:19
QUOTE (Kohlrabi @ Apr 28 2011, 03:17) *
I'm sure. -compression_level is for lossless, -aq is for lossy. I'll try to add an entry in the Libav docs for the flac encoder at some point in the near future.
RastaMan
post Oct 10 2011, 04:07
Tried, over and over again to use the 'compression_level switch in FFmpeg to convert a file to FLAC at a certain compression level. Totally uselsss. File size was the same no matter what level I chose. Switch doesn't work at all. Docs I've seen at their web site say nothing about FLAC, or any other lossless codec. IMO, if people want to use FFmpeg to do lossless conversion, they should just say no. Total waste of time.
Justin Ruggles
post Oct 12 2011, 22:04
QUOTE (RastaMan @ Oct 9 2011, 23:07) *
It works just fine for me. Always has. I use avconv now, but the commandline options are still the same as ffmpeg.
avconv -i test.wav -compression_level 1 -y test.flac
bitrate= 798.7kbits/s
avconv -i test.wav -compression_level 12 -y test.flac
bitrate= 715.8kbits/s
What is the command are you're using?
danutz
post Dec 17 2013, 06:55
Post #15
QUOTE (Justin Ruggles @ Oct 12 2011, 23:04) *
Sorry for the zombie thread, but I've searched for a long time and the above is the answer: -compression_level must occut after -i. Amazingly, if you put the level before -i, it gets ignored (and the default FLAC compression_level of 5 gets used). I've searched for the answer for quite a while, as I have to convert m4a's to flac's losslessly (and I prefer the smaller size of course).
This post has been edited by danutz: Dec 17 2013, 06:55
Kohlrabi
post Dec 17 2013, 08:16
Post #16
QUOTE (danutz @ Dec 17 2013, 06:55) *
It gets ignored, because options before the -i are options regarding the following input file, not the output file:
ffmpeg <inputoptions> -i infile <inputoptions2> -i infile2 ... <outputoptions> outfile
This post has been edited by Kohlrabi: Dec 17 2013, 08:22
RSS Lo-Fi Version Time is now: 22nd September 2014 - 07:52
