> Upload forum rules
Pathological example of a intersample peak, 11dB
Rescator
post Jan 10 2013, 04:27
Pathological example of a intersample peak that was artificially created:
~0dB peak, ~20dBFS RMS (squarewave), +10.87dB intersample peak, 44.1KHz, 32bit float.
Discussion thread for this sample: http://www.hydrogenaudio.org/forums/index....showtopic=98753
The red line is 0dBFS, the white line is -1dBFS, even without oversampling one can see the intersample peak is at ~+8.5dBFS, and settles on +10.87dBFS after 2x (or more) oversampling.
This post has been edited by Rescator: Jan 10 2013, 04:45
Attached thumbnail(s)
Attached File(s)
"Normality exist in the minds of others, not mine!" - Rescator
bandpass
post Jan 11 2013, 14:02
Probably not a big problem for the test you are doing, but your input sample is a bit weird -- not even vaguely symmetrical. Here's a way to generate a clean input sample:
sox -r 44100 -n InterSamplePeak2.wav synth 220501s 0 25 sin 22050 repeat 1 fade h 5 10 5
Rescator
post Jan 14 2013, 00:17
Here is a CSV with the result from a scan I did.
The MD5 and CSV was created by a quick tool I made myself, the actual stats was gathered with Sox using the following params. (thanks again bandpass for your sox knowhow).
sox.exe file.wav -n stats upsample 4 sinc -a 40 -t 8k -24k stats
The two stats (peak and rms of the first stats, and the peak from second stats with a +12.04 adjustment to counter the attenuation during the upsampling in sox)
Here follows just one example of the numbers you can do on the attached csv data. Have fun. (PS! the MD5 id is local to the scan/csv file only)
CSV format is: id,peak,rms,isp
peak and rms and isp are all relative to 0 dBFS (0dBFS = +1.0 or -1.0 floating point).
5824 tracks.
Peak -1.18 dBFS (Min -28.03, Max 0.00)
ISP -0.45 dBFS (Min -28.02, Max 9.54)
ISP/Peak Delta -1.63 dB (Min -56.05, Max 9.54)
RMS -16.89 dBFS (Min -46.18, Max -6.34)
27.59% ISP <-1 dBFS
72.41% ISP >-1 dBFS
44.33% ISP -1 to 0 dBFS
19.95% ISP 0 to 1 dBFS
3.71% ISP 1 to 2 dBFS
0.79% ISP 2 to 3 dBFS
0.21% ISP 3 to 4 dBFS
0.34% ISP 4 to 5 dBFS
0.31% ISP 5 to 6 dBFS
1.56% ISP 6 to 7 dBFS
1.18% ISP 7 to 8 dBFS
0.00% ISP 8 to 9 dBFS
0.02% ISP 9> dBFS
Attached File(s)
RSS Lo-Fi Version Time is now: 6th March 2015 - 14:42
