19 Pages V  « < 17 18 19
Channel Mixer (foo_channel_mixer)
lvqcl
post Jul 22 2012, 10:39
Post #451
QUOTE (noway @ Jul 22 2012, 11:03) *
I'm not sure what DH is but from what i understand it's a VST modelling algorithm built into the firmware of some devices.
It is also available in some software DVD players such as PowerDVD. And there is DH wrapper component.
noway
post Jul 22 2012, 13:01
Post #452
TB IsoneSurround.
In internet you can find jb isone pro surround v1.0.1, which works without limitations.
Thanks!!
JB Isone Pro Surround is brilliant. I even managed to calibrate it for my UE5 earphones!
CMSS3D is limited to headphones only. As for DH and TB IsoneSurround -- just tested them; they're overall tolerable, but i certainly wouldn't use them for music since they enforce reverberation and it always makes a mess out of music :)
flyingsaucer
post Oct 3 2012, 12:02
Post #453
Hi Skipyrich,
I'm a request for you could you please create a VST version of your Channel Mixer foobar2000?
I think it's a very good plugin for stereo upmix; There's nothing on the web like yours. It would be possible feed with your VST a dolby digital headphone wrapped dll (six channel input and two channel output).
With a VST HOST in this way we could give dolby digital to everykind of audio card to whole system with ASIO DRIVERS.
Best Regards
Tony
P.S.
Thank you in advance for your answer.
NinjaGaijin
post Nov 17 2012, 07:50
Post #454
Hi, I hope someone can answer this for me..
I set 'convert mono to stereo' for a mono flac file I had, then forgot I had the DSP set.
All the files since then have been stereo.. I've probably processed 100 tunes.. will all these be converted one (Left?) channel of the files into dual mono now?
I always delete my flacs after I extract them to wav files, so that would suck sad.gif
Does the plugin check if the file is stereo before attempting the mono to stereo DSP?
edit: a quick look in winamp at some wav's I created seem to be proper stereo files.. confirmation would be nice though smile.gif
This post has been edited by NinjaGaijin: Nov 17 2012, 08:00
http://soundcloud.com/ninja-gaijin
fouinix
post Dec 10 2012, 20:04
Post #455
Hi!
First of all, big thanks for this powerfull plugin!
But (sorry) I have a problem, I can't save settings. I want to increase center volume, after a restart all settings are reseted even if I save them in "default" profile. I also tried to create a new profile but they are reseted after a restart.
Here is the report :
Core (2012-11-25 10:24:36 UTC) foobar2000 core 1.1.18
foo_albumlist.dll (2012-11-25 10:23:28 UTC) Album List 4.5
foo_audioscrobbler.dll (2010-06-04 07:27:04 UTC) Audioscrobbler 1.4.7
foo_cdda.dll (2012-11-25 10:23:06 UTC) CD Audio Decoder 3.0
foo_channel_mixer.dll (2011-06-01 17:18:00 UTC) Channel Mixer 0.9.6.7
foo_converter.dll (2012-11-25 10:23:02 UTC) Converter 1.5
foo_dsp_std.dll (2012-11-25 10:23:20 UTC) Standard DSP Array 1.0
foo_dsp_vstwrap.dll (2009-05-11 16:08:58 UTC) George Yohng's VST Wrapper 1.2
foo_fileops.dll (2012-11-25 10:21:52 UTC) File Operations 2.2
foo_freedb2.dll (2012-11-25 10:23:32 UTC) Online Tagger 0.7
foo_input_monkey.dll (2011-02-24 10:13:54 UTC) Monkey's Audio Decoder 2.1.5
foo_input_std.dll (2012-11-25 10:23:00 UTC) Standard Input Array 1.0
foo_playcount.dll (2012-06-11 18:09:57 UTC) Playback Statistics 3.0.2
foo_rgscan.dll (2012-11-25 10:22:36 UTC) ReplayGain Scanner 2.1.2
foo_ui_std.dll (2012-11-25 10:22:46 UTC) Default User Interface 0.9.5
foo_unpack.dll (2012-11-25 10:23:00 UTC) ZIP/GZIP/RAR Reader 1.6
I only use this DSP :
Equalizer
Channel mixer
I'm under Seven 64bits.
Any idea?
This post has been edited by fouinix: Dec 10 2012, 20:07
fouinix
post Dec 10 2012, 20:20
Post #456
I tried to delete foo_channel_mixer.dll.cfg in my profile folder. Then restart, increse center volum => fb2k write a new foo_channel_mixer.dll.cfg. Then restart => channel mixer settings reseted.
konradoo77
post May 24 2013, 15:52
Post #457
Hi!
I've a strange problem with foo_channel_mixer and foobar(last and older version also). I've 5.1 setup and upmix from stereo to 6 channels. When I'm change track subwoofer sound disappear and only solutions is restart foobar. Everything work with keyboard UP-DOWN selections and ENTER as a start playback key but not with mouse double click. With first play after start the program, I've a subwoofer sound everytime and only changing manually with mouse have this issue. I've try a clean instalation of windows and foobar, onboard Realtek and USB Maya U5 soundcard, different chanell mixer, foobar settings also WASAPI ASIO KS DirectSound but not luck.
My setup is Acer 5930g laptop, Maya U5 DAC with analog 5.1 speakers, Windows 7 x64.
Any ideas, someone have a similar problem?
oo131193oo
post Feb 22 2014, 13:15
Post #458
right now I'm mixing up my stereo music to 6 channels for my headphones.
Everything sounds great.
But i have to wait long time for changes for example on the speaker configuration
to be applied.
Is that normal?
It normally takes ~7 seconds to change the settings.
My system:
- Gigabyte h77 d3h
- xeon e3 1230 v2
Rollin
post Feb 22 2014, 13:24
Post #459
QUOTE (oo131193oo @ Feb 22 2014, 16:15) *
This time depends on output buffer size. File->Preferences->Playback->Output->Buffer length
This post has been edited by Rollin: Feb 22 2014, 13:25
oo131193oo
post Feb 22 2014, 15:55
Post #460
QUOTE (Rollin @ Feb 22 2014, 13:24) *
RSS Lo-Fi Version Time is now: 22nd July 2014 - 23:50
