16 Pages V   1 2 3 > »
Resampler plugin, uses SoX 14.2.0 resampling routines
lvqcl
post Nov 19 2008, 03:45
Uploaded here
Good quality, fast resampler (~2 times faster than PPHS Ultra, although ~2.5 times slower than regular PPHS). Minimum / intermediate / linear phase.
Any comments?
Added: If you want to know what settings are best:
1. Read SoX FAQ, "What are the best 'rate' settings to resample a file and retain the highest quality?"
2. This post: http://www.hydrogenaudio.org/forums/index....st&p=626176 (an excerpt from SoX help)
3. Feel free to experiment and decide what's best for you.
This post has been edited by lvqcl: Apr 10 2009, 20:37
patul
post Nov 19 2008, 06:41
Downloading now & will try soon. I use SSRC however. Do you have any detailed comparison between your SoX based resampler vs PPHS, SSRC??
This post has been edited by patul: Nov 19 2008, 06:44
AFAIK
post Nov 19 2008, 13:19
well... somebody made this test
http://src.infinitewave.ca/
Canar
post Nov 19 2008, 16:00
Now does this resampler use the "High" or "Very High" setting?
Thanks for the component, by the way.
You cannot ABX the rustling of jimmies.
No mouse? No problem.
AFAIK
post Nov 19 2008, 18:46
I think i found a bug
when using in dsp chain and play a 22050Hz file, the playback time displayed in foobar is slower than it should be
and it sometimes even stall at 0:00
there might be something wrong...
btw. i love this component
lvqcl
post Nov 19 2008, 19:11
QUOTE (Canar @ Nov 19 2008, 18:00) *
SoX effect named "rate" has 5 quality presets: quick, low, medium, high, very high.
    |      Quality   Band-  Rej dB   Typical Use       |
    |                width                             |
    |-q     quick     n/a   ≈30 @    playback on       |
    |                        Fs/4    ancient hardware  |
    |-l      low      80%    100     playback on old   |
    |                                hardware          |
    |-m    medium     95%    100     audio playback    |
    |-h     high      95%    125     16-bit mastering  |
    |                                (use with dither) |
    |-v   very high   95%    175     24-bit mastering  |
Also, 'quick' and 'low' quality levels doesn't allow to override options like aliasing, steep filter and phase response. So I disabled them. I don't think that foobar users play music on ancient or old hardware wink.gif
lvqcl
post Nov 19 2008, 19:22
QUOTE (AFAIK @ Nov 19 2008, 20:46) *
Thanks, I'll investigate this.
Canar
post Nov 19 2008, 19:48
Please ignore my earlier comment. I missed the configuration somehow. This looks great!
vigylant
post Nov 19 2008, 22:28
QUOTE (AFAIK @ Nov 19 2008, 14:19) *
The SSRC is better than this component, right?
Because if you select Passband/Transition, you can see that the SSRC is more similar to the "ideal filter".
Foobar2000 @ Onkyo SE-90PCI @ Sennheiser HD595 :)
lvqcl
post Nov 19 2008, 23:27
QUOTE (vigylant @ Nov 20 2008, 00:28) *
I'm afraid that it isn't so simple. Look at:
http://www.hydrogenaudio.org/forums/index....ost&p=81050
http://www.hydrogenaudio.org/forums/index....ost&p=29125
But I don't know of the audibility of ringing at Nyquist limit.
Bug confirmed and (I hope lalala.gif) fixed. Updated version is available. Thanks!
vigylant
post Nov 19 2008, 23:45
But im wondering: What should i use for samplerate conversion? (From 44100 to 96000)
My soundcard (Onkyo SE-90PCI, highend stereo soundcard, VIA Envy24 chip) or this plugin, any idea which one is better?
Probably hard/impossible to tell without actually testing my soundcard tongue.gif
This post has been edited by vigylant: Nov 19 2008, 23:58
bandpass
post Nov 20 2008, 07:38
QUOTE (lvqcl @ Nov 19 2008, 22:27) *
lvqcl, good work with the port, and good pointers to some well informed posts. smile.gif
vigylant, the bandwidth of the SoX SRC is configurable up to 99.7% which pretty much matches that of SSRC (standard). But be aware, that the closer you get to the nyquist, the more artifacts you get; look closely at the transition graphs for the Shibatch SRC and you'll see that (esp. for the hp version) the transition lies to the right of the ideal filter's -- i.e. aliasing is occurring.
-bandpass
jaro1
post Nov 23 2008, 01:22
I had carefully compared this SRC, based on SOX 14.2.0 with other foobar resamplers and it is sonically the best resampler out there, IMHO of course. On this SRC I appreciate very low artifacts, frequency responce, good transition and very low noise floor.
Then I found this, maybe well known side yet (http://src.infinitewave.ca), which basically confirmed my experience. SOX with VHQ settings is according to this side for me in pair with iZ RX Advanced (High steepness), which is in some parameters maybe very slightly better, but has also a little higher noise floor, which is on sweep test result picture quite visible and therefore maybe for highend headphones or speakers also audible.
So many many thanks to the author for hard work and time for creating and uploading this free soft, which will certainly improve listening experience for people with low/medium quality sound cards/int. chips. To author, I intercede for future development of this great plug-in to make it even better, btw I didn't find any bugs in this version yet.
So thank you very very much again
Canar
post Nov 23 2008, 01:46
@jaro1: I am not convinced that you did, indeed, hear a difference. The quantifiable differences between PPHS and this resampler are below the threshold of human hearing. Please re-read our terms of service, paying attention to point 8.
That is not to diminish the efforts of the developer of this component. I am now using it myself for high quality work, due to the objective differences. Subjectively, however, I am not convinced it is possible to discern between PPHS and the SoX resampler. The site you cited primarily concerns itself with inaudible qualities.
hidn
post Nov 23 2008, 14:37
Post #15
question which I must ask. He as well as PPHS Ultra?
jaro1
post Nov 23 2008, 20:05
Post #16
QUOTE (Canar @ Nov 23 2008, 01:46) *
Because of very short time I could not write all circumstances of listening tests I'done, now I can only add, that I wasn't alone, there were three of us, loudspeakers-B&W Sig. Diamond; headphones - AKG K701.
But according to service terms you are absolutely right, but I wanted because of time shortness write something about our SUBJECTIVE observations and at least say thanks to the author, sorry for forum rules breaking and also for my bad english.
Jorgo
post Nov 23 2008, 20:23
Post #17
Group: Banned
This seems to be a very good resampler. From my limited understanding, it rivals the SSRC resampler but uses less CPU.
A visual comparison can be seen at
http://sox.sourceforge.net/SoX/Resampling
http://sox.sourceforge.net/rate-44k1-96k.png
The example of VERY HIGH (-v) looks almost the same as the Secret Rabbit result with -c0 and
Secret Rabbit -c1 looks very close to MEDIUM with 90% bandwidth (-mb 90). Other than that, I don't know enough to be able to interpret the impulse response per se.
Here are some more pointers from the SOX manual:
Quality Band-width Rej dB Typical Use
-q quick n/a ~=30 @ Fs/4 playback on ancient hardware
-l low 80% 100 playback on old hardware
-h high 95% 125 16-bit mastering (use with dither)
This post has been edited by Jorgo: Nov 23 2008, 20:26
hidn
post Nov 24 2008, 07:09
Post #18
someone who can compile and lay out icl version?
lvqcl
post Nov 27 2008, 20:16
Post #19
Version 0.3.0 is out. It seems that resampling routines are not thread-safe, so I changed them a little.
By the way, I think that "Resampler based on SoX 'rate' effect" is a bit awkward name. Any ideas how to name this plugin more elegantly?
Canar
post Nov 28 2008, 02:33
Post #20
SoX Resampler.
Resampler (SoX) in the DSP list.
.halverhahn
post Dec 31 2008, 13:36
Post #21
.halverhahn
Jorgo
post Mar 9 2009, 22:34
Post #22
Group: Banned
0.4.0... uh, what? Please don't rename stuff so it gets broken in the DSP setup... the names should be kept between updates.
lvqcl
post Mar 9 2009, 23:03
Post #23
QUOTE (Jorgo @ Mar 10 2009, 00:34) *
jaro1
post Mar 10 2009, 11:00
Post #24
Hi, I know it's a little offtopic, but I wanted to ask lvqcl to something, because I suppose he knows SOX internal routines quiet good yet.
Would it be possible in the future make a plugin, which implements SOX deemphasis filter? (deemph: ISO 908 CD de-emphasis (shelving) IIR filter)
Till now I use for it wav impuls responses with FB2Ks Convolver plugin, but this isn't a right choice according to this german page:
http://www.radonmaster.de/robernd/tAFILTER.html (thanks to author and Surfi for the link)
On this side there are packed wav signals, with explanation, for testing different deemphasis filters ( there is also filter of old SOX version, which results very badly, it altered also stereo image... )
Filter from recent SOX version is perfect, but solution with Convolver plugin (whatever impulse I use) alters a signal after closser look in Audition quiet a lot from what it should do, although frequencygoing could be very close and therefore after listening undistinguishable.
For me is use of Convolver plugin, at least for this purpose, a little unpractical and ultimately inaccurate, so therefore this idea. By the way, it may or may not be a problem, but I think SOX deemph filter has 32bit internal precision, which is, on the other side, for this kind of operation absolutely necessary.
Once more, sorry for offtopic and thanks for your opinion.
This post has been edited by jaro1: Mar 10 2009, 11:48
lvqcl
post Mar 10 2009, 17:56
Post #25
QUOTE (jaro1 @ Mar 10 2009, 13:00) *
Seems strange for me. Try to use this impulse: deemph_SoX.wav
I tested SoX and Convolver with my impulse: difference between them is about -130 dB. So convolver is quite accurate.
And don't use "Auto level adjust" option.
This post has been edited by lvqcl: Feb 14 2013, 16:19
RSS Lo-Fi Version Time is now: 20th December 2014 - 09:26
