Audigy SPDIF bypass
Guillaume
post Jun 9 2002, 14:10
Hi, I'm using the SB Audigy and record to MiniDisc through the Hoontech SBII bracket (TOSLink out). Now when one uses the Audigy Drive! the option 'SPDIF bypass' is available in AudioHQ. However, when using a non-Creative (like Hoontech's) extension the option is not available. How can I activate the bypass option manually??
What I had in mind is a Winamp plugin that uses this bypass option to create track marks: between two songs the bypass option is shortly enabled, which makes the MD stop recording and shortly after procede recording in a new track. Shouldn't this be possible??
Listen to Guillaume - EAC/MP3 Guide
I see seven towers, but I only see one way out...
JonPike
post Jun 10 2002, 04:37
Huh... wierd.
Sounds almost like there is some kind of hardware related switch that tells the card (and software) "I've got a external adapter plugged in" and the Hoontech isn't flipping it.
If that's so, you could (probably) pull up the right line on the interface (solder a resistor to the right place) on your Hoontech.. and it would just work..
Try for something about this in Hoontech or Creative or musician sound card forums.. or see if there's anything on Hoontech's site..
Sounds like your "recorder control" feature would work fine, as long as you can figure out how to get that feature working with your hardware..
Guillaume
post Jun 10 2002, 17:54
Thanks for the reply, but I wouldn't know on what forum to post this question. Creative sure won't help me sad.gif.
Pio2001
post Jun 10 2002, 20:49
Moderator
You can try http://hardforums.com/forumdisplay.php?forumid=33
Guillaume
post Jun 10 2002, 22:46
Thanks PIO, I posted the same thing I did here (http://hardforums.com/showthread.php?s=&threadid=424469). Hopefully somebody will be able to help me.
Guillaume
post Jun 17 2002, 16:16
Case
post Jun 17 2002, 16:23
Group: Developer (Donating)
You could try if kX Project drivers allow selecting the bypass regardless that the device is not from Creative. But I don't believe there is plugin that takes advantage of this for minidisc recording, you will have to resort using pause between tracks.
Guillaume
post Jun 17 2002, 21:10
Well, I already use these drivers, so that's no problem. But there has to be a programmer who would want to make such a thing rolleyes.gif
RSS Lo-Fi Version Time is now: 31st October 2014 - 19:09
