IPB
> foobar2000 Tech Support Forum Rules
Please read foobar2000 Tech Support Forum Rules before posting and comply with all the points.
Failure to provide all the information pointed out in the above document in your post is considered wasting other people's time and in extreme cases will lead to your topic getting locked without a reply.
See also: Hydrogenaudio Terms of Service.
How to adhere my tagging standard to comply with Foobar?, New to Foobar. Need Help.
metalive
post Jan 13 2008, 14:52
Post #1
Group: Members
Hi, I am very new to foobar, just started with the all new 0.9.5. I have been using Winamp5 for several years and have noticed that foobar reads some tags slightly different than Winamp, as I will explain:
My audio collection comprises of Oggs and MP3s. My tagging tool of choice was MP3Tag v2.33a and my tagging standard was as follows:
Oggs -> VorbisComment (what else?!)
MP3s -> only ID3v2 (ID3v1 and APEs removed)
When importing my files into foobar the year and track# become tricky problem children. My above mentioned tagging tool applies these tags to both Oggs and MP3s consistently as follows:
track = 03/11
year = 1969
Foobar interprets this as follows:
Oggs:
track = 03/11
totaltracks = ?
date = 1969
MP3s:
track = 03
totaltracks = 11
date = 1969
...and very strangely with some, but not all MP3s, and only displayed in this way in the playlist, not in selection properties:
date = 1969, 1969
What do I need to do to achieve consistency between Oggs and MP3s in foobar? And further question: Which tag type for MP3 should I use in future? Does it make sense to stick to only ID3v2 as I have been doing so far?
This post has been edited by metalive: Jan 13 2008, 14:56
Go to the top of the page
+Quote Post
Florian
post Jan 13 2008, 19:15
Post #2
Mp3tag developer
Group: FB2K Moderator (Donating)
I assume that you still have Mp3tag installed and if you continue using it, I suggest to update to the latest official release or the current Development Build.
To copy the total number of tracks to the TOTALTRACKS field within the Vorbis Comment you can again use an Mp3tag action 'Format values' for the field TOTALTRACKS with a format string %_total%
Afterwards you can remove the total number of tracks from the TRACK field by using an Mp3tag action 'Format values' for the field TRACKS with a format string $num(%track%,2)
I'm sure that you can also achieve this by using the Properties dialog from foobar2000, but I can't think of an easy solution right now (and I must admit that I'm also just more familiar with Mp3tag wink.gif).
Regarding the duplicate date field you can use the extended tag dialog from Mp3tag to remove the duplicate value (since it seems that the Properties dialog doesn't show duplicate fields with the same content).
And I think using only ID3v2 at MP3s is the right decision as long as you don't depend on hardware players that only read ID3v1.
Mp3tag - universal multi-format tag editor
http://www.mp3tag.de/en/
+Quote Post
Ydope
post Jan 15 2008, 16:48
Post #3
Group: Members
I had the similar issues with DATE/YEAR.
Maybe this post helps you with this problem: http://www.hydrogenaudio.org/forums/index....showtopic=32224
Greets
+Quote Post
metalive
post May 15 2008, 23:15
Post #4
Group: Members
Wonderful! With the lastest versions of Mp3Tag and foobar, this issue is history. Thanks!
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 3rd September 2015 - 08:46
