60 Pages V  « < 25 26 27 28 29 > »
WSH Panel Mod, foo_uie_wsh_panel_mod
marc2003
post Jan 19 2010, 17:31
Post #651
if you're using the script i posted the other day, it's my fault. crying.gif i'm reading the cached text file during window.repaint() rolleyes.gif i originally made the script without knowing how to scroll and my panel is locked in size so it didn't matter at the time. i really should have updated it. dry.gif
This post has been edited by marc2003: Jan 19 2010, 17:32
carmenm
post Jan 19 2010, 17:34
Post #652
QUOTE (marc2003 @ Jan 19 2010, 17:31) *
Yeah i corrected that. I also made sure that i measure the string height only when necessary. The time it takes to repaint is only due to the drawing itself
marc2003
post Jan 19 2010, 17:41
Post #653
whilst on the subject of that, i found this neat activex component to properly decode all special characters. use it like this....
ck = new ActiveXObject("CkString.StrFun");
try {
    text = xmlDoc.getElementsByTagName("content")[0].childNodes[0].nodeValue;
    text = ck.StripHtml(text);
    text = ck.HtmlEntityDecode(text);
} catch(e) {
    text = "This artist does not have a biography page on Last.fm.";
http://www.chilkatsoft.com/downloads.asp - ckstring, 2nd from the bottom. you need to register the dll using "regsvr32 ckstring.dll" in an administrator command prompt.
EDIT: question about gdi draw text array removed. using measure string instead.
This post has been edited by marc2003: Jan 19 2010, 18:17
carmenm
post Jan 19 2010, 22:50
Post #654
i need help with WshShell.run
i have that command
"C:/Program Files/AlbumArtDownloader/aad.exe" /sources "LastFM Artist" /ar "Bloc Party" /mn 500 /mx 1000 /path "D:/Martin/My Documents/My Music/LastFmData/Bloc Party.jpg"
i am launching it with WshShell.Run(command, 0, true); so that i wait for the result
but i never go to the next line :s
Yet the command works perfeclty in a cmd.
Does anyone have an idea of what might be the problem?
Is there any to get the output of the command in the console?
marc2003
post Jan 19 2010, 23:01
Post #655
use "cmd.exe /k c:\program...." to troubleshoot. this spawns a command prompt window and it keeps it open so you can see what happens. it's probably to do with escaping of quotes.
carmenm
post Jan 19 2010, 23:15
Post #656
ok something is really wrong, it doesnt open the command line :s
T.P Wang
post Jan 20 2010, 08:38
Post #657
Another way:
http://www.daniweb.com/forums/post658176.html#post658176
EDIT: found it in the Graphics. COuld you give us access to setClip TPWang?
It's already used before calling on_paint(gr);
You should stop using DT_CALCRECT in that case (or use with limited).
carmenm
post Jan 20 2010, 09:28
Post #658
QUOTE (T.P Wang @ Jan 20 2010, 08:38) *
Another way:
i cant get it to work. I have difficulties translating the function.
Yes it s a lot better! and i dont need DT_CALCRECT anymore as i know the size so thank you!
T.P Wang
post Jan 20 2010, 10:06
Post #659
function decodeXMLEntites(text) {
var xmlDoc = new ActiveXObject("MSXML.DOMDocument");
xmlDoc.async = false;
xmlDoc.loadXML("<sometext>" + text + "</sometext>");
if (xmlDoc.parseError.errorCode != 0) {
return "";
return xmlDoc.text;
fb.trace(decodeXMLEntites("&quot;Some text&quot;"));
carmenm
post Jan 20 2010, 11:15
Post #660
QUOTE (T.P Wang @ Jan 20 2010, 10:06) *
return "";
return xmlDoc.text;
thanks
marc2003
post Jan 20 2010, 14:13
Post #661
QUOTE (T.P Wang @ Jan 20 2010, 09:06) *
fine with plain text but when you have special characters.....
fb.trace(xmlDoc.parseError.reason);
Reference to undefined entity 'oacute'
T.P Wang
post Jan 20 2010, 14:28
Post #662
@marc2003:
Then try this:
var doc = new ActiveXObject("htmlfile");
doc.open();
var div = doc.createElement("div");
div.innerHTML = text;
return div.innerHTML;
carmenm
post Jan 20 2010, 14:49
Post #663
QUOTE (T.P Wang @ Jan 20 2010, 14:28) *
@marc2003:
Then try this:
doc.open();
WIth the latest version i loose all the "\n"
T.P Wang
post Jan 20 2010, 14:55
Post #664
Yes, because "\n" will be ignored in HTML, use <br/> instead.
carmenm
post Jan 20 2010, 15:25
Post #665
QUOTE (T.P Wang @ Jan 20 2010, 14:55) *
Thanks, i replace "\n" with <br/>, decode then replace <BR> with "\n" and it works !
marc2003
post Jan 20 2010, 15:40
Post #666
text = text.replace(/&(lt|gt);/g, function (strMatch, p1){
    return (p1 == "lt")? "<" : ">";
text = text.replace(/<\/?[^>]+(>|$)/g, "");
doc.open();
div.innerHTML = text.replace(/\n/g, "<br>");
text = div.innerHTML;
text = text.replace(/<BR>/g,"\n");
text = text.replace(/&amp;/g,"&");
carmenm
post Jan 20 2010, 16:15
Post #667
QUOTE (marc2003 @ Jan 20 2010, 15:40) *
doc.open();
text = strInputCode.replace(/<\/?[^>]+(>|$)/g, "");
                            text = text.replace(/\n/g, "<br/>");
                            text = decodeXMLEntites(text);
                            text = text.replace(/<BR>/g, "\n");
                            text = text.replace(/&quot;/g, '"');
                            artistbio = text.replace(/&amp;/g,"&");
i use that directly from lastfm api input
marc2003
post Jan 21 2010, 05:29
Post #668
i've stumbled across a really odd problem. i'm fetching data from last.fm and and am using this to save the results to text files.
ts = fso.FileExists(filename) ? fso.OpenTextFile(filename, 2) : fso.CreateTextFile(filename, 2);
ts.WriteLine(text);
ts.close();
but i've found a couple of artists that are causing this error...
WSH Panel Mod (GUID: 61276294-C90D-48B6-BE13-0C2328792088): Microsoft JScript runtime error:
Invalid procedure call or argument
Ln: 42, Col: 9
<source text only available in compile time>
line 42 is simply
ts.WriteLine(text);
how can the contents of "text" cause the function to fail? this is one example of some problematic text...
edit: sample removed. T.P has provided the solution.
This post has been edited by marc2003: Jan 21 2010, 06:08
T.P Wang
post Jan 21 2010, 05:56
Post #669
@marc2003:
First you make wrong use of CreateTextFile() (but it's not important), and acutally OpenTextFile() can be used to create a file if file doesn't exist.
This most important thing is:
You try to write unicode chars (there are some korean chars in your sample) in ANSI files, so, open a text file in Unicode mode using:
var fs = fso.OpenTextFile(filename, 2, true, -1);
That's all.
marc2003
post Jan 21 2010, 06:08
Post #670
cheers. that's sorted it.
T.P Wang
post Jan 21 2010, 09:06
Post #671
WSH Panel Mod 1.3.0 Uploaded.
carmenm
post Jan 21 2010, 09:20
Post #672
@TPWang: I think i found a bug.
I use the on_playback_time(time) to provoke media downloading.
If time ==3 i do the download.
If i do WshShell.run just there in the on_playback_time(time), i get the error that WshShell doesnt exist which i really good as it doesnt !
But if i do it the way i do it which is
function on_playback_time(time)
    if(time == 3)
    xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
        xmlhttp.open("GET", url + "&s=" + Math.random(), true);
    xmlhttp.setRequestHeader('User-Agent','foo_lastfm_playcount_sync');
    xmlhttp.send();
    xmlhttp.onreadystatechange = function()
             WshShell.run
I dont see the error. (i remove most of the code).
I suppose the stdout from xmlhttp isnt redirected to the console
T.P Wang
post Jan 21 2010, 09:41
Post #673
I don't think so.
carmenm
post Jan 21 2010, 10:21
Post #674
QUOTE (T.P Wang @ Jan 21 2010, 09:41) *
I don't think so.
OK but still i dont see the error.
marc2003
post Jan 21 2010, 14:14
Post #675
you didn't remove this bit. did you?
xmlhttp.onreadystatechange = function() {
    if (xmlhttp.readyState == 4) {
        if (xmlhttp.status == 200) {
            //on success do something
        } else {
            fb.trace(xmlhttp.responsetext);
you have to wait for it to complete and this can take a few seconds if the remote server is being slow.
3 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
RSS Lo-Fi Version Time is now: 31st July 2014 - 01:45
