Problems with Fb2K and La 0.4b, I can't play la files...
vize84
post May 5 2004, 15:26
I'm not able to play la files even thought I have installed the right plugin in the components directory in foobar2K version 8.1, when I try to play the same compressed file with WinAmp 5.03 (with the right plugin) everything works fine; the strange thing is that I remember that 1 or 2 months ago I could play la files with foobar without problems (probably I had an older verion of foobar, but I'm nt sure), can anybody help me?
ssamadhi97
post May 5 2004, 18:04
Group: Developer (Donating)
works for me without any problems..
can you please be more specific about this? "I'm not able to play la files" is a bit vague.. do track times show up properly when dropping new files into foobar's playlist? Do you get any error messages? etc
A riddle is a short sword attached to the next 2000 years.
vize84
post May 5 2004, 18:21
This is trhe error that appears on the console:
ERROR (CORE) : error opening file for playback
ssamadhi97
post May 5 2004, 22:24
Maybe it's about time to bitch at foo_la author - the plugin seems to have several weird issues anyway. I just installed it to reproduce your problems and found one issue in LaWin frontend and at least two more in foo_la itself along the way dry.gif
This post has been edited by ssamadhi97: May 5 2004, 22:25
VCSkier
post Feb 7 2005, 06:40
i ran into the same problem you did. it just dosent seem to work, and will do different things when i try... when i did some exploring, i found this quote on the la documentation: "The plugin is designed to work with foobar2000 versions 0.7x. It will most likely not work with earlier or later versions." also, i found foo_la listed as a "problematic component" in this thread for other reasons: http://www.hydrogenaudio.org/forums/index....17872&hl=foo_la unfortunate eh? i really like la simply for archival. from what ive seen it has the best compression ratio of all the lossless encoders, particularly when utilizing its commands -high and -noseek. btw, if any of you know of a lossless encoder that can put out a better compression ratio, let me know.
a windows-free, linux user since 1/31/06.
RSS Lo-Fi Version Time is now: 29th January 2015 - 20:42
