85 Pages V  « < 72 73 74 75 76 > »
Columns UI appearance, Post a screenshot of your config!
derty2
post Mar 29 2012, 21:58
Post #1826
If you are having problems sorting the items in the playlist, read this post ---> here <---
lettuceman44
post Apr 3 2012, 04:15
Post #1827
QUOTE (BunnyHoover @ Mar 22 2012, 06:36) *
QUOTE (tdisbd @ Mar 22 2012, 05:39) *
THIS WILL BE VERY GOOD !
I want this
patanpatan
post Apr 9 2012, 16:13
Post #1828
Hi guys, this is my current config:
But I need some help: how can I change the window colors?
I know I can make a buttons panel with WSH (in fact the volume control is WSH), but I want to paint blue the scroll bars, columns headers, dropdown boxes, and the line between panels...
Is this possible?
derty2
post Apr 9 2012, 21:33
Post #1829
Those elements are dependent on your operating system theme; therefore, under normal circumstances, you can't change those things.
However, if you run your foobar2000 installation contained in a portable sandbox and configure the sandbox to be fully isolated from your real system
then you can possibly change these things without touching your real system.
Do a Google search for a free software named JauntePE and see what it can do for you...
Corey
post Apr 12 2012, 14:51
Post #1830
How did you split window like that? I want to do the same, so I can have space for album artwork, lyrics, bio etc... This is stupid question, I'm a beginner at this, so basic help you be nice.
Or how can I make tabbed columns?
Example
http://fc07.deviantart.net/fs47/f/2009/236...amofsandman.png
Bottom right, are small button that have tabbing ability, in one tab is Playlists, other libary, third lyrics, 4th bio etc... how can I make it? And what's the plugin for making playlist organized like this by albums?
I know, so many questions.... : (
This post has been edited by Corey: Apr 12 2012, 14:57
patanpatan
post Apr 12 2012, 15:14
Post #1831
I'm using ColumnsUI, if you go to Preferences -> Display -> Columns UI -> [TAB] Layout you will see a tree structure where you can group different splitters.
My config is:
Horizontal splitter
---Vertical splitter
------Horizontal splitter
---------Buttons
---------Playback order
---------WSH Panel Mod (for volume)
------EsPlaylist
------Waveform seekbar
---------Vertical splitter
------------Biography (for album art)
------------Biography (for artist info)
---------Lyric Show 3
------Channel spectrum panel
------Spectrum analizer
Also I use [a banned component] to [circumvent compliance with the Windows UI]
This post has been edited by db1989: Apr 12 2012, 15:21
Corey
post Apr 13 2012, 09:35
Post #1832
What are differences between deffault splitters and Panel Stack Splitters? And what's the component for artist biography, I can't seem to find it.
patanpatan
post Apr 13 2012, 16:32
Post #1833
@db1989: banned component? that means it can be harmful? should I delete it?
@corey: not sure about panel stack, but I think it's like a tab panel...
and about biography, is this one:
foo_uie_biography
Biography View 0.4.0.3
This is an experimental plugin, use at your own risk
This post has been edited by patanpatan: Apr 13 2012, 16:34
Corey
post Apr 14 2012, 09:27
Post #1834
QUOTE (patanpatan @ Apr 13 2012, 16:32) *
Hm, I think it's not, maybe someone else can explain better.
juddyymars
post Apr 16 2012, 22:04
Post #1835
Uploaded with ImageShack.us
acrox999
post Apr 23 2012, 12:15
Post #1836
Here's mine:
Details:
http://acrox999.deviantart.com/art/CUIGray...rox999&qo=0
This post has been edited by acrox999: Apr 23 2012, 12:16
patanpatan
post Apr 26 2012, 03:00
Post #1837
This post has been edited by db1989: Apr 26 2012, 08:54
Reason for edit: removing pointless full quote
LSton
post Apr 27 2012, 13:41
Post #1838
QUOTE (juddyymars @ Apr 16 2012, 17:04) *
I love your setup! I know this is probably a stupid question but how do you get the underline across the bottom of the grouping titles?
MacStew
post Apr 28 2012, 02:59
Post #1839
New version of fooxgen3 released
Falstaff
post Apr 28 2012, 10:04
Post #1840
nice config MacStew, ...but imho track line is maybe too cluttered around the ...rating info
http://br3tt.online.fr/
MacStew
post Apr 28 2012, 12:17
Post #1841
Thanks, I will fix it.
Brazil2
post Apr 29 2012, 08:44
Post #1842
I'd wish to make tabs for the artwork view for Front, Back, Media covers as seen in the pic from this post:
http://www.hydrogenaudio.org/forums/index....st&p=793905
But it's done with the default UI, so is it possible to do the same with Columns UI ? And if so, how to do it ? I'm quite new to foobar and not good at customization, I've searched but I didn't find out how to do it. Thanks smile.gif
marc2003
post Apr 29 2012, 09:01
Post #1843
assuming you have an artwork panel already in your layout, goto file>preferences>display>columns UI>layout tab. using the right click menu, remove the artwork panel. now right click the splitter it was sitting in and add a tab stack. add to that as many artwork panels as you need. use the use custom title option on each panel and that will become the title of the tab. make sure you untick show caption for each panel as well.
This post has been edited by marc2003: Apr 29 2012, 09:02
Brazil2
post Apr 29 2012, 09:21
Post #1844
QUOTE (marc2003 @ Apr 29 2012, 10:01) *
There is one annoyance though: each time I click on a tab (Front, Back, etc) the title on the playlist becomes unselected-out of focus thus the artwork view appears empty and I have to click on the title again for making the covers to show up.
Is there any workaround for this so I can switch between tabs without the need the click back on the title each time ?
marc2003
post Apr 29 2012, 09:34
Post #1845
right click the panel>displayed track and try the options there.
Brazil2
post Apr 29 2012, 09:49
Post #1846
QUOTE (marc2003 @ Apr 29 2012, 10:34) *
The 'Playlist selection' option did it.
Frankie
post Apr 30 2012, 08:50
Post #1847
QUOTE (lljk @ Sep 23 2009, 12:43) *
hello all -
well, here's the new and improved (much) lljkturntable config. it looks about
the same...
what's new?
tone arm functions as search bar
MUCH smoother tone arm movement
resizing problem fixed
reflexion and other image problems fixed
i've included the dockable panels .dll in the .zip, and yes, the .fcl wink.gif
thanks to tom barlow and tedgo for their help with the wsh panel, and to br3tt
for his (unwitting) help with the buttons scripting! thanks also to everyone else
i've shamelessy but not thanklessly "borrowed" scripting ideas from....
here's the link: stick this in yer foobar and smoke it...
rock
j
Unfortunatly the link in this post doesn't work anymore. Can anybody please repost this or tell me if I can find this skin (or another nice turntable skin) elswhere?
juddyymars
post May 2 2012, 04:41
Post #1848
QUOTE (LSton @ Apr 27 2012, 13:41) *
patanpatan
post May 2 2012, 15:12
Post #1849
QUOTE (MacStew @ Apr 28 2012, 02:59) *
Interesting, but I cannot get it to work.
After it loads I get a "Aw, crashed sad.gif" message below the album art, and I can't see the playlist or the tabs.
Console says:
Error: WSH Panel Mod ({05B803E5-E660-4D82-9F7F-4635DEA32226}): Microsoft JScript runtime error:
Invalid procedure call or argument
File: <main>
Ln: 28, Col: 1
Do you know what am I missing?
MacStew
post May 3 2012, 00:49
Post #1850
QUOTE (patanpatan @ May 2 2012, 16:12) *
Console says:
File: <main>
Ln: 28, Col: 1
A picture can be helpful ^^.
If you have like the picture and only a crash, click on the big down arrow button: add an album and restart foobar.
http://imageshack.us/photo/my-images/10/untitm.jpg/
Otherwise the installation is not good
This post has been edited by MacStew: May 3 2012, 01:36
RSS Lo-Fi Version Time is now: 27th November 2014 - 04:23
