IPB
2 Pages V   1 2 >
stream-recording, with what and how?
thinkum dinkum
post Apr 12 2005, 10:29
Post #1
Group: Members
I'm curious, what software do you use if you want to save audio stream and how you do it?
I use total recorder, it's good but maybe there is some free alternative, or not free but better?
a frag a day keeps the doctor away
Go to the top of the page
+Quote Post
M
post Apr 12 2005, 13:23
Post #2
Group: Members
I use Jasper's "LineIn" and "File Writer" Winamp plugins.
- M.
+Quote Post
nyarlathotep
post Apr 12 2005, 13:54
Post #3
Group: Members
Well for me it depends on the stream.
For shoutcast, I use foobar2000 and the modified http reader component. Other possibilities are Streamripper or Stationripper.
For Real or Windows media streams (using RTSP, PNM or MMS protocols), I use Net Transport.
Actually I don't record the sound (through the sound card) but try to download the stream from the server when it is possible.
+Quote Post
PoisonDan
post Apr 12 2005, 14:01
Post #4
Group: Members (Donating)
Some good advice from nyarlathotep. I also try to directly capture the encoded packets instead of decoding the stream.
The modified HTTP reader with stream saving can be downloaded here.
For Windows Media streams, I've also succesfully used ASFRecorder in the past.
Over thinking, over analyzing separates the body from the mind.
+Quote Post
thinkum dinkum
post Apr 12 2005, 15:53
Post #5
Group: Members
+Quote Post
emr
post Apr 12 2005, 21:26
Post #6
Group: Members
For Real Audio/Media streams there's an older version of the Streambox VCR that can download and save the files when you find the name of the source. I believe due to copyright reasons or something like that the newer versions do not have the possibility.
+Quote Post
Digga
post Apr 12 2005, 21:35
Post #7
Group: Members
RadioRipper is also good free app that plays along nice with WA.
threads
Nothing but a Heartache - Since I found my Baby ;)
+Quote Post
Frank
post Apr 13 2005, 01:05
Post #8
Group: Members
If you have a Mac, Audio Hijack and Audio Hijack Pro work great
http://www.rogueamoeba.com/audiohijack/
http://www.rogueamoeba.com/audiohijackpro/
+Quote Post
Acid Orange Juic...
post Apr 13 2005, 01:58
Post #9
Group: Banned
+Quote Post
Mono
post Apr 13 2005, 03:52
Post #10
QUOTE (Frank @ Apr 12 2005, 07:05 PM)
Unfortunately no Mac software works to download streams, as my experience shows: Stream Downloader for Mac OS X?
"Facts do not cease to exist just because they are ignored."
—Aldous Huxley
+Quote Post
thinkum dinkum
post Apr 13 2005, 08:27
Post #11
Group: Members
QUOTE (nyarlathotep @ Apr 12 2005, 02:54 PM)
yes, interesting solution indeed, while I'm looking into that I'm gonna try that Streamripper and RadioRipper for quick alternatives
...again, thank you
+Quote Post
tgoose
post Apr 13 2005, 10:07
Post #12
Group: Members
The only versions of Streambox VCR that still do that are the hacked ones. I assume I'm not allowed to post any information relating to getting them on this board?
This post has been edited by tgoose: Apr 13 2005, 10:10
+Quote Post
kindofblue
post Apr 13 2005, 10:12
Post #13
Group: Members
Just discovered a cool no-bloat freeware app called Screamer Radio. Worth a look.
WavPack 4.31 / LAME 3.98 alpha 3 -V9 -vbr-new
+Quote Post
hujay
post Apr 13 2005, 18:20
Post #14
Group: Members
QUOTE (thinkum dinkum @ Apr 13 2005, 07:27 AM)
yes, interesting solution indeed, while I'm looking into that I'm gonna try that Streamripper and RadioRipper for quick alternatives ...
This is what Streamripper and RadioRipper already do. They record the stream before passing it to your soundcard, so no re-encoding losses.
You should be aware that some broadcasters take a dim view of this and you may find yourself kicked if they detect you.
The alternative is an output recorder, of which there are dozens, EAC, Feurio, CDex(I think) TR, X-Ripper, Wave Repair etc. These are obviously undetectable.
In fairness to the very small operators you should ensure that any streamripping program you use does not establish a second connection and use up precious bandwidth.
UJ
+Quote Post
DonP
post Apr 14 2005, 13:52
Post #15
QUOTE (hujay @ Apr 13 2005, 12:20 PM)
Both streamripper and radioripper can rebroadcast the stream to you can listen to the restream while recording without adding more load to the station.
advantages:
Streamripper
1) multiple OS
2) runs off command line, and you can specify how long to record, so you can start it with a scheduling program to record while you aren't home.
3) free
Radioripper:
1) GUI: select the station you want off the list, then hit buttons for listen, record, rebroadcast.
2) can rebroadcast up to 7 copies of the stream in case you want to wander about the house, or others on your local network want to listen.
Timer functions are on Radioripper's list of coming attractions.
Both: record the original encoding, not a decoded wav or transcode.
I believe both can split the stream into separate song files if the stream has the right tag support. None of the stations/shows I record do that.
This post has been edited by DonP: Apr 14 2005, 13:54
+Quote Post
Mr_Rabid_Teddybe...
post Apr 14 2005, 15:57
Post #16
Group: Members
QUOTE (kindofblue @ Apr 13 2005, 01:12 AM)
Looks cool to me;
Direct saving of mp3 and ogg vorbis streams. Doesn't open a second listening connection while recording (I checked against my own stream). Saves individual tracks with artist & title for filename; at least it does with the Icecast2 ogg vorbis stream I'm trying out now, this stream sends a full set of tags along with the stream, though (it saves the tags, too). And not limited to Shoutcast servers like some of the tools mentioned. There's also a predefined preset list, for other stations you enter the URL.
Minor drawbacks;
It doesn't seem to understand m3u or PLS playlists. There's only limited display of metadata. Ogg, mp3 and wma streams are supported, but not aac. Can't see that you can enter your own presets.
[EDIT]
Sorry. You can indeed enter your own presets or favorites through XML files, using the following syntax:
<Station title="AAA" url="BBB">
<Source>CCC</Source>
</Station>
More here
[/EDIT]
This post has been edited by Mr_Rabid_Teddybear: Apr 14 2005, 20:58
+Quote Post
spies
post Apr 14 2005, 16:28
Post #17
Well there is the excellent RadioLover but that only works with mp3 streams. iRecordMusic works with other streams but it does transcode. I find it works pretty well however YMMV smile.gif
QUOTE (Mono @ Apr 12 2005, 06:52 PM)
+Quote Post
Mr_Rabid_Teddybe...
post Apr 14 2005, 19:28
Post #18
Group: Members
Just for the sake of completion:
There's also a Win32 standalone GUI version of StreamRipper to be found here.
+Quote Post
emr
post Apr 14 2005, 20:03
Post #19
Group: Members
QUOTE (tgoose @ Apr 13 2005, 11:07 AM)
Don't know but if it's legal to have this older version at for example Rarewares, I have it.
+Quote Post
thinkum dinkum
post Apr 14 2005, 20:51
Post #20
Group: Members
now
I think Streamripper or Screamer Radio will do just fine for now
@ Mr_Rabid_Teddybear - I think you are right about pls in Screamer R
+Quote Post
Olive
post May 8 2005, 06:35
Post #21
Net Transport is great for getting eg .rm's from .ram's
Unfortunately it isn't freeware.
+Quote Post
Althalus
post May 8 2005, 12:13
Post #22
Group: Members
I've best ex[erience using OfflineExplorer for downloading streams directly. MMS,RTPS,etc.
It's really a leecher for downloading whole sites, but the stream ripping functions work perfectly.
ASFrecorder for example doesnt work on all streams, and on some streams it manages to download the file but somehow mess it a bit up so when you watch it, it is choppy and stalls.
+Quote Post
tgoose
post May 8 2005, 12:45
Post #23
Group: Members
I never got ASFrecorder to work at all, Streambox VCR is good though.
+Quote Post
OFI
post May 12 2005, 13:42
Post #24
Group: Members
I use HiDownlaod for any real or windows media streams audio and video smile.gif it also comes with a link to some app which monitors sites and gives u the url to streams if u cant find them yourself as they are quite often hidden (havent yet used this extra but sounds good)
+Quote Post
Mr_Rabid_Teddybe...
post May 13 2005, 05:31
Post #25
Group: Members
For those instances when direct ripping is impossible, and you'll have to resort to recording from soundcard (which have been dicussed earlier in this thread should be avoided if possible), I find that HardiskOgg are a nice free program (Ogg, mp3, Monkeys Audio). LiveInCode are another one (bit more primitive, but offers Speex in addition to Ogg). I've had this issue with some real streams and such, that I could not rip them and had to resort to simple recording....
+Quote Post
2 Pages V   1 2 >
0 Members:
RSS Lo-Fi Version Time is now: 31st August 2014 - 02:02
