burn live mp3
mantra
post Feb 10 2004, 08:43
Group: Banned
hi
i have some live mp3
and i tried to burn onto a audio cd
but there are some silence block so is impossible to set gaps =0
wavelab4 does a great job!
but cool edit no
i tried to delete silence with cool edit but it keeps some silence blocks why? crying.gif
AtaqueEG
post Feb 10 2004, 08:51
Group: Members (Donating)
Because that "silence" is inherent to MP3 decoding, that's why.
If your MP3 were made with LAME version 3.90 or newer (except some 3.94 versions) try decoding them with foobar2000 which should give you no such "silences".
If they were made with other version, try foobar2000's "Fix MP3 Header" feature.
Go to foobar2000 forum and search for more info there.
I'm the one in the picture, sitting on a giant cabbage in Mexico, circa 1978.
Reseņas de Rock en Espaņol: www.estadogeneral.com
minix
post Feb 10 2004, 09:15
CoolEdit should do it, if you save as WAV format.
Foobar2k is better for removing those silence blocks automatically.
Feurio is better for doing it manually if your burner is supported. Of course, any wave editor will also do it (if you save to wav), but it's quite slower.
http://www.hydrogenaudio.org/forums/index....showtopic=17396
mantra
post Feb 12 2004, 08:46
Group: Banned
yes please i can i delete silence with cool edit?
ancl
post Feb 12 2004, 11:56
QUOTE (mantra @ Feb 12 2004, 08:46 AM)
You can manually delete the silence with any audio editor. But you can't save the resulting file as an mp3, because then the silence/gap will come back!
There is one way to make playback of mp3 files gapless: Use lame to encode them and listen to your files through foobar2000 or with mpg123 (plugin for winamp).
But there is no portable player that support this (as far as i know).
This post has been edited by ancl: Feb 12 2004, 11:57
mantra
post Feb 12 2004, 12:04
Group: Banned
yes i know
but in cool edit is there a command delete silence
but it does not delete every silence blocks....
can i post a piece of this wavs?
MugFunky
post Feb 16 2004, 17:42
you can zoom in to the sample level to make this precise, and i think there's a trim silence option somewhere. you'll have to look for it smile.gif
one problem with burning to CD is that all your edits have to coincide with CD frame boundaries (75fps) or you'll get gaps again (all but inaudible).
mantra
post Feb 17 2004, 15:09
Group: Banned
ok ok
it works
i deleted with cool edit pro
but i would love it will delete the fist 5 second of silence and the last 5 sec.
but in batch mode
magic75
post Feb 18 2004, 09:56
If you want to delete leading and trailing silence from MP3:s you can try MP3trim. Note that there is a difference between analogue and digitial silence, I think what you want is to remove is analogue silence and this has to be configured in MP3trim. And also, the batch features requires registration and hence costs money.
What the other guys have been trying to tell you is that the MP3 format in itself adds silence, but this is just a fraction of a second, and I guess this is not the problem you are trying to solve, right?
The most probable reason why the delete silence command in Cool edit doesn't work is because it only removes digital silence. Digital silence means that each sample is equal to zero. Analogue silence means that all samples are not zero, but close enough so that your ears can't hear it.
If you need to do it in batch mode and can afford MP3trim I think that is your best choice.
An alternative is to decode all MP3:s to wav and use wavTrim instead. I think the batch features in wavtrim are free...
mantra
post Feb 18 2004, 17:41
Group: Banned
yeah it works
thanks!
RSS Lo-Fi Version Time is now: 28th February 2015 - 02:08
