2 Pages V   1 2 >
aoTuVbeta6.02
Anakunda
post Apr 29 2011, 10:55
Hi, why aoTuVbeta6.02 Compiles are not available @ Rarewarez, could somebody so kind and made oggenc2 + dlls available to public, thankyou
alter4
post Apr 29 2011, 11:01
Do you mean 6.03?
Anakunda
post May 1 2011, 17:15
sure, 6.03
it's couple of days
Anakunda
post May 1 2011, 18:58
QUOTE (Anakunda @ May 1 2011, 18:15) *
sure, 6.03
it's couple of days
Okay I `ve made an attempt for optimized OggEnc2 build. Please for testing.
http://www.mediafire.com/?1pl3o7vqb3ljxe3
punkrockdude
post May 1 2011, 20:40
I replace the oggenc2.exe from rarewares with yours and the included dll's but I get the following message from Foobar2000 when I convert:
Source: "D:\Audio\Pennywise - Live @ The Key Club\Pennywise - 02 - Wouldn't it Be Nice.flac"
An error occurred while finalizing the encoding process (Object not found) : "D:\Pennywise - 02 - Wouldn't it Be Nice.ogg"
Conversion failed: Object not found
I use the same command line as I did with the rarewares 6.02 that worked and it is the following:
%s -q 3.5 --advanced-encode-option lowpass_frequency=17 --advanced-encode-option impulse_noisetune=-15 -o %d
I use Windows XP SP3 on this laptop.
Regards
This post has been edited by punkrockdude: May 1 2011, 20:46
Anakunda
post May 1 2011, 20:53
QUOTE (punkrockdude @ May 1 2011, 21:40) *
Regards
Do you get an crash or error message during conversion?
I think it requires SSE 4.1 or higher to run as it was compiled as optimized build.
Try to copy msvcr100.dll and libmmd.dll to same directory.
This post has been edited by Anakunda: May 1 2011, 20:54
punkrockdude
post May 1 2011, 20:54
Oh, I see. This Intel Centrino only has SSE2 I think. Regards.
Anakunda
post May 1 2011, 20:57
Ah so, If I get some positive confirmation about proper conversion I can try to make a more generic build tomorrow.
punkrockdude
post May 1 2011, 21:10
I just tried it on my Intel Q9550 with Windows 7 x64 and it works. The processor was in 1.9GHz mode to save power and not in full 2.83GHz and it was about 50x times faster than realtime.
Anakunda
post May 1 2011, 21:16
Just for the case I`ve made a more generic build that should run on any CPU:
http://www.mediafire.com/?81janz0arwccpva
Not Tested
punkrockdude
post May 1 2011, 21:22
The generic version worked on my Intel Centrino 1.75GHz and the speed was about 9x. Regards
punkrockdude
post May 1 2011, 21:27
By the way, thank you a lot for these builds! I really appreciate it. Regards.
punkrockdude
post May 1 2011, 21:32
Is it a lot of work to make a SSE2 version. I do not expect you to make one but just wonder if it is something you might be interested in making? Regards.
Anakunda
post May 1 2011, 21:45
QUOTE (punkrockdude @ May 1 2011, 22:32) *
Not so much work, if there'll be some interest for SSE2 I might do that level also.
Thanks for testing.
punkrockdude
post May 1 2011, 21:47
Post #15
QUOTE (Anakunda @ May 1 2011, 22:45) *
Thanks for testing.
No problem at all. You are the one to be thanked! Regards.
lvqcl
post May 1 2011, 22:05
Post #16
In the meantime you can test my compile.
It doesn't have built-in FLAC reader and resampler but since you use oggenc2 as encoding backend for foobar2000 they are useless anyway.
Destroid
post May 3 2011, 10:08
Post #17
Thanks for that. Tested SSE2 version on Athlon64 3000+ and got twice the encoding speed of VEnc without any anomalous bitrate/quality differences (tested on commentary DVD track at @100kbps). Speed of your OggEnc2 was about on-par with Musepack and right between Nero and CELT.
Destroid
post May 3 2011, 19:18
Post #18
This test was for multiple reasons: a) to expand my knowledge of DVD video extraction process (heard that CELT did better with 48KHz and figured stereo AC3 converted to WAV would work; b) to test CELT encoding speed in regards to the statement that it was a magnitude faster because of no psy-model and other reasons; c) just another general encoder speed test carried out on a not-so-modern machine. Seems CELT could benefit from optimizations. But anyhow, I ended up putting results here since the OggEnc2 compile (SSE2) above seemed dramatically faster than Venc.
This test focused on lossy encoders aiming for a VBR setting which would result in @100kbps since I figured a DVD commentary track was less complex and needed no 5.1->stereo conversion. I think 100kbps for this material is overkill since there is virtually no audible winner here. Lossless codecs were added to reflect the material was non-complex and easily compressed.
Encoder/Settings File size Bitrate* Speed* TimeThis
_________________________ __________ __________ _______ ___________
Musepack 1.30 -q 4.99 65,978,894 98.8 kbps 23.99x 222.687 sec
AoTuv 6.03 -q 4 65,996,209 98.8 kbps 13.37x 399.593 sec
OggEnc 2.7 SSE2 -q 4 65,996,560 98.8 kbps 26.71x 200.781 sec
CELT 0.11.2 --bitrate 100 66,843,352 [97.8 kbps] [30.49x] 175.156 sec
Nero AAC 1.5.1.0 -q 0.4 67,192,851 [98.9 kbps] [20.86x] 256.093 sec
OggEnc 2.7 SSE2 -q 4.1 67,515,708 101.1 kbps 26.57x 201.078 sec
AoTuv 6.03 -q 4.1 67,516,144 101.1 kbps 13.31x 401.265 sec
LAME 3.99 alpha16 -V 5 68,150,160 102.1 kbps 14.10x 379.500 sec
Musepack 1.16 -q 4.99 68,544,320 102.7 kbps 24.03x 222.281 sec
Helix MP3 5.1 -V90 69,001,032 103.4 Kbps [104.99x] 50.875 sec
Musepack 1.30 -q 5 72,427,994 108.5 kbps 23.73x 225.171 sec
Helix MP3 5.1 -V100 72,959,688 109.3 Kbps [102.59x] 52.062 sec
Musepack 1.16 -q 5 75,120,664 112.5 kbps 23.77x 225.406 sec
WAVE (16bit 48KHz 2ch) 1,025,507,372 1536 kbps - - - - - - - - - -
FLAC 1.2.0 -5 312,449,472 468 kbps [88.90x] 60.078 sec
Monkey's Audio -c2000** 312,394,832 468 kbps [166.22x] 32.328 sec
WavPack 4.60 311,117,884 465 kbps [95.57x] 55.890 sec
TAK 2.1.0 -p 2 281,036,191 421 kbps 122.28x 43.718 sec
* values reported by encoder, brackets indicate user-calculated values
** old/deprecated version of codec used, don't ask
IgorC
post May 3 2011, 19:56
Post #19
Those were interesting numbers.
QUOTE (Destroid @ May 3 2011, 15:18) *
Since it is DVD audio track then even 64-80 kbps will be more than enough (excluding MP3 perhaps)
This post has been edited by IgorC: May 3 2011, 20:05
http://listening-test.coresv.net/results.htm
john33
post May 4 2011, 15:47
Post #20
xcLame and OggDropXPd Developer
John
Destroid
post May 5 2011, 00:46
Post #21
john33- I noticed your P4 compile is much slower than lvqcl's compile, close to Venc . This was running an Athlon64. Seemed strange enough that I re-ran tests on both compiles to confirm.
IgorC
post May 5 2011, 03:00
Post #22
Ive experienced slow encoding speed too with rarewares compilation on my AMD cpu. http://www.hydrogenaudio.org/forums/index....st&p=726406
Destroid
post May 5 2011, 04:17
Post #23
Great, it's the compiler. The Rarewares generic compile gets 10x speed, the SSE's get 12x. Meanwhile the lvqcl gets 26x
Anakunda
post May 5 2011, 09:43
Post #24
I have compared the speeds and lvqcl's oggenc is about 1.5x faster than every other compile.
If raw streams binary compared, each compile generated binary different output, maybe it's due to each compiler operates with different floating point precision.
john33
post May 5 2011, 09:54
Post #25
QUOTE (Destroid @ May 5 2011, 00:46) *
Hmmm, I'll check the compiler options I've used.
John
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 4th March 2015 - 03:57
