.FLAC to .AAC, Easiest way to do this?
mikehartl
post Sep 4 2004, 04:57
I have ripped my CD collection into perfect quality .flac files and want to convert osme selections of music to AAC for my iPod. Is there a simple way to do this? What program should I use?
kl33per
post Sep 4 2004, 05:16
A/V Moderator
You could use foobar2000 to do this. You would also require a AAC codec. Nero or FAAC could do it. I think there's even a way to use the iTunes codec with foobar, but I use Nero so it doesn't worry me.
www.sessions.com.au - Sessions Entertainment
mikehartl
post Sep 4 2004, 05:39
QUOTE (kl33per @ Sep 3 2004, 10:16 PM)
I have tried Nero but the problem is when I try to play back the files in iTunes all of the tags are missing. mad.gif It's a very annoying problem.
DickxLaurent
post Sep 4 2004, 06:48
If you want to use iTunes to ensure compatibility with your iPod, Otto42 has written a very nice tool which allows us to use iTunes to encode from command line, EAC, Foobar, etc. He has it available here: http://otto.homedns.org:8888/iTunes/iTunesEncode.zip
It comes with a text file containing usage options, or you can read the posts: http://www.hydrogenaudio.org/forums/index....showtopic=22391
Anyway, for your project, I think using this tool with Foobar would be your best option. I have tried it myself and was satisfied. smile.gif
"The way we see our world is better than yours."
menno
post Sep 4 2004, 08:02
Nero MPEG4 developer
Group: Developer (Donating)
QUOTE (mikehartl @ Sep 4 2004, 05:39 AM)
Rename the .mp4's to .m4a
Menno
henkersmahlzeit
post Sep 7 2004, 03:34
To convert from FLAC to Apple's *.aac you just install dbpowerAmp Music Converter (+ the FLAC and WMA 9 encoder!). Convert any FLAC-files to WMA lossless (e.g. Right-Mouse-Button).
Just Drag-and-Drop your WMA files into iTunes after you choose your favourite bitrate ... cool.gif
anticrust
post Sep 7 2004, 20:54
QUOTE (mikehartl @ Sep 3 2004, 07:57 PM)
I have written a few batch scripts to convert all my flac files to m4a (aac), mp3, mpc, or ogg. Here are the steps and code to set it up.
Assumptions:
- All .flac files are in the same directory, not in subdirectories. (Example C:\music\song.flac)
- All .flac files are properly tagged.
1. In your .flac file directory (see example above) make a "convert" directory (ie. C:\music\convert).
2. In this "convert" directory, make an "aac", "mp3", and "flac" directory (ie. C:\music\convert\aac & C:\music\convert\flac).
3. Copy itunesencode.exe, faac.exe, naacenc.exe, and tg.exe into the "aac" directory (from www.rarewares.org)
4. Copy flac.exe and metaflac.exe into the "flac" directory.
Copy lame.exe into the "mp3" directory.
5. Create a file called "encode.cmd" in the "convert" directory.
6. Use notepad to open the file and copy and paste the code below into the file. Save.
encode.cmd
@ECHO OFF
rem :Check to see if path exists, if not create and encode.
if exist ..\%ext% (
echo.
) else (
mkdir ..\%ext%
rem :Grab the tag data from the .flac file and store it in temp.txt for now.
flac\metaflac --show-vc-field=artist %1 > temp.txt
flac\metaflac --show-vc-field=title %1 >> temp.txt
flac\metaflac --show-vc-field=album %1 >> temp.txt
flac\metaflac --show-vc-field=date %1 >> temp.txt
flac\metaflac --show-vc-field=tracknumber %1 >> temp.txt
flac\metaflac --show-vc-field=genre %1 >> temp.txt
rem :Turn the tags into var's for later use.
for /F "tokens=1,2 delims==" %%i in (temp.txt) do set %%i=%%j
rem :Now delete the temp file.
del temp.txt
rem :If the track number is 9 or less, lets add a 0 in front for formatting.
if %tracknumber%==1 set tracknumber=0%tracknumber%
if %tracknumber%==2 set tracknumber=0%tracknumber%
if %tracknumber%==3 set tracknumber=0%tracknumber%
if %tracknumber%==4 set tracknumber=0%tracknumber%
if %tracknumber%==5 set tracknumber=0%tracknumber%
if %tracknumber%==6 set tracknumber=0%tracknumber%
if %tracknumber%==7 set tracknumber=0%tracknumber%
if %tracknumber%==8 set tracknumber=0%tracknumber%
if %tracknumber%==9 set tracknumber=0%tracknumber%
rem :Check the file type and goto proper encoder.
if %ext% EQU mp3 goto MP3
if %ext% EQU mpc goto MPC
if %ext% EQU ogg goto OGG
if %ext% EQU aac goto AAC
if %ext% EQU m4a goto AAC
else echo Unknown Format: %ext%
pause
goto END
:MP3
rem :Encode and tag the new file.
if %program%==lame (
for %%I in (%1) do flac\flac -d -c %%I | mp3\lame - --preset extreme --id3v2-only --pad-id3v2 --ta "%artist%" --tt "%title%" --tl "%album%" --ty "%date%" --tn "%tracknumber%" --tg "%genre%" "..\%ext%\%%~nI.%ext%"
goto END
) else if %program%==itunes (
for %%I in (%1) do flac\flac -d %%I
for %%I in (%1) do aac\iTunesEncode -a "%artist%" -t "%title%" -l "%album%" -y "%date%" -n "%tracknumber%" -g "%genre%" -d -e "MP3 Encoder" -i "..\%%~nI.wav" -o "..\%ext%\%%~nI.%ext%"
for %%I in (%1) do del "..\%%~nI.wav"
goto END
) else (
echo Unknown Encoder: %program%
pause
goto END
:MPC
for %%I in (%1) do flac\flac -d -c %%I | mpc\mppenc --quality 6 --xlevel --artist "%artist%" --title "%title%" --album "%album%" --year "%date%" --track "%tracknumber%" --genre "%genre%" - "..\%ext%\%%~nI.%ext%"
goto END
:OGG
for %%I in (%1) do flac\flac -d -c %%I | ogg\oggenc -q 7 -a "%artist%" -t "%title%" -l "%album%" -d "%date%" -N "%tracknumber%" -G "%genre%" -o "..\%ext%\%%~nI.%ext%" -
goto END
:AAC
if %program%==nero (
for %%I in (%1) do aac\naacenc -extreme -qh "..\%%~nI.wav" "..\%ext%\%%~nI.%ext%"
for %%I in (%1) do aac\tg "..\%ext%\%%~nI.%ext%" --artist "%artist%" --album "%album%" --track "%tracknumber%" --title "%title%" --genre "%genre%" --year "%date%"
goto END
for %%I in (%1) do aac\iTunesEncode -a "%artist%" -t "%title%" -l "%album%" -y "%date%" -n "%tracknumber%" -g "%genre%" -d -e "AAC Encoder" -i "..\%%~nI.wav" -o "..\%ext%\%%~nI.%ext%"
goto END
) else if %program%==faac (
for %%I in (%1) do flac\flac -d -c %%I | aac\faac -q 150 -w --artist "%artist%" --title "%title%" --album "%album%" --year "%date%" --track "%tracknumber%" --genre "%genre%" -o "..\%ext%\%%~nI.%ext%" -
goto END
) else (
pause
goto END
:END
rem :All done with the var's, lets purge.
set artist=
set title=
set album=
set date=
set tracknumber=
set genre=
7. Create a file called "flac-m4a.cmd" in the "covert" directory.
8. Use notepad to open the file and copy and paste the code below into the file. Save.
flac-m4a.cmd
@ECHO OFF
rem :What program do you want to use to encode?
rem :Choices are case sensitive: nero | itunes | faac
set program=nero
rem :Set the file extension and directory path.
set ext=m4a
for %%I in (..\*.flac) do encode.cmd "%%I"
rem :Purge the vars.
set ext=
set program=
for mp3 conversion
flac-mp3.cmd
@ECHO OFF
rem :Choices are case sensitive: lame | itunes
set program=lame
set ext=mp3
set program=
set ext=
9. Now just double click on the flac-m4a.cmd file and the batch conversion will begin.
The directory structure should look like this:
C:\--
    \Music\--
             \convert\-----
              Song1.flac  |
              Song2.flac  |
              Song3.flac  |
                          \aac\-------- iTunesEncode.exe, faac.exe, naacenc.exe, tg.exe
                          \mp3\------- lame.exe
                          \flac\------- flac.exe, metaflac.exe
                           encode.cmd
                           flac-m4a.cmd
                           flac-mp3.cmd
If anyone would like the batch script code for mp3, ogg, or mpc just let me know. Once I get all the bugs worked out, I'll zip (or rar) it up and thought it out there for download somewhere.
Edit: Revised code and instructions to add use of iTunes encoder via iTunesEncode.exe
Edit: Revised code and instructions to add mp3 encoder
This post has been edited by anticrust: Sep 13 2004, 23:49
chelgrian
post Sep 7 2004, 21:36
QUOTE (anticrust @ Sep 7 2004, 08:54 PM)
3. Copy faac.exe, naacenc.exe, and tg.exe into the "aac" directory (from www.rarewares.org)
Using foobar with iTunesEncode is much easier than a huge mess of batch files. I am unconvinced about the quality of faac 1.24. At least on my music the Apple encoder in the latest version of Quicktime/iTunes is streets ahead of it.
Specifically:
1) faac appears to produce distortion on certain vocal frequences (see my post in AAC-Tech)
2) faac appears to produces a "metalic sheen" on strings which isn't present using the apple encoder.
It's a real pitty that the Apple AAC encoder isn't generally availible via the Quicktime API on Windows but I guess that would have cost Apple too much in license fees.
I ripped all my music to flac using EAC then cross coded to aac for my iPod using foobar and faac. At some point I'll have to junk the faac encoded files and re-encode it all using iTunesEncode.
chelgrian
post Sep 7 2004, 21:41
Foobar knows about how to extract tags from flac files and add them to AAC files after they have been encoded. Go to
Preferences->Components->Diskwriter
Then click the edit button for your output preset. Change tthe "Tag" drop down box from "none" to "default".
Garf
post Sep 7 2004, 21:49
Server Admin
Group: Admin
QUOTE (chelgrian @ Sep 7 2004, 10:36 PM)
I would bet that using foobar with Nero AAC or FAAC is still easier than using it with iTunesEncode smile.gif
anticrust
post Sep 7 2004, 22:14
QUOTE (chelgrian @ Sep 7 2004, 12:36 PM)
As are most things in life, the word "easier" is relative to the user. If the user is unfamiliar/uncomfortable with batch files, then this may not be the "easier" method for them. Although I can't see how double clicking on a single batch file can be perceived as difficult.
I would prefer to have the same executables that created my flac files extract, tag, and encode my new files. This method is versatile in the sense that you could use faac.exe, Nero via naacenc.exe, or someday iTunes (if Apple allows). If a new version of an encoder comes out, I just replace the .exe in the appropriate directory and double click. "Easy" as pie. smile.gif
Also, my earlier message is not an endorsement of faac, even though the code is offered as an alternative to those who do not own or have Nero installed. I prefer Nero's encoder personally.
Edit: Edited earlier post to include encoding with iTunes. It's all about choice. smile.gif
This post has been edited by anticrust: Sep 8 2004, 00:59
chelgrian
post Sep 8 2004, 20:43
QUOTE (Garf @ Sep 7 2004, 09:49 PM)
And you'd be right. Although it's only really the difference between using one of the preset encoders or defining your own commandline encoder in foobar. The other problem is that you can only run one encoding job at once although for the vast majority of people who don't have dual processor machines on their desktop this is not a problem.
dewey1973
post Sep 9 2004, 00:44
QUOTE (henkersmahlzeit @ Sep 6 2004, 07:34 PM)
Why go to wma? Just go directly to aac. It will even keep the tags for you.
Get the app here: dBpowerAMP Music Converter
Get the flac component here: Codec Central - FLAC
Get the Quicktime component and aac component here: Codec Central - Mp4 & AAC Details
(You will need both the QuickTime m4a Encoder and the Mp4 & AAC decoder.)
Just read the instructions that come with the QuickTime Encoder and transcode away!
The Belgain
post Nov 23 2004, 20:52
I'm in this situation too, thanks for the info guys.
Quite why apple don't either add input support for more major formats (especially free formats like flac, which won't cost them a dime), or allow people to write 3rd-party plugins is beyond me...
xmixahlx
post Nov 23 2004, 21:15
Post #15
for the linux searchers, convert using:
flac -dc filename.flac | faac - -o filename.mp4
RareWares/Debian :: http://www.rarewares.org/debian.html
neomoe
post Feb 8 2005, 15:48
Post #16
QUOTE (xmixahlx @ Nov 23 2004, 12:15 PM)
if a do something similar in linux, I get an error-message like " mp4(m4a) not supported" I am using debian sid. does the latest source support m4a output?
[url="http://www.ergosum-apple.de"]www.ergosum-apple.de[/url]
jerryfreak
post Aug 2 2005, 04:01
Post #17
I worked on these batch files a little, and incorporated them into an installer that writes registry entries, check it out:
FLAC Transcoder
feedback is welcome, as always
gb115b
post Oct 6 2006, 10:14
Post #18
hi,
sorry i'm not too great with batch files
can you tell me what each batch file does?
basically i want one batch file that will turn one .flac file into 1 lossy file (including tagging)
is that what the encode.cmd does? if so what are the parameters i need to feed it with?
gb115b
post Oct 6 2006, 10:58
Post #19
also what does the following bit of code doing in encode.cmd
"for %%I in (%1)"
i can see int he other batch fuiles that is used for working on each file in the directory, but in encode, isn't %1 just one file?
gb115b
post Oct 18 2006, 21:57
Post #20
okay, i've blatantly had far too much time on my hands, so i ended up developign a vb.net app that goes through a root directory picking out all the files and recreates the fiel structure in a destination directory.
it can then transcode the flac files detected into the destination directories using whatever command line program / batch file you've got.
the next time you run it, it compares the file list against the last run to find new / modified / deleted files and performs differing actions against some of them,
long story short...
i now have a way of 'synching' (1-way) my .flac library with my .m4a library
freely available to anyone who wants it with source code if people want to mod it.
it's probably a little more untested than i'd like at the moment, but i've just got it going through my 10000 flac file library at the moment...
bhoar
post Oct 18 2006, 23:56
Post #21
Group: Members (Donating)
Cool, I'd love to play with it!
-brendan
Hacking CD Robots & Autoloaders: http://hyperdiscs.pbwiki.com/
djoole
post Apr 5 2008, 17:08
Post #22
QUOTE (gb115b @ Oct 18 2006, 22:57) *
RSS Lo-Fi Version Time is now: 28th December 2014 - 14:59
