Topic: UpnP bubbleUPnP Android (Read 6146 times) previous topic - next topic
Hello everybody...
I'm trying to stream music from my Windows7 64 ultimate + and foobar2000 (latest) to my Android tablet connected via WiFi (outside my LAN).
I must install this
and this component to work.
I'm following this instructions to setup
But, i need to install foobar2000 in windows and the bubbleupnp in android, and that's all?
thanks!...
more or less, minus is best
The instructions you include in your post is about UPnP MediaRenderer Output(http://www.foobar2000.org/components/view/foo_out_upnp) which is something different from UPnP/DLNA Renderer, Server, Control Point.(http://www.foobar2000.org/components/view/foo_upnp)
The first component allows you to select an upnp device on your LAN , for output.
The second component adds a upnp server (for your foobar library) / upnp browser ( for accessing upnp servers-local or from internet).
What to do :
For The PC.
Install the UPnP/DLNA Renderer, Server, Control Point component (http://www.foobar2000.org/components/view/foo_upnp) and activate the upnp server from the prefernces page.
Install the bubble upnp Server which will let you access all active upnp servers on that pc.
http://bubblesoftapps.com/bubbleupnpserver/
For access to the server outside your LAN , you must set-up port forwarding.
For the tablet.
Install the bubble upnp application (https://play.google.com/store/apps/details?id=com.bubblesoft.android.bubbleupnp.unlocker&hl=es) on your tablet.
Local upnp servers will be visible immediately in the application.
To access the remote bubbleupnp server , go to settings and use the "setup network wizard".
What to do :
For The PC.
For the tablet.
thanks...i'll give a view tonight!
then i need to install another upnp server in the windows machine...it's a server with PLEX already installed!.
Sorry for that:
But it's impossible to me to work android app, foobar2000 upnp and all.
Could someone guide me to setup. I want to use the bubbleupnp app in android (with the license buyed) in my LAN and also outside.
it's not simple like described in the previous post.
i installed this component in foobar2000 (foo_upnp), the server in the PC too (http://bubblesoftapps.com/bubbleupnpserver/) and the app in android (https://play.google.com/store/apps/details?id=com.bubblesoft.android.bubbleupnp)
but nothing is working!.
sorry, i need help, please!.
Do any upnp servers show up in foobar2000 upnp browser? (Menu > View > Upnp Browser).
If not disable firewall just for testing, and then retry.
Also enable upnp server on mobile device BubbleUpnp App (Settings > Local Media Server > Enable)
no, i don't see any foobar2000 upnp servers in browser. only plex, and the server itself. see this:https://drive.google.com/open?id=0B2vZ6lUhEr87aFVpeUFwQzkxT2c&authuser=0
the firewall are granted for foobar2000, it's not general disabled
i'll try to attach more pictures tomorrow
