Closed TopicStart new topic
Unable to open item for playback (object not found)
php111
post Sep 22 2013, 10:23
While opening up the CUE in Foobar, I get unable to open the item for playback (object not found)
What does this mean and most important how do I fix it so everything could be normal?
yanni
post Sep 22 2013, 11:47
Make sure that the audio file referenced in the cue sheet (specified by the FILE command) does actually exist and is named exactly as in the cue (including extension).
php111
post Sep 22 2013, 12:51
Thank you! I'll try that later. I could tell you right now without looking at it, the CUE sheet when opened in notepad and the individual tracks in my directory where my music is are not correct when the CUE sheet is opened in notepad. On my directory I have the tracks as followed being 01 - the track name, but with the CUE sheet it has 201, so that part is not correct. Second, the CUE sheet has "track name.wav" WAVE, I have in my directory is track name.flac, so I'm guessing would be to edit the CUE and enter "track name.flac" WAVE? Correct?
db1989
post Sep 22 2013, 13:21
Of course.
php111
post Sep 23 2013, 01:41
It worked earlier, but then I deleted the FLAC tracks because I knew that I could open the CUE file in Foobar then right click tracks and go from there, but now the same error comes back up as with the error from my opening post.
Andreasvb
post Sep 23 2013, 07:00
The .cue file is just a small text file pointing to the actual music file, being the .flac file.
Windows 8.1u1 Pro x64 Media Center // foobar2000 1.3.3
php111
post Sep 23 2013, 11:19
QUOTE (Andreasvb @ Sep 23 2013, 02:00) *
That doesn't help me to get rid of those errors when loading the CUE file into Foobar.
Andreasvb
post Sep 23 2013, 11:28
Make sure it points to correct existing files.
php111
post Sep 23 2013, 11:33
I deleted all the track files except for the CUE file because my plans was to load the CUE file back into Foobar and then re-save them.
Andreasvb
post Sep 23 2013, 13:40
What do you need the cue file for in that case?
It will just list the tracks but no way to play them, a bit useless IMHO.
Ouroboros
post Sep 23 2013, 13:41
If you have the flac files then you simply edit the cue file to point to the correct flac files (which you say you did in posts 3 and 5), or use Cuetools to do it for you. If you have deleted the flac files then you no longer have anything to play.
php111
post Sep 23 2013, 20:04
Never mind. I actually made a backup before I delete it and I still don't remember making such a backup but I did. I didn't feel like ripping it again lol. Thank you!
However, what does this mean when 1 of 1 tracks converted with major problems, and how could that be fixed? Could it even be fixed? I read on another forum it might have to do with permissions of the drive. Would that be true?
This post has been edited by php111: Sep 23 2013, 20:05
db1989
post Sep 23 2013, 20:07
Please keep unrelated questions about ripping in the correct location, CD Hardware/Software.
php111
post Sep 23 2013, 20:10
Sorry.
And I tried converting a track in Foobar, it said 1 of 1 tracks converting with major problems. How do I fix that?
Could I ask that above here?
db1989
post Sep 23 2013, 20:14
Post #15
Sorry, I had a mental blank and assumed you were talking about a different application. Still, it is best to start a new thread when you have a different question. Start one here in fb2k/General.
php111
post Sep 23 2013, 20:15
Post #16
Ok, I'll start a new thread.
db1989
post Sep 24 2013, 01:29
Post #17
Locked.
RSS Lo-Fi Version Time is now: 21st September 2014 - 05:59
