32 Pages V  « < 20 21 22 23 24 > »
[Not my release] Biography view
romor
post Dec 24 2012, 17:30
Post #526
I got another idea - maybe your biography view panel is set to artist instead album?
You can check by right-clicking on biography panel, and switch by double-clicking on it.
And if you wish you can add command in Artist tab in biography view preferences - it's same as in Album tab but change "review" argument with "bio"
Although missing foo_allmusic.xml doesn't make this scenario very probable.
scripts: http://goo.gl/M1qVLQ
vine
post Dec 24 2012, 17:46
Post #527
I already tried that one too and was switching all the time between artist and album.
Is the foo_allmusic.xml necessary to display the reviews/bios? Can I manual create one?
romor
post Dec 24 2012, 18:19
Post #528
It's created by default to store the data.
If you did as suggested in post 522, you should have foo_allmusic.xml in your %homepath%
Press "Win+R", type cmd, then enter and type at command line:
dir foo*.xml
This should list the file.
If you do this, can you execute this command also:
cd %comspec:cmd.exe=% & dir foo*.xml
If it doesn't list anything, then open the script and change line 3: "Cache = 1" to "Cache = 0" and try again.
[edit] I just read that "//U" switch doesn't work on Windows 8, so don't use it and select ANSI, but try also UTF-8 just in case.
This post has been edited by romor: Dec 24 2012, 18:30
vine
post Dec 24 2012, 18:28
Post #529
Yay! Yes, the .xml file was in %homepath% (C:\Users\x). I moved it to the Foobar's folder and now my biography panel displays bios and reviews on every album.
Thanks a lot, romor.
This post has been edited by vine: Dec 24 2012, 18:29
romor
post Dec 24 2012, 18:33
Post #530
Strange, but glad it worked for you.
Did "cd %comspec:cmd.exe=% & dir foo*.xml" command list anything?
vine
post Dec 24 2012, 18:38
Post #531
The following is the output on both commands.
Microsoft Windows [Version 6.2.9200]
(c) 2012 Microsoft Corporation. All rights reserved.
C:\Users\x>dir foo*.xml
Volume in drive C has no label.
Volume Serial Number is AA79-3D0D
Directory of C:\Users\x
24.12.2012  15:47             2.523 foo_allmusic.xml
               1 File(s)          2.523 bytes
               0 Dir(s)  50.210.054.144 bytes free
C:\Users\x>cd %comspec:cmd.exe=% & dir foo*.xml
Directory of C:\Windows\System32
File Not Found
C:\Windows\System32>
romor
post Dec 24 2012, 18:42
Post #532
OK, thanks.
Let's wait and see if some other Windows 8 user will experience problems similar to yours. I can't make sense of it
vine
post Dec 24 2012, 22:56
Post #533
It seems like the script's caching didn't work for me (or Windows 8) by default although it was set to 1. The script didn't want to display information because it is set to cache the data, but there was no foo_allmusic.xml to save it to. After I found the foo_allmusic.xml and moved it to Foobar's folder, the biography panel showed the information, but it wasn't cached. foo_allmusic.xml didn't get updated. So I set the caching to 0, moved the foo_allmusic.xml to another location to see if the panel would work with out it - and it worked. Then I set the caching back to 1 and moved foo_allmusic.xml back to Foobar's folder and now it gets updated somehow.
romor
post Dec 25 2012, 00:07
Post #534
Don't know... If for some reason write access is denied that would be reported as error. If foo_allmusic.xml isn't found, then script is instructed to create it, and at the same time return False and query over HTTP and print result in panel. So script won't query over HTTP only if XML file is present and contains wanted data.
Whatever... set cache to 0 and don't worry about it, as I'm not convinced that writing to XML works for you (if that's what you mean with you last sentence)
vine
post Dec 25 2012, 02:35
Post #535
No, I meant, that writing to XML works now and that I don't know the reason either. I can see the reviews and biographies in the foo_allmusic.xml.
This post has been edited by vine: Dec 25 2012, 02:38
romor
post Dec 28 2012, 22:16
Post #536
talk.vbs download
Very simple script that mimics foo_talktome component.
Uses default voice settings (as set in speech control panel applet)
Example:
cscript //nologo talk.vbs "%title%. By %artist%, from %date% release %album%"
Should be add as first source in Album sources, as it doesn't return result so next source item will be executed afterwards.
This post has been edited by romor: Dec 28 2012, 22:42
pepito
post Jan 19 2013, 01:02
Post #537
Hello,
I'am not sure you are still talking about Biography view...
Nevertheless,maybe somebody could gently help me
I have 2 biography panels in my foobar,one for bio and one for cycling artist image
but the max images is only 6 in the prefs even if there is a lot more on lastfm
is it possible to display more than 6 images/photos ?
or with a command line like my other config on Seven,where I use album art panel to cycle images from within the artist folder
or maybe with the allmusic,you are using?
thank you
Super_Steve
post Jan 21 2013, 15:15
Post #538
Hi!
I'm not sure if this has been solved before, but I don't wanna read through 23 pages in case it hasn't been asked.
So, I'm using the biography plugin right now, but only for the pictures, no text, as a background.
I was wondering if it would be possible to pull pictures from somewhere else besides last.fm or Wikipedia, since their pictures are really low-res and it looks really bad when stretched.
Like, using a script or something.
I mean, it shouldn't be too hard to have a function to search google for the artist name with 'Size: large', take the first one and use that one instead?
romor
post Jan 22 2013, 14:26
Post #539
There is one limited possibility I know of. You can add biography panel with just image support enabled, and in "Biography server preferences" add built in artwork reader in source list. Then in "Display preferences" create file path pattern that points to image file provided by your script.
mire777
post Feb 16 2013, 22:03
Post #540
Today I noticed something strange. I can't see the whole biography.
Only the first few rows is visible, and then message:
''read more about ''artist'' on last.fm''
Something has changed on last.fm page, and causes this.
If you click on biography text, and go to last.fm page, you will see the same text.
But below it has button ''Read more...'' , after click on that you will get a full biography.
I think that's what is causing the problem.
If anyone has a similar problem or solution, let me know...
lender1257
post Feb 17 2013, 08:52
Post #541
QUOTE (mire777 @ Feb 16 2013, 23:03) *
same to me; something's changed on last.fm
hope the developer changes the plugin
foomark
post Feb 17 2013, 11:06
Post #542
QUOTE (mire777 @ Feb 16 2013, 22:03) *
marc2003
post Feb 18 2013, 10:13
Post #543
http://www.last.fm/group/Last.fm+Web+Servi...21604/_/2201974
mjm716
post Feb 18 2013, 13:14
Post #544
QUOTE (marc2003 @ Feb 18 2013, 11:13) *
any chance the panel could maintain the local XML data, if longer than what is available at lastfm? or simply not fetch anything if local version exists?
mire777
post Feb 18 2013, 13:27
Post #545
Really nothing that can be done? But let's say you go to the link http://www.last.fm/music/Jennifer+Lopez/+wiki, there you have a full biography. Maybe WSH script can pull this information? Or to change something in foo_uie_biography. I don't believe that it is impossible...
This post has been edited by mire777: Feb 18 2013, 13:29
Fooguy
post Feb 18 2013, 18:28
Post #546
Regarding the biography problem:
Now and then I use the Clementine music Player. And Clementine fetches the full biography from Last.FM 8-/
vomer
post Feb 18 2013, 20:34
Post #547
Well I posted a comment to that last.fm article link, and aside from half a dozen others it doesn't seem to be stirring up much complaint. Perhaps those of us who have last.fm accounts (or would make one) could let last.fm know how we feel?
mire777
post Feb 18 2013, 20:41
Post #548
QUOTE (vomer @ Feb 18 2013, 21:34) *
They don't care how we feel, believe me. They are looking way to make money. someone needs to update plugin...
This post has been edited by mire777: Feb 18 2013, 20:42
Zao
post Feb 19 2013, 04:07
Post #549
Group: Members (Donating)
How would you "update" the plugin if the API doesn't expose the functionality.
Screen-scraping is an excellent way of making the lives of everyone worse.
marc2003
post Feb 19 2013, 10:27
Post #550
QUOTE (mire777 @ Feb 18 2013, 12:27) *
that's a web page - complete different from the webservices API that this component and my scripts utilise.
it is possible to scrape webpages but it's not something i'd ever waste my time doing. if you go back over this thread, romor has posted some scraping scripts that go over the allmusic site to pull info. take a look at that if you like.
BTW, my WSH panel mod script no longer tries to update if a cached file exists. obviously this is only useful for people who've used my script previously and already have a cache built up. details here: http://www.hydrogenaudio.org/forums/index....st&p=824713
This post has been edited by marc2003: Feb 19 2013, 10:38
RSS Lo-Fi Version Time is now: 15th September 2014 - 11:40
