4 Pages V   1 2 3 > »
Exact Audio Copy V0.99 prebeta 3, Updated Aug. 18. PB3 out.
magic75
post Jun 30 2007, 10:05
Change Log
- Better AccurateRip support (reading ranges and CD images)
- Improved log file output
- Flac encoder now comes with EAC
- Much improved configuration wizard
- Writing CD-Text using CDRDAO
- Copy and test range
- Added writing new tags for ID3V2 like duration, encoder settings and the CD TOC
- Correction of Xing header after writing ID3V2
- Drive options are now stored by the drive name and not by adapter and LUN
- Fixed many issues and bugs
Homepage & Download: http://www.exactaudiocopy.de/
Alternative: http://www.exactaudiocopy.de/en/index.php/...tive-servers-2/
This post has been edited by magic75: Jun 30 2007, 10:04
Synthetic Soul
post Jun 30 2007, 13:18
Test & Copy for images.
I guess I'm going to have to give that a try.
Thanks for the info.
I'm on a horse.
Fandango
post Jun 30 2007, 16:17
<fanboymode> gun2.gif Eat that dMC! gun2.gif </fanboymode>
Great work, Andre!
gib
post Jun 30 2007, 17:24
QUOTE (magic75 @ Jun 29 2007, 23:05) *
So AccurateRip is usable even when ripping to images? Woo hoo!
greynol
post Jun 30 2007, 17:26
...and ranges as well.
Fandango
post Jun 30 2007, 17:28
greynol
post Jun 30 2007, 17:33
QUOTE (Fandango @ Jun 30 2007, 09:28) *
Nope, there is a distinct difference: ripping an image is a specific case of copying ranges. tongue.gif
This post has been edited by greynol: Jun 30 2007, 17:54
Keykey
post Jun 30 2007, 18:00
Installed the new EAC and I am testing the T&C for images.
Ripping now a cd and it will take well over 40 minutes!!! blink.gif blink.gif Read speed is just (while re-reading) 1.2X blink.gif
I use Secure Mode and a cd is ripped normally in 7 - 8 minutes. Why does it take so long to "check" the Image?? Am I losing something in the way?
EDIT
LOG:
Exact Audio Copy V0.99 prebeta 1 from 25. May 2007
EAC extraction logfile from 30. June 2007, 19:04
Aces High / Pull No Punches
Used drive : PLEXTOR CD-R PREMIUM Adapter: 1 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 30
Overread into Lead-In and Lead-Out : Yes
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks : No
Used interface : Installed external ASPI interface
Used output format : User Defined Encoder
Selected bitrate : 32 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Archivos de programa\Exact Audio Copy\wapet.exe
Additional command line options : %d -t "Artist=%a" -t "Title=%t" -t "Album=%g" -t "Year=%y" -t "Track=%n" -t "Genre=%m" mac.exe %s %d -c3000 -v
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.32 | 4:50.65 | 32 | 21846
2 | 4:51.22 | 4:23.30 | 21847 | 41601
3 | 9:14.52 | 4:02.73 | 41602 | 59824
4 | 13:17.50 | 5:33.57 | 59825 | 84856
5 | 18:51.32 | 4:20.08 | 84857 | 104364
6 | 23:11.40 | 6:30.17 | 104365 | 133631
7 | 29:41.57 | 4:21.18 | 133632 | 153224
8 | 34:03.00 | 5:04.35 | 153225 | 176059
9 | 39:07.35 | 4:29.65 | 176060 | 196299
10 | 43:37.25 | 5:14.45 | 196300 | 219894
Range status and errors
Selected range
Filename C:\RIPEOS EAC\Aces High - Pull No Punches.wav
Peak level 0.0 %
Range quality 97.0 %
Test CRC 28697CAA
Copy OK
AccurateRip summary
Track 1 accurately ripped (confidence 1) [945F87DF]
Track 2 accurately ripped (confidence 1) [381493BD]
Track 3 accurately ripped (confidence 1) [A8E4D508]
Track 4 accurately ripped (confidence 1) [E1B66268]
Track 5 accurately ripped (confidence 1) [1A80E060]
Track 6 accurately ripped (confidence 1) [57F8461C]
Track 7 accurately ripped (confidence 1) [5A7AEA3A]
Track 8 accurately ripped (confidence 1) [6F112F39]
Track 9 accurately ripped (confidence 1) [5BC45176]
Track 10 accurately ripped (confidence 1) [E4A14345]
No errors occurred
End of status report
After over 40 minutes I get a 0.08 MB *.ape file!!! crying.gif or laugh.gif --> don't know what to do! unsure.gif
This post has been edited by Keykey: Jun 30 2007, 18:09
eofor
post Jun 30 2007, 18:12
10 years in beta - this must be the longest development-stage ever? Google must be jealous biggrin.gif
Elbart
post Jun 30 2007, 18:18
QUOTE (eofor @ Jun 30 2007, 19:12) *
Fandango
post Jun 30 2007, 18:31
QUOTE (Keykey @ Jun 30 2007, 19:00) *
You know what really irritates me here? This:
While the rip obviously went wrong, correct data was actually extracted at some point... wasn't it? Or did you manage to change your computer ID for AR somehow?
This post has been edited by Fandango: Jun 30 2007, 18:32
greynol
post Jun 30 2007, 18:37
How do you know that the actual rip went wrong?
Seems like there was a problem with the encoding, not the rip.
This post has been edited by greynol: Jun 30 2007, 18:40
Fandango
post Jun 30 2007, 18:38
QUOTE (greynol @ Jun 30 2007, 19:37) *
Peak level 0.0 %
A CD filled with silence?
greynol
post Jun 30 2007, 18:40
Keykey
post Jun 30 2007, 18:42
Post #15
Peak level 0.0 %
greynol
post Jun 30 2007, 18:44
Post #16
...though it looks like there was only a test CRC that was generated. Was that the enitre log?
btw, the "-v" in your command line does absolutely nothing(!) (unless it's causing an error).
Why not test one thing at a time instead of blowing your wad all at once? Try T&C of the image as a wave file.
This post has been edited by greynol: Jun 30 2007, 18:46
Fandango
post Jun 30 2007, 18:49
Post #17
QUOTE (greynol @ Jun 30 2007, 19:42) *
Yes! That's odd. blink.gif The Copy CRC is missing.
It is possible to save and see the log of a test without actually doing a rip to the disk, but only for Track based tests ("Test Selected Tracks" F8). How did you manage to do "Test Image"? Maybe there is something wrong with the encoder settings and it will make EAC skip the copy part?
This post has been edited by Fandango: Jun 30 2007, 18:53
Keykey
post Jun 30 2007, 18:53
Post #18
QUOTE (greynol @ Jun 30 2007, 19:44) *
1.- Yes, it was the entire log.
2.- Thanks for the tip about the -v commnad. I had never been sure it should be there or not wink.gif
This time I did not use the "Test and copy" but just "Copy the Image":
EAC extraction logfile from 30. June 2007, 19:43
Deep Purple / Machine Head
Read mode : Secure
Quality : High
Add ID3 tag : No
1 | 0:00.33 | 6:08.57 | 33 | 27689
2 | 6:09.15 | 4:50.33 | 27690 | 49472
3 | 10:59.48 | 5:03.50 | 49473 | 72247
4 | 16:03.23 | 3:59.55 | 72248 | 90227
5 | 20:03.03 | 5:40.55 | 90228 | 115782
6 | 25:43.58 | 7:22.00 | 115783 | 148932
7 | 33:05.58 | 4:32.57 | 148933 | 169389
Selected range
Filename C:\RIPEOS EAC\Deep Purple - Machine Head.wav
Peak level 100.0 %
Range quality 100.0 %
Copy CRC 6FBD68AD
Copy OK
AccurateRip summary
Track 1 accurately ripped (confidence 7) [648E1CE7]
Track 2 accurately ripped (confidence 7) [022C25E2]
Track 3 accurately ripped (confidence 7) [BD1E3539]
Track 4 accurately ripped (confidence 7) [E1697794]
Track 5 accurately ripped (confidence 8) [4DF6E910]
Track 6 accurately ripped (confidence 7) [69A5A7BE]
Track 7 accurately ripped (confidence 7) [662A3CE0]
No errors occurred
Doing now another rip with T&C
Fandango
post Jun 30 2007, 18:55
Post #19
Keykey
post Jun 30 2007, 18:57
Post #20
QUOTE (Fandango @ Jun 30 2007, 19:55) *
Yes.
I am going to try again with the previous one. Results in an hour or so.
Synthetic Soul
post Jun 30 2007, 19:33
Post #21
NB: Here's the log from my first image T&C.
EAC extraction logfile from 30. June 2007, 14:35
Kings of Leon / Aha Shake Heartbreak
Used drive : PLEXTOR CD-R PX-W5224A Adapter: 1 ID: 0
Read mode : Secure
Make use of C2 pointers : Yes
Overread into Lead-In and Lead-Out : No
Used output format : Internal WAV Routines
Sample format : 44.100 Hz; 16 Bit; Stereo
1 | 0:00.00 | 3:54.09 | 0 | 17558
2 | 3:54.09 | 2:25.36 | 17559 | 28469
3 | 6:19.45 | 3:05.43 | 28470 | 42387
4 | 9:25.13 | 2:20.52 | 42388 | 52939
5 | 11:45.65 | 4:00.20 | 52940 | 70959
6 | 15:46.10 | 2:55.44 | 70960 | 84128
7 | 18:41.54 | 2:59.24 | 84129 | 97577
8 | 21:41.03 | 2:15.63 | 97578 | 107765
9 | 23:56.66 | 3:33.01 | 107766 | 123741
10 | 27:29.67 | 2:09.33 | 123742 | 133449
11 | 29:39.25 | 2:11.00 | 133450 | 143274
12 | 31:50.25 | 3:22.39 | 143275 | 158463
13 | 35:12.64 | 2:23.61 | 158464 | 169249
Selected range
Filename E:\CDBackup\Kings of Leon - Aha Shake Heartbreak.wav
Peak level 100.0 %
Test CRC 95EB659B
Copy CRC 95EB659B
Copy OK
AccurateRip summary
Track 1 accurately ripped (confidence 7) [26C3C3B3]
Track 2 accurately ripped (confidence 7) [021E9A14]
Track 3 accurately ripped (confidence 7) [4C3E3743]
Track 4 accurately ripped (confidence 7) [4E7A5ED3]
Track 5 accurately ripped (confidence 7) [4969222B]
Track 6 accurately ripped (confidence 7) [12513A61]
Track 7 accurately ripped (confidence 7) [FC28C812]
Track 8 accurately ripped (confidence 7) [8BA6ECBC]
Track 9 accurately ripped (confidence 7) [81053A0E]
Track 10 accurately ripped (confidence 7) [EB37A4B2]
Track 11 accurately ripped (confidence 7) [99260264]
Track 12 accurately ripped (confidence 7) [CD02F674]
Track 13 accurately ripped (confidence 7) [7E6B6A3B]
No errors occurred
I'm on a horse.
Societal Eclipse
post Jun 30 2007, 19:35
Post #22
Only the alternate download links go to 0.99 PB1 for me... the main links still point to 0.95 B4.
"Have you ever been with a woman? It's like death. You moan, you scream and then you start to beg for mercy, for salvation"
Keykey
post Jun 30 2007, 20:21
Post #23
EAC extraction logfile from 30. June 2007, 21:10
Read mode               : Secure
Quality                         : High
Add ID3 tag                     : No
Selected range
     Peak level 0.0 %
     Test CRC 28697CAA
     Copy OK
AccurateRip summary
No errors occurred
prankstare
post Jun 30 2007, 20:55
Post #24
Nice,
Besides the fact FLAC codec is now packed together with the new release, EAC will now store their log file into the extracting directory. Speaking of changes, the selective bitrate range now goes from 32 to 1024kBit/s in 'User Defined Encoder' parameter.
odyssey
post Jun 30 2007, 21:11
Post #25
SERIOUS BUG FOUND!
When you tick "Eject CD after extraction", and performs a T/C image, it will eject the CD after the test is done, and proceed ripping as if the disc were present.
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 25th May 2015 - 19:22
