Peakmeter spectrum component, Download...
foo_pm
post Feb 10 2008, 12:05
Foo_uie_peakmeter_spectrum is a foobar2000 plugin that combines a peakmeter with a spectrum analyzer. It requires Columns UI and is the successor of foo_uie_peakmeter. The component can be used as a peakmeter and/or a spectrum analyzer. This forum is only used as a download location. If you got questions, comments or suggestions please post it to the Main Thread. Instructions can be found in the peakmeter spectrum wiki.
Previous version(s):
Attached File  foo_uie_vis_peakmeter_spectrum_0100.zip ( 109.81K ) Number of downloads: 6415
Attached File  foo_uie_vis_peakmeter_spectrum_0101.zip ( 109.83K ) Number of downloads: 4314
Attached File  foo_uie_vis_peakmeter_spectrum_0102.zip ( 110.33K ) Number of downloads: 13916
Current version: 0.2.0.0 beta
Attached File  foo_uie_vis_peakmeter_spectrum_0_2_0_0.zip ( 111.28K ) Number of downloads: 46836
Change log:
Presets:
Attached File  peakmeter_spectrum_preset_1_0100.zip ( 462bytes ) Number of downloads: 7115
Attached File  peakmeter_spectrum_preset_2_0100.zip ( 500bytes ) Number of downloads: 10596
This post has been edited by foo_pm: Apr 19 2008, 20:06
Raxxion
post Jun 24 2010, 08:48
How can I get this working in Foobar2000 1.0.3?
Robertina
post Jun 24 2010, 11:28
Group: Banned
Raxxion, did you read the post above yours? The right thread for your question is here and your answer you can find in the component's Wiki.
saivert
post Jul 21 2010, 16:03
I think he was looking for a Default UI version of this. Not something that requires Columns UI to work.
This post has been edited by saivert: Jul 21 2010, 16:03
http://foobar2000.saivert.com - foobar2000 component repository
iamthejeff
post Oct 26 2011, 22:07
I was hoping somebody could help me out with a problem with this component
It's been working great for some time now, until recently. It appears to pause every second or so, as if it's lagging.
I've tried increasing it's refresh rate from 5ms up to 20 or 30ms, but it still happens. Thinking it was a CPU issue, I've disabled all DSPs I have active, disabled replay gain, tried kernel streaming vs regular output, switched between 16bit and 24 bit playback, increased the buffer. No change. foobar uses about 15% cpu constantly while playing, I don't know if that's high or not (I have an i5 processor). I've even tried playing songs from different hard drives thinking it was a disk reading issue, but no change there either.
I am beginning to think it's a bug with the new version of foobar, since I updated it recently... but I am wondering if anyone else has any tips I could try.
dagfaune
post Mar 15 2014, 15:43
foo_musical_spectrum.dll
http://www.hydrogenaudio.org/forums/index....showtopic=97404
XPiRx
post Oct 22 2014, 01:02
QUOTE (iamthejeff @ Oct 26 2011, 16:07) *
I just installed a new video card today, 5870 -> R9 280. I never had this issue before until this new video card. I have tried several different drivers and just about everything I can think of. The smaller the window and less bars there is, the less laggy it is. It uses 25% constant CPU and the GPU is 100% usage and still laggy. I'm wondering if it has something to do with the new architecture of the GPU, since the 5870 is from ~2010 when the last update for this component was. I switched to the musical spectrum that was linked above this post and have absolutely no issues with that. Just wish it showed the Hz instead notes, but im not complaining, I can display a lot more Hz levels on this new component. Just wish I could figure out the peakmeter spectrum issue, doubt that will happens since its not maintained anymore.
RSS Lo-Fi Version Time is now: 19th December 2014 - 13:59
