How do I get frameLength from packets from FFmpeg?, [split from “AAC Bitstream format”, thread 97442/TOS #5]
trungnq
post Feb 27 2013, 10:40
Hi all,
I use ffmpeg to generate adts stream:
ffmpeg -re -i input.mp3 -acodec aac -strict experimental -ab 64k -f adts tcp://localhost:1234
I have a sequence of packets with different size (normally around 200bytes each). I can extract the adts header with 7 bytes by following this http://wiki.multimedia.cx/index.php?title=ADTS (by the way, do anybody know about the field calls "Buffer fullness" in ADTS header?).
To decode (using http://labs.official.fm/codecs/aac/) I need to know frameLength, but I don't know how to get this value from packets I receive from ffmpeg. As I understand, frame length is the number of samples in one frame. I don't know if it's correct or not (please correct me if I am wrong). The packets are varies in size, does it mean the frameLength is not fixed for ADTS packets?
Thanks a lot in advance!!
--Trung
trungnq
post Feb 27 2013, 17:42
After googling around, I see the frameLength is always 1024 (samples in a frame). I am going to test the decoder, see if it works.
trungnq
post Feb 28 2013, 10:43
But one strange thing with ffmpeg is, sometimes it generates some big adts packet. Normally adts packet with 64kbs is around 200bytes per frame, but sometimes, I get 1000+bytes packet. This make the sound a bit weird (at least with my decoder). But in the adts header, the actual frame size is much smaller than 1000+bytes. So there are some redundant bytes (don't know what does it use for).
trungnq
post Mar 1 2013, 10:03
It seems there is no problem when I use ffmpeg with -acodec libfaac.
QUOTE (trungnq @ Feb 28 2013, 10:43) *
RSS Lo-Fi Version Time is now: 2nd September 2014 - 21:35
