18 Pages V  « < 13 14 15 16 17 > »
qtaacenc: a command-line QuickTime AAC encoder for Windows
IgorC
post Sep 23 2011, 01:17
Post #351
Nice. Works here.
Thank you.
Is it possible to do fully portable package (without downloading QuickTimeInstaller.exe or iTunesSetup.exe ) or it will violate some licence? Or some workaround in such situation?
sneaker
post Sep 23 2011, 02:04
Post #352
Thx for this progam, just used the portable version for the first time.
The channel mapping for 5.1 seems to be wrong, though:
original - qtaac
FL - C
FR - FL
C - FR
BL - BR
BR - LFE
LFE - BL
lvqcl
post Sep 23 2011, 18:13
Post #353
QUOTE (IgorC @ Sep 23 2011, 04:17) *
It is technically possible, but I don't know is it legal or not.
C.R.Helmrich
post Oct 11 2011, 20:06
Post #354
fyi, iTunes 10.5 is apparently out. The 64-bit Windows release notes have an interesting note:
Note: iTunes 10.5 no longer requires or includes QuickTime.
Chris
lock67ca
post Oct 11 2011, 20:29
Post #355
No Quictime? Interesting. Updated AAC encoder? TVBR? Guess I'll have to do some testing on the new iTunes.
kornchild2002
post Oct 11 2011, 23:58
Post #356
I don't see any encoder updates to the iTunes AAC encoder settings under Mac OS X so no true VBR. Also, based on the release notes, I don't think they changed the AAC encoder. The only updates they seemed to apply (aside from what has already been mentioned which does not really affect Mac OS X users) revolved around the integration of iCloud in that iTunes can wirelessly sync devices running the latest version of iOS and it can also automatically download previously purchased apps, TV shows, eBooks, and music content (songs, iTunes LP files, and music videos) that are not located in your iTunes library. The last version of iTunes could not automatically do this, you had to download each and every file manually while it can do that automatically now. It didn't bring iTunes Match yet but that isn't supposed to come until the end of the month.
Elbart
post Oct 12 2011, 10:40
Post #357
-blub sorry, my mistake-
This post has been edited by Elbart: Oct 12 2011, 10:49
lvqcl
post Oct 13 2011, 15:40
Post #358
So iTunes now uses CoreAudioToolbox/CoreFoundation/etc directly. Interesting.
polemon
post Oct 13 2011, 20:14
Post #359
Could we have HE-AAC+v2 encoding with qtaacenc.exe? Would be nice to have all kinds of encoding options in one tool.
This post has been edited by polemon: Oct 13 2011, 20:14
-EOF-
kareha
post Oct 13 2011, 20:16
Post #360
Slightly off topic, but if iTunes no longer requires Quicktime and doesnt come with it, is it not possible to use WASAPI for iTunes anymore?
polemon
post Oct 13 2011, 22:06
Post #361
I'd like to ask a casual question: What settings should I use for listening on mobile devices (iPod)?
Right now, all I do is this:
qtaacenc.exe --highest input.wav
I leave the rest on defaults. Is that advisable? I'd like transparent results, so I reckon a higher quality setting would be in order, correct?
In case someone has experience with that, please respond.
-EOF-
mixminus1
post Oct 13 2011, 23:24
Post #362
Well, if you don't specify an encoding mode and parameters, it encodes at True VBR 65.
That gives bitrates roughly in the same range as LAME's V5 switch, so basically ~128 kb/s nominal target rate, with variations quite a bit above or below that depending on the music.
Apple's AAC encoder has proven to be very good in the last couple lower-bitrate (64 kb/s and 96 kb/s) listening tests, so it's reasonable to assume it's quite good at TVBR 65, but as to whether or not it's transparent to you...as usual, only doing your own ABX tests can answer that.
FYI, there's a bug in the QuickTime AAC encoder (at least as of v7.7.0) that can potentially introduce artifacts - in all encoding modes - if the quality switch is above "--normal" - see here for an example of a track that causes it.
polemon
post Oct 14 2011, 01:44
Post #363
Well, that's why I was asking. I did encode with default values (except --highest), and once again with --tvbr 96. I believe I heard artifacts, but I didn't know if it was just something I was imagining, or if it was artifacts at higher VBR settings. I was thinking I was using wrong parameters, but it seems I've ran into the bug.
I'll keep an eye on this. I've encoded a number of files with --tvbr 96 and have already tagged them. Seems I need to do this all over again, once I recreate them (I still have the FLACs that I used as source).
Anyway, thanks for bringing this to my attention.
-EOF-
mixminus1
post Oct 14 2011, 20:46
Post #364
QUOTE (polemon @ Oct 13 2011, 17:44) *
ABX! That's exactly what it's for.
Before you can say whether or not you're hearing artifacts due to an encoder bug, you need to at least establish whether or not you're even hearing artifacts.
Boulder
post Oct 15 2011, 17:53
Post #365
QUOTE (subinbar @ Sep 17 2011, 10:11) *
Any version of CoreAudioToolbox.dll after 7.6.3.0 applies and incorrect channel map on multichannel files:
http://sites.google.com/site/qaacpage/news/aboutquicktime77
You have two options - get an older version of CoreAudioToolbox.dll that was mentioned earlier in this thread, or use qaac.exe instead of qtaacenc.exe because it automatically remaps the channels for the newer versions of quicktime.
I have v7.7.0 and it seems to produce correct channelmapping, I just tried encoding a surround test clip and the result sounded fine on headphones (used eac3to to decode the 5.1 AC3 file and piped to qtaacenc to encode to 5.1 AAC). If I use the channel remapping in eac3to that was mentioned earlier in this thread, the mapping is incorrect in the result.
Boulder
post Oct 15 2011, 22:50
Post #366
QUOTE (Boulder @ Oct 15 2011, 19:53) *
Heck, it seems that encoding a 5.1ch DTS-HD MA file produces incorrect mapping...need to investigate more mad.gif
06_taro
post Nov 1 2011, 06:40
Post #367
7.7.1's CoreAudioToolbox (version 7.9.7.8) is still broken.
clintb
post Nov 9 2011, 06:25
Post #368
QUOTE (Khanattila @ Apr 13 2010, 07:29) *
I have this problem, no one can help me?
This is the result in foobar2000:
1 out of 1 tracks converted with major problems.
Source: "F:\Audio - Video\Foobar\Ghost.wav"
An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "F:\Audio - Video\Foobar\Ghost.m4a"
Additional information:
Encoder stream format: 44100Hz / 2ch / 16bps
Command line: "D:\Program Files (x86)\qtaacenc-20100307\qtaacenc.exe" --tvbr 100 --highest - "Ghost.m4a"
Working folder: F:\Audio - Video\Foobar\
Conversion failed: The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters
Edit: now work
I've just setup Foobar with qtaacenc and the latest version of Qucktime (7.7.1) and I'm getting the same error. I've dealt with this once before, but for the life of me I can't remember what I ended up doing to fix it.
Any help would be appreciated.
ErnestS
post Nov 9 2011, 14:21
Post #369
I got the same problem using Quicktime 7.7.1.
QuickTime 7.6.9 works without a problem.
b66pak
post Nov 9 2011, 17:38
Post #370
please update to the latest version (qtaacenc-20110816)...
http://tmkk.pv.land.to/qtaacenc/
_
clintb
post Nov 9 2011, 18:16
Post #371
QUOTE (b66pak @ Nov 9 2011, 09:38) *
_
Weird, I downloaded that yesterday and it wasn't working. Downloaded again this morning and it's now working. Did the file change?
Regardless, thank you for the spurring to dl again!
smok3
post Nov 10 2011, 11:14
Post #372
A/V Moderator
Group: Moderator
@nao: do you have a similar OS X version of this utility? Or should one use badly documented afconvert? If so, do you happen to have any decent docs about afconvert? (especially considering HE-AAC v1 and v2 and multichannel with pipe as input)
This post has been edited by smok3: Nov 10 2011, 11:54
nao
post Nov 10 2011, 11:55
Post #373
afconvert doesn't accept pipe input, but besides that it should have all encoding features that qtaacenc has.
It will be easy to provide the same tool for OSX, because a large part of the feature is already implemented in my another project for OSX (XLD). But should I do that?
DARcode
post Nov 10 2011, 12:04
Post #374
Group: Members (Donating)
nao, would you be OK with integrating the necessary code by lvql into the official build to enabel portability please?
WavPack 4.70.0 -b384hx6cmv/qaac 2.41 -V 100
smok3
post Nov 10 2011, 12:05
Post #375
A/V Moderator
Group: Moderator
would one of the features be the piping input?
If there is enough demand, certainly do not bother if my request is the only one smile.gif
RSS Lo-Fi Version Time is now: 17th September 2014 - 17:41
