IPB
> foobar2000 Tech Support Forum Rules
Please read foobar2000 Tech Support Forum Rules before posting and comply with all the points.
Failure to provide all the information pointed out in the above document in your post is considered wasting other people's time and in extreme cases will lead to your topic getting locked without a reply.
See also: Hydrogenaudio Terms of Service.
converter error with multiple encoder instances, overwrighting a file that's being encoded results in the encoding
kotekzot
post Feb 11 2008, 15:45
Post #1
Group: Members
usually, when telling the converter to overwrite a file it will work without problems, but if multiple encoding threads are running it may return a sharing violation error and quit the conversion (the progress window disappears, foobar runs fine) if the file it tries to overwrite is currently being encoded by another thread.
this problem occurs in foobar2000 0.9.5
ooops, the topic description field is too short.
This post has been edited by kotekzot: Feb 11 2008, 15:48
Go to the top of the page
+Quote Post
Purple Monkey
post Feb 11 2008, 18:50
Post #2
Group: Members
You can set Preferences -> Advanced -> Tools -> Converter -> Thread Count to 1 so that foobar will only use one thread at a time. This will stop two instances of that encoder trying to write to the same file.
+Quote Post
kotekzot
post Feb 11 2008, 19:37
Post #3
Group: Members
+Quote Post
thuan
post Feb 12 2008, 03:32
Post #4
Group: Members
I don't have a quad-core only a dual, but I haven't encountered this problem once. IIRC there're certain decoders (especially those that decode game music files) that are not thread-safe. So what do you transcode from and to?
+Quote Post
kotekzot
post Feb 12 2008, 11:44
Post #5
Group: Members
i was using oggenc2 to transcode mp3s to q5 oggs for my flash player. the best way to simulate it would be to add the same track twice and then attempt to transcode it.
+Quote Post
foosion
post Feb 12 2008, 11:55
Post #6
Group: FB2K Moderator (Donating)
So the problem is that you try to convert the same file multiple times in the same batch set and that converter tries to generate the same output file multiple times?
http://foosion.foobar2000.org/ - my components for foobar2000
+Quote Post
kotekzot
post Feb 12 2008, 12:00
Post #7
Group: Members
i was converting multiple albums to the same directory with the following naming scheme %artist% - %title%, so if there were same tracks on different albums they would overlap. i used to do 'overwrite all' so i wouldn't have to skip 100 times on my single core pc, but now that i encode 4 songs at the same time sharing violation occurs.
+Quote Post
nilla
post Feb 13 2008, 06:24
Post #8
Group: Members
(EDIT: Nevermind...)
Sounds like you're going to have to add a unique variable to your file name scheme.
This post has been edited by nilla: Feb 13 2008, 06:25
+Quote Post
foosion
post Feb 13 2008, 10:01
Post #9
QUOTE (kotekzot @ Feb 12 2008, 12:00) *
Sorry for that, I was just trying to understand the problem. Never mind that doing idiotic things to software is a good way to reveal bugs, I have quite some experience with that. tongue.gif
Anyway, thanks for clearing up what triggers the problem.
+Quote Post
kotekzot
post Feb 13 2008, 10:08
Post #10
Group: Members
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 31st March 2015 - 23:46
