CUI: [feature request] Foobar only in tray, i.e. disable taskbar completely
wojtek
post Sep 30 2011, 13:43
right now there is an option to minimize foobar2000 to the tray, but when the application is restore there is still a taskbar item. It might be helpful, but with the double-display setup when on has the application constantly visible on the second screen there is hardly a need for the taskbar item (especially when one has a lot of application running and taskbar is getting quite crowded)
http://foobar2000.pl/ :: unofficial polish forum
db1989
post Oct 1 2011, 14:59
Searching revealed several past threads on the same question. It seems that this isnít possible (refs.: [1], [2]).
This post has been edited by db1989: Oct 1 2011, 15:00
shakey_snake
post Oct 1 2011, 16:22
Group: FB2K Moderator
In your unique situation, you may want to consider using a UI, such as columns, that can be customized to fit your unique needs.
As far as the Default UI, this won't be implemented because having an open window appear in the taskbar IS a usability and accessibility requirement.
elevatorladylevitateme
wojtek
post Oct 2 2011, 16:57
Well, I'm using ColumnsUI but haven't found option there either. fortunatelly i've stambled upon <removed> which does the trick.
as for the requirement -- is it mandated by MS/Windows? also - how do *option* to do so violates this? It's meant for the (hate the phrase) 'power user' who should know the consequences of it..
This post has been edited by Frank Bicking: Oct 2 2011, 17:51
Reason for edit: Removed reference to an illegal component.
shakey_snake
post Oct 2 2011, 20:32
QUOTE (wojtek @ Oct 2 2011, 11:57) *
Well, I'm using ColumnsUI...
Great, then you should be asking musicmusic. Thread Moved
This post has been edited by shakey_snake: Oct 2 2011, 20:36
wojtek
post Feb 5 2012, 12:49
QUOTE (shakey_snake @ Oct 2 2011, 20:32) *
A noob question -- is it possible for an external plugin/componend to achieve that without violating SDK?
RSS Lo-Fi Version Time is now: 3rd September 2014 - 00:03
